04-18-2014, 20:37 | #1 (permalink) |
Insane Poster Join Date: Feb 2010 Location: .:FUTURE:.
Member: 1243462 Status: Offline Sonork: 100.1667252 Thanks Meter: 38 | Nokia E7 Can't Repair Simlock Data. ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-626 (c) Nokia IMEI Plain : 357909043220681 IMEI Spare : A357909043220680 IMEI SV : 33579090432206845F Phone Model: Nokia E7-00 Category : Classic Phone Phone Type : RM-626 ================================================ Super Dongle RPL Stand Alone Edition ================================================ Generating Super Dongle RPL... Sending Superdongle RPL... OK: Super Dongle RPL Accepted Successfully done. Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-626 (c) Nokia IMEI Plain : 357909043220681 IMEI Spare : A357909043220680 IMEI SV : 33579090432206845F Phone Model: Nokia E7-00 Category : Classic Phone Phone Type : RM-626 ================================================ SL1/SL2 Simlock RPL Stand Alone Edition ================================================ Generating Simlock Data RPL... ERROR: Wrong Simlock RPL data Last edited by ragznarok; 04-18-2014 at 20:46. |
04-18-2014, 20:55 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | It is SL3 based phone, you can't repair simlock in it via repair simlock button that is intended for SL1/SL2 phones. Write PM120 backup if you have it... |
04-18-2014, 21:04 | #3 (permalink) |
Member: 1243462 Status: Offline Sonork: 100.1667252 Thanks Meter: 38 | the problem of the phone before is phone LOCK.. so i flashed it directly with new firmware. after that the phone stock on Dot dot .... loading Process cant access to menu. in that situation after i flashed the phone it will automaticaly back up the pm120?? where i can find it in atf folder... |
04-18-2014, 21:12 | #4 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | ATF backups Simlock and Rpl before flashing If you only flash it and did not erase phone the you no need to repair simlock. Dots Dots Problem is CMLA Key damaged. First Authorise Phone via ATF Network then Repair CMLA Key |
04-18-2014, 21:50 | #5 (permalink) |
Member: 1243462 Status: Offline Sonork: 100.1667252 Thanks Meter: 38 | i erase the phone sir Angel. and thats my problem i cant find the pm120 in atf folder back up. only pm i see there.. CMLA key is Ok. what should i do for this error sir Angel. By the way thx for the reply. |
