05-18-2014, 13:34 | #31 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1554988 Status: Offline Thanks Meter: 0 | Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! JTAG Interface Disconnected! JTAG Interface USB I/O Error, Code 0x00000004 JTAG Interface Disconnected! JTAG Interface Connected, Resetting and Exploring JTAG chain...No Devices found in Chain! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 32808194 ACTIVE Level 1 PUK: 29822164 ACTIVE Level 2 PIN: 48187706 Level 2 PUK: 15333317 Level 3 PIN: 47592715 Level 3 PUK: 73712105 Level 4 PIN: 01367529 Level 4 PUK: 10827481 Level 5 PIN: 56760994 Level 5 PUK: 51960054 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== |
06-14-2014, 22:30 | #33 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
From JTAG, click in PHONE then select model and show Immage of Jtag and which are wires from any RJ45 cable, i think have cleared this to you. Br allumts | |
06-20-2014, 11:43 | #34 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | nokia lumia 610 rm-835 Retrieving Unlock Codes...Unknown EFS2 Format Detected. Service Provider Codes Not Found cable length ok i made other 3 pcs also phone power on wait 1min after closed by button and same error |
06-20-2014, 13:24 | #35 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | [QUOTE=IM8;10387299]nokia lumia 610 rm-835 Retrieving Unlock Codes...Unknown EFS2 Format Detected. Service Provider Codes Not Found 1. Put battery on phone and power it up Until WP7 menu GUI. 2. After GUI of WP7 OS is fully loaded, properly shut down phone power button and swipe down screen. 3. Read codes again via jtag. *** in case the phone is not properly shutdown, then you will get invalid EFS2 error. Br allumts |
06-20-2014, 17:50 | #36 (permalink) | |
Member: 694535 Status: Offline Thanks Meter: 70 | i tryed also tu full turn on and off phone other solution ? [QUOTE=allumts;10387525] Quote:
06-21-2014, 09:19 | #37 (permalink) |
Freak Poster Join Date: May 2014 Location: baia mare romania Age: 40
Member: 2195859 Status: Offline Thanks Meter: 19 | [QUOTE=IM8;10388012]i tryed also tu full turn on and off phone other solution ? same here , any logs or screenshot will help team debug this problem? i have tried 2 diferent versions , and still same efs2 error |
06-27-2014, 10:50 | #40 (permalink) |
No Life Poster Join Date: Sep 2004 Location: POLAND Age: 43
Member: 82759 Status: Offline Thanks Meter: 153 | My first phone unlocked ATF - new box Nitro Code: Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 31166095 ACTIVE Level 1 PUK: 10413160 ACTIVE Level 2 PIN: 40409049 Level 2 PUK: 87869817 Level 3 PIN: 18386619 Level 3 PUK: 79749276 Level 4 PIN: 73864439 Level 4 PUK: 50722246 Level 5 PIN: 25349809 Level 5 PUK: 94046537 =================================== Reading Unlock Codes Done! |
06-28-2014, 11:37 | #41 (permalink) |
Member: 694535 Status: Offline Thanks Meter: 70 | another probelm with lumia 610 unlock code read ok. but when insert not supported sim card it says no service the sim card it's missing or invalid but it doesnt ask for any cod . how to insert code for unlock ? |
07-21-2014, 15:20 | #44 (permalink) |
Insane Poster Join Date: Apr 2012
Member: 1743497 Status: Offline Thanks Meter: 7 | help help please hi sir i have one 100 old Nokia fbus cables i cant found like your one green color on the corner can u tell me which model phone cable u used it or which which Nokia phone cable we can used to unlock it please thank u |
