07-21-2014, 21:29 | #47 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | |
07-22-2014, 11:05 | #48 (permalink) |
Insane Poster Join Date: Apr 2011 Location: Romania
Member: 1555576 Status: Offline Thanks Meter: 11 | i select 610_610C_510_505_ALL_LEVELS_UNLOCK_V2.afp and after that my lumia 610 restart continuously after unlock (restore boot with that file). phone power on fully and after 30 seconds it's restarting... |
07-22-2014, 17:51 | #49 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Had used wrong file afp, if have used old Jtag vers. and Build, had to select LUMIA_610_610C_UNLOCK.afp, now use new update how write above, Br allumts | |
07-24-2014, 10:22 | #50 (permalink) | |
Member: 1555576 Status: Offline Thanks Meter: 11 | Quote:
07-24-2014, 11:13 | #51 (permalink) |
Member: 1555576 Status: Offline Thanks Meter: 11 | I do repair boot, still the same Code: eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : FE014E4D4D4330384731E42C07A4 CSD : D04F01320F5913FFFFFFFFEF8A4000BF eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 128 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: FE Device Type : Embedded BGA Application ID : 4E Product Name : MMC08G Product Rev : 3.1 Product SN : E42C07A4 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: FE014E4D4D4330384731E42C07A4_62FE1D18.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR... Write Success! Writing DBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:00:16 |
07-31-2014, 22:20 | #52 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1880169 Status: Offline Thanks Meter: 2 | Hello.. ive done more than 15 nokias lumia 610. this phone I just did asked me for the pin code. I inserted it. pin accepted.. reboots.. and shows me the new company for 2 sec and goes to no service... reboot and shows on top left the no valid sim card icon. but doent ask me for the pin code anymore.. under settings 3g data. says sim not valid.. any idea whats going on ? thanks |
08-13-2014, 09:18 | #54 (permalink) |
Freak Poster Join Date: Sep 2007 Location: laguna
Member: 580947 Status: Offline Thanks Meter: 7 | please help me brother i tried also to unlock but i goes only here im unlocking lumia610.. usb connected waiting for first event... timeout during operation.. i just want to make it clear on pinout am i right that i need to solder only is for pin of 3-8pins fron rj45.. please reply.. ty |
08-13-2014, 11:02 | #55 (permalink) | |
If you want use TP, loock good in ATF folder--->Lumia TP PIC. Br | |
08-13-2014, 11:22 | #56 (permalink) | |
Insane Poster Join Date: Dec 2006 Location: romania
Member: 407773 Status: Offline Thanks Meter: 22 | Quote:
Just use 610_610C_510_505_UNLOCK_V3.afp. Solder jtag , put battery in phone and fully power on. Then hit read codes. All done. | |
08-14-2014, 10:38 | #57 (permalink) | |
FOR ALL, Here all Steps: http://forum.gsmhosting.com/vbb/10424476-post6.html Br allumts | |
