07-11-2014, 12:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1281173 Status: Offline Thanks Meter: 4 | nokia lumia 520 flasher fair help mi pl. 11:57:27 : Flash File Checksum Verification 11:57:27 : ================================================== ==== 11:57:42 : RM914_3056.40000.1349.2004_RETAIL_eu_spain_360_04_ 369817_prd_signed.ffu: CHECKSUM PASSED 11:57:42 : ================================================== ==== 11:57:42 : Verification Done... 11:57:47 : Windows Phone 8 Flashing Started 11:57:47 : Loading Flash Files Please Wait... 11:57:48 : 11:57:48 : ================================================== ==== 11:57:48 : Windows Phone 8 Lumia Flasher 11:57:48 : ================================================== ==== 11:57:48 : 11:57:48 : If the Phone is ALIVE 11:57:48 : 1. Power On the Phone and Connect it to the USB Port 11:57:48 : 11:57:48 : If the Phone is DEAD 11:57:48 : 1. Connect Phone to the USB Port 11:57:48 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 11:57:48 : 3. Wait until the Phone Vibrates Shortly... 11:57:48 : 4. Stop Pressing the Buttons... 11:57:48 : ================================================== ==== 11:57:48 : 11:58:10 : IMEI: 359xxxxxxxxxxxx 11:58:10 : Version: 1.1.1.3 11:58:10 : Product Code: 059V251 11:58:10 : Module Code: 0205435 11:58:11 : 11:58:11 : Boot Flash Mode Successful... 11:58:11 : 11:58:11 : Phone Info Query Start... 11:58:11 : Blocks Returned: 0x07 Blocks 11:58:11 : Block ID 0x01 :00241000 11:58:11 : Block ID 0x02 :00240000 11:58:11 : Block ID 0x03 :00E90000 11:58:11 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 11:58:11 : Block ID 0x0D :0001 11:58:11 : Block ID 0x0F :0301010100000101FF 11:58:11 : Block ID 0x10 :0100130000 11:58:11 : Checking SD Card Size... 11:58:11 : Card Size: 0x00000000 11:58:11 : Checking Platform Security Status... 11:58:11 : Platform Secure Boot Status: Active 11:58:11 : Secure FFU EFUSE Status: Active 11:58:11 : Debug Status: Active 11:58:11 : RDC Status: Not Active 11:58:11 : Authentication Status: Not Active 11:58:11 : UEFI Secure Boot Status: Active 11:58:11 : Checking Secure FFU Mode... 11:58:11 : Secure FFU Mode : 11:58:11 : Query Flash App Information... 11:58:11 : Flash App Information: 02010F011C00 11:58:11 : UEFI App: FLASH APP 11:58:11 : Flash App Protocol Version: 1.15 11:58:11 : Flash App Implementation Version: 1.28 11:58:11 : Query ROOT KEY HASH... 11:58:11 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD 11:58:11 : 11:58:11 : Sending Image Signatures... 11:58:12 : Image Signatures Accepted! 11:58:12 : Erasing Data Partition... 11:58:13 : Data Partition Erased Successfully 11:58:13 : Preparing Buffers for DATA LOOP... 11:58:13 : Allocating System RAM OK! 11:58:13 : Start Sending DATA BLOCKS... 11:58:17 : ERROR: LAST DATA BLOCK REJECTED! 11:58:17 : Check your Flash File and Phone Connection 11:58:17 : ERROR: Flashing Failed! |
07-11-2014, 13:33 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Not mention the phone condition ... I mean was was the condition B4 flash ? 1 - May phone disconnect during flashing . 2 - Check Battery , use 70% or higher charged battery . Br - srinibas |
07-11-2014, 16:56 | #5 (permalink) |
Member: 1281173 Status: Offline Thanks Meter: 4 | Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== ================================================== ==== ERROR: Flashing Failed! Last edited by fjyong; 07-11-2014 at 16:57. Reason: HS-USB Diagnostics 9008 com26 |
07-11-2014, 23:13 | #9 (permalink) |
Member: 1281173 Status: Offline Thanks Meter: 4 | Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
