03-11-2015, 15:58 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | Nokia Lumia 620 Unable to find bootable option "Unable to find bootable option press any key to shut down ". phone can't flash always error. can jtag fix this problem? |
03-11-2015, 16:17 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
So open phone and check eMMC if Samsung. Check this: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX\620_TP_HIRES.jpg eMMC is the one on the LEFT PCB with the Yellow Box. So if eMMC is in fact Samsung brand, then you need to solder wires to those eMMC TP Connection. Then perform this using ATF 12.00 or above: If Remove Write Protection is successful, then you can write BOOT via eMMC using this file: http://www.4shared.com/download/Zs1r....mmc?lgfp=3000 OR you can just flash phone via USB after removing all eMMC TP Wires. | |
10-13-2015, 10:25 | #4 (permalink) |
Junior Member Join Date: Oct 2015 Location: kerala
Member: 2466529 Status: Offline Thanks Meter: 0 | nokia Lumia 620 Unable to find bootable option i have Nokia Lumia 620 with Error: "Unable to find bootable option press any key to shut down ". phone can't flash always error. can jtag fix this problem? |
10-14-2015, 02:20 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
