Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 09-22-2012, 18:36   #31 (permalink)
Member: 1745330
Hi,
yes it's true. I did with E7
But if you want upgrade again to Belle....NO WAY
Old 09-25-2012, 14:49   #32 (permalink)
Crazy Poster
Member: 1703463
i did test on nokia e6 to downgrade frome belle to anna but after restore the pm phone is hanged on nokia logo............
Old 09-25-2012, 16:11   #33 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Post the LOGS here , Without LOG we cant help you
Br - srinibas
Old 10-26-2012, 11:55   #34 (permalink)
HARISH4u's Avatar
Member: 1417266
i did successfully belle to anna N8 but now i want belle back
i flashed it with belle file test mode ok but phone is now hang on nokia then its off how can i fix this problem
Old 10-26-2012, 12:06   #35 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
Phones without CMLA KEY won't work on Belle versions. For now if you
want phone to work with Belle version, then you'll need to buy an RPL
file from Nokia or you can stay at Anna version without to buy an RPL file.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 10-26-2012, 12:11   #36 (permalink)
HARISH4u's Avatar
Member: 1417266
Ok i stay on anna but if i get an other phone how can i make backup cmla key like my n8
& hoW I CAN WrITE IT On PHONE
Old 10-26-2012, 12:13   #37 (permalink)
Member: 183390
The problem is not on the phone. The problem is the user who keeps on experimenting there unit . and if s h i t happens call for support. and sometimes blame the box for it. Grow up people .
Old 10-26-2012, 12:34   #38 (permalink)
HARISH4u's Avatar
Member: 1417266
DEAR I ONLY CONFIRM THAT CAN I REPAIR CMLA KEY OR AN OTHER WAY BELLE SOFTWARE WORKING WAY ITS NOT MY PROBLEM
its PEOPLES problem bcoz if they want to anna from belle they use it 2 or 3 days then they told many type of problem then wants to again back belle
& iam not blaming on team or any supporters atf team always BEST & ANGEL is always good
& FAST REPLY
Old 10-26-2012, 13:25   #39 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
For now, we don't support CMLA KEY backup. In next release we will have it IN SHA ALLAH.
Old 10-26-2012, 16:03   #40 (permalink)
HARISH4u's Avatar
Member: 1417266
Thanks brother i know you bring it first
Old 11-21-2012, 17:49   #41 (permalink)
road_hunter420's Avatar
Member: 896397
Sonork: 100.1603751
Wink
Originally Posted by ..::Angel::.. View Post
بِسْمِ اللّهِ الرَّحْمنِ الرَّحِيمِ
Hi, I saw many users stuck with these Nokia phones in downgrading firmware.. Don't have working ENO for 25.xx.xx Anna Firmwares? Don't worry!
Here is the working solution for them:
1. Backup RPL and Full PM
2. Full Erase Phone Flash chip
3. Write Flash with 25.xx.xx Anna version - CORE, ROFS3, ROFS2 and UDA - NO LOCAL MODE ON SCREEN ??? :O) Go for next step ...
4. Power On phone in NORMAL MODE, select OVI Suite in phone
5. Write Full PM Backup - (YES, PM BACKUP - NOT RPL) - SIMLOCK will remain corrupted without NPC DATA, but PM Backup written to phone
6. Write RPL Backup
7. Authorize Phone via ATF Network
8. Again Power On phone in NORMAL MODE, if phone stuck on "Nokia Logo" Reconnect Battery and Power On again - this time it will be powered on.
9. Go to PM/PP tab, select "StandAlone SX4 AUTH" Write RM-1.pm or RM-xxx.pm of your phone or the backup - it doesn't matter.
10. Click SD/CMLA KEY check button. CMLA KEY would be absent, but Anna Firmware can work without it. Phone back to normal and downgraded from Belle to Anna. :O)
Nokia BB5 SL3 Firmware downgrade via USB cable:
Trust ATF...
Thxxx Brother 100% working solution
successfully flashed E7 from 111.040.1511 to 25.007 using ATF
Old 12-18-2012, 08:10   #42 (permalink)
Member: 341702
Help for nokia N8
I did lik all said in no1 post..i flashed with 025.008 RM-596..the phone turned on but says "Phone startup failed..contact the retailer"..nd i scanned the phone on ATF which says "unable to read SP data"..this phone was just user locked n i flashed..i need urgent help..help plzzzzzzzzz...
Old 12-18-2012, 08:21   #43 (permalink)
Member: 341702
i forgot to mention tht i couldnt backup full pm from phone since it was dead n i dnt think atf saved the full pm so i had to write a simple RM-596 pm from UB folder..
Old 12-18-2012, 09:03   #44 (permalink)
Member: 643472
Sonork: 100.96901
@sahilguraya
Phone in contact retailr, because you didn't read my first post...
ATF can recover simlock from dead phone, other N8 PMs will never work.
Since you have now corrupted simlock without have backup, then you
have to make Level 3 recovery for 25 SRP credit in order to resolve this
problem.
Old 12-20-2012, 18:22   #45 (permalink)
Member: 1144411
Sonork: 100.1593619
Solved
Hi solution released
ATF Lumia WP8 TP v.9.80 Update!! 30 April 2013!!
br
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.36376 seconds with 11 queries
