12-17-2014, 11:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: colombo
Member: 1418524 Status: Offline Thanks Meter: 186 | Nokia Lumia 520 Error: Unable to find bootable option when switching on Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x94265DB0 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/3/2014 2:26:00 PM ================================================== ======== Phone Type : Lumia 520, 520T, 525, 526 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Procedure : WP8 FFU Flasher via JTAG More Info : http://www.advance-box.com/ffu_flasher/ ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...Timeout During Operation! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943008A04ECA2500C Flash Description: Samsung M8G2YC, 7.28 GiB, SN 8A04ECA2, May 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943008A04ECA2500C Flash Description: Samsung M8G2YC, 7.28 GiB, SN 8A04ECA2, May 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943008A04ECA2500C Flash Description: Samsung M8G2YC, 7.28 GiB, SN 8A04ECA2, May 1997 Flash Write Protection: PERM Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5953 Op/Sec) FFU File Loaded: RM941_3058.50000.1424.0001_RETAIL_apac_laos_thaila nd_272_01_442058_prd_signed.ffu FFU File CRC-32: Computing, Please wait...0xFBA4A199 Analyzing FFU, please wait...OK Restoring MBR Data...OK Restoring GPT Data from Backup...OK Writing "SBL1" area, flash #1, p#0, 0x0001000000, 0x0000180000...OK Writing "SBL2" area, flash #1, p#0, 0x0001200000, 0x0000180000...OK Writing "SBL3" area, flash #1, p#0, 0x0001400000, 0x0000200000...OK Writing "UEFI" area, flash #1, p#0, 0x0001600000, 0x0000200000...OK Writing "RPM" area, flash #1, p#0, 0x0001A00000, 0x0000080000...OK Writing "TZ" area, flash #1, p#0, 0x0001C00000, 0x0000080000...OK Writing "WINSECAPP" area, flash #1, p#0, 0x0001E00000, 0x0000080000...OK Writing "PLAT" area, flash #1, p#0, 0x0003400000, 0x000027D000...OK Writing "EFIESP" area, flash #1, p#0, 0x0004000000, 0x0000972400...OK Writing "MMOS" area, flash #1, p#0, 0x0008C00000, 0x0004EA8000...OK Completed in 0h 4m 58s. Code Download Speed 339 KiB/sec. |
The Following User Says Thank You to gsaara For This Useful Post: |
12-17-2014, 12:00 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gsaara This is some bug made by Nokia/Microsoft when upgrading Lumia 520 to Windows 8.1... As you can see in your logs: Flash Write Protection: PERM This means your eMMC is permanently WRITE-PROTECTED and has become "READ ONLY"... Henceforth, no amount of Flashing/JTAG will repair it because it cannot be written any new data to the eMMC. Only solution is to backup IMEI/Simlocks/Tuning and replace eMMC with new one. B.R. |
12-17-2014, 12:25 | #3 (permalink) | |
Member: 1418524 Status: Offline Thanks Meter: 186 | Quote:
LUMIA_520_RM-914_BIG_BOOT[www.atfsupport.com].mmc | |
