12-12-2014, 13:00
#1 (permalink)
Member: 1517329
Sonork: 100.1647599 Thanks Meter: 263 | Nokia Lumia 625 RM-941 HS-USB QDLOADER 9008 Device: Lumia 625
Condition Dead..When connected to usb cable shows as HS-USB QDLOADER 9008
Repaired Boot with ATF Quote:
Default language ID 0x4009, LR 12
JTAG Interface Connected, S/N 0x89276F78
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 03-09-2014 15:31:00
Phone Type : Lumia 625
CPU Type : Qualcomm MSM8227
Storage Type: eMMC 8GB
Procedure : WP8 FFU Flasher via JTAG
More Info : http://www.advance-box.com/ffu_flasher/
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
Waiting for Device Connection 15 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting eMMC #1 ID...1501003030303030305620110726589C
Flash Description: Samsung 000000, 8.00 GiB, SN 20110726, May 2005
Partition Config: No boot enabled, Boot ACK OFF (0x00)
Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00)
Testing Device Memory...OK
Sending Flash Loader...OK (5989 Op/Sec)
FFU File Loaded: RM941_3058.50000.1424.0003_RETAIL_im_india_204_03_ 453683_prd_signed.ffu
FFU File CRC-32: Computing, Please wait...0xE3C045F9
FFU File CRC-32: CRC32 Check Failed!
AFP revision 4, compiled 25-06-2014 23:03:00
Phone Type : Lumia 625 RM-941
CPU Type : Qualcomm MSM8930
Boot Package: 3056.40000.1402.1005 (BIG BOOT)
Restore Boot...
Halting Core...OK
Sending Flash Loader...OK (5987 Op/Sec)
Restoring MBR Data...OK
Restoring GPT Data from AFP...OK
Restoring Partition #1...OK
Restoring Partition #2...OK
Restoring Partition #3...OK
Restoring Partition #4...OK
Restoring Partition #5...OK
Restoring Partition #6...OK
Restoring Partition #7...OK
Restoring Partition #8...OK
Restoring Partition #9...OK
Restoring Partition #10...OK
Completed in 0h 9m 20s. Code Download Speed 314 KiB/sec.
Boot Restore Done!
Assemble Phone and Start Normally
If Phone cannot Start, perform USB Firmware Update Procedure
================================================== =========== | Boot repair success..but still detected as HS-USB QDLOADER 9008 |
