10-30-2014, 01:25 | #1 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1085379 Status: Offline Thanks Meter: 65 | Nokia Lumia 520 Error: Unable to find bootable option when switching on Try ffu flasher via jtag update the os also (same product code) Still cant flash the device error occurred as flash file mismatch (same product code) Any advice to fix the issue |
The Following User Says Thank You to coolmfarshard For This Useful Post: |
10-30-2014, 07:13 | #3 (permalink) |
Member: 1085379 Status: Offline Thanks Meter: 65 | Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/4/2014 5:07:00 PM ================================================== ======== Phone Type : Lumia 520 RM-914 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Boot Package: 3056.40000.1408.0007 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/31/2013 12:22:00 PM ================================================== ======== Phone Type : Nokia WP8 CPU Type : Qualcomm MSM8960 / MSM8930 / MSM8227 Storage TYpe: eMMC ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Use RESET JTAG button to check the JTAG Connection 6. Click READ INFO button to Start Reading Phone Info ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...CPSR Write Failed! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/4/2014 5:07:00 PM ================================================== ======== Phone Type : Lumia 520 RM-914 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Boot Package: 3056.40000.1408.0007 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3240 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...User break! Loading AFP (Please Wait)...OK AFP revision 4, compiled 4/8/2014 2:50:00 PM ================================================== ======== CPU Type Supported : ALL LUMIA WIN8 Except Snapdragon 800 Storage TYpe : eMMC ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type 6. Use RESET JTAG button to check the JTAG Connection 7. Click CUSTOM R/W to Start Read or Write Operations ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5954 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000973000...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...Flash Write Error at 0x09B48000, DCC Read Error, Timeout During Operation! Task Process Saved to: LUMIA_WIN8_CUSTOM_READ_WRITE.task Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5954 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...Skipped! Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...Skipped! Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...Skipped! Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...Skipped! Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...Skipped! Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...Skipped! Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...Skipped! Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...Skipped! Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000973000...Skipped! Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...OK Completed in 0h 3m 19s. Code Download Speed 309 KiB/sec. Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5954 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "MainOS" area, flash #1, p#0, 0x000E000000, 0x0055350000...User break! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Turbo JTAG Frequency 30.00 MHz! Sending Flash Loader...OK (5954 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "MainOS" area, flash #1, p#0, 0x000E000000, 0x0055350000...Flash Write Error at 0x13500000, DCC Read Error, USB I/O Error, Code 0x00000004 Task Process Saved to: LUMIA_WIN8_CUSTOM_READ_WRITE.task JTAG Interface Disconnected! JTAG Interface Connected, S/N 0x93761E50 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 JTAG Interface Disconnected! JTAG Interface Connected, S/N 0x93761E50 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x93761E50 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x207D00E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 4/8/2014 2:50:00 PM ================================================== ======== CPU Type Supported : ALL LUMIA WIN8 Except Snapdragon 800 Storage TYpe : eMMC ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type 6. Use RESET JTAG button to check the JTAG Connection 7. Click CUSTOM R/W to Start Read or Write Operations ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5953 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...Skipped! Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...Skipped! Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...Skipped! Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...Skipped! Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...Skipped! Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...Skipped! Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...Skipped! Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...Skipped! Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000973000...Skipped! Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...Skipped! Completed in 0h 0m 0s. Code Download Speed 0 KiB/sec. Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5953 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "MainOS" area, flash #1, p#0, 0x000E000000, 0x0055350000...Flash Write Error at 0x1E4CC000, DCC Read Error, Timeout During Operation! Task Process Saved to: LUMIA_WIN8_CUSTOM_READ_WRITE.task Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5954 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...Skipped! Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...Skipped! Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...Skipped! Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...Skipped! Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...Skipped! Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...Skipped! Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...Skipped! Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x0000264000...Skipped! Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000973000...Skipped! Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004BC8000...Skipped! Completed in 0h 0m 0s. Code Download Speed 0 KiB/sec. Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001A435BCE6044 Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1A435BCE, Jun 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5953 Op/Sec) FFU File Loaded: RM914_3058.50000.1425.0001_RETAIL_apac_singapore_2 41_01_444540_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0x0CC6233F Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "MainOS" area, flash #1, p#0, 0x000E000000, 0x0055350000...OK Completed in 1h 13m 39s. Code Download Speed 315 KiB/sec. |
10-30-2014, 07:30 | #4 (permalink) |
No Life Poster Join Date: Sep 2014 Location: Technology town
Member: 2252481 Status: Offline Sonork: 1660352 Thanks Meter: 206 | if does not work try atfplus and bigboot repair emmc i done several look at my profile |
The Following 2 Users Say Thank You to Techsky For This Useful Post: |
10-30-2014, 16:20 | #6 (permalink) | ||
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Quote:
and i've tried repair with Riff but after process done still same problem .. now i went to ATF to flash BIG BOOT via EMMC TP .. and i'm using ATF 4 IN 1 ADAPTOR .. but can't connect .. Quote:
and i've checked my soldered wires many times .. and i can confirm nothing wrong with it .. could you pls Mr.Techsky help me as you've done it before .. ?? thx in advance. Last edited by MiRoOo; 10-30-2014 at 16:27. | ||
10-31-2014, 07:59 | #7 (permalink) |
Member: 2252481 Status: Offline Sonork: 1660352 Thanks Meter: 206 | Make sure ur not using batt and resolder 4wire correctly .....in setup cpu type check it select qualcom halt.......and plug usb cable |
11-04-2014, 23:55 | #8 (permalink) |
No Life Poster Join Date: May 2000 Location: Bacau, Romania Age: 50
Member: 1447 Status: Offline Thanks Meter: 97 | Yep..confirmed..one 520 with same condition..FFU flasher and boot repair dont solve .. TNX, Cris WAIT another solution, or is motherboard damage? |
11-05-2014, 00:02 | #9 (permalink) | |
I tried everything with that phone .. 1- Riff boot repair .. Done but same problem. 2-EasyJTAG boot repair .. Done but same problem. 3-ATF eMMC Direct Connection for BIG BOOT File .. Failed to connect. So, i gave it back to the customer .. Hope someone can find a solution for this problem and share it with us. Sent from my iPhone 4S using Tapatalk. | |
