11-19-2015, 16:50 | #1 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia Lumia 620 Network Show But Not Work Hello There ... Here I Got a Lumia 620 with network not work.But Network shown with sim card.. Doing Flash with same Product code Firmware[Latest].. After Flash Done I Put Sim & make call again .. its work just 1 time .. After call end when again make any call ..again its not work .. Also come some touch problem like dial pad not work some time .. If I Do again Flash again work Call for 1 time .. Check out Flash logs or screen shot .. Code: Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ====================================================== Windows Phone 8/8.1/10 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ====================================================== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Version: 1.1.1.3 Product Code: 059R5S6 Module Code: 0205404 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467E31DAA963D1467 Query PUBLIC ID... PUBLIC_ID: 11D7B23FCE4F062F38DEFBE020EEBC6093FB9749 Query eMMC Info... EMMC Manufacture ID: TOSHIBA EMMC Product SN : DD536A57 EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 71% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:42 Waiting for Support for this issue .. Best Regard' AniAXN |
11-20-2015, 05:54 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | After flash it works for one time ( out-going ) 2nd call not possible ,As you mention . Now check these steps 1 - Flash the phone again & make a call after finish the call not try for 2nd call , just switch off the phone & keep 15 min , after 15 min switch on the phone & try to make a call ..... Report what happen . ( Either call will connect or not , If not then follow 2nd step ) 2 - Flash the phone & do a in coming call & after finish try to make a out going call , lets see what happening waiting for your reply Br - srinibas |
