04-13-2016, 02:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Where i Want
Member: 1699006 Status: Offline Thanks Meter: 179 | Nokia Lumia 520 Error: Unable to find bootable option ... STRANGE 2x Lumia with same problem - Unable to find bootable option ... 1st Flash with JTAG - OK Flashed with ATF - set 100% 2nd Flash with JTAG - OK but still Unable to find bootable option ... I didnt post logs because as i say 1st recovered in easy way so there is no mistake from mine side. Both are Samsung emmc. If need log i will post |
04-14-2016, 20:10 | #2 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: UFI#Wellcome Worlwide UFiXers
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Quote:
- Use direct emmc, scan emmc, you should see write protection enable -now backup 512mb user partition and ext csd -upgrade emmc firmware -restore your backup flash firmware.. Gud luck | |
The Following 3 Users Say Thank You to madgoeslim For This Useful Post: |
04-22-2016, 11:30 | #3 (permalink) | |
Member: 1699006 Status: Offline Thanks Meter: 179 | Quote:
Using TP From Software IS Connection is same ? or there is another connection way ? If yes Please Describe , Thanks | |
