09-09-2015, 01:06 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | nokia lumia 800 flashing error Windows Phone Flashing Started OSBL File Found: RM801_12w22_prod_generic_nokia_osbl.esco AMSS File Found: RM801_12w22_prod_generic_amss.esco ADSP File Found: RM801_12w22_prod_generic_adsp.esco WPOS File Found: RM801_12220_prod_490_01_boot.esco USER AREA ERASE File Found: RM801_12w22_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
09-10-2015, 21:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | You can repair lumia 800 with ATF using Test Point. But if the phone is taking NokiaConnectivityDriver than is not dead boot. Log says, boot is alive. But keystore is damaged. Unfortunately, ATF doesn't support damaged keystore repair for lumia wp7 phones. |
09-11-2015, 22:04 | #3 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | Indeed, I have succesfully managed to repair boot via TP but phone still dead...phone was alive before flashing it with Best...there is any tool ,or method that can repair damaged keystore on this phone? |
09-11-2015, 22:12 | #4 (permalink) | |
Member: 148032 Status: Offline Thanks Meter: 415 | Quote:
This coud not help me? | |
09-16-2015, 16:37 | #5 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
