04-25-2014, 16:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: BHIMAVARAM Age: 36
Member: 900602 Status: Offline Thanks Meter: 99 | Nokia Lumia 800 Hard Reset Done ATF 27 Sec Nokia Lumia 800 Hard Reset Done ATF 25 Sec Hard Reset Try Not Work ? Try ATf RM-801 File |
The Following 9 Users Say Thank You to ..::BobbyMobiles::.. For This Useful Post: |
04-25-2014, 18:53 | #2 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Hard reset lumia - no box Quote:
Here Guide for all Lumia Factory OS HARD RESET Windows Phone 7.x This method applies to Nokia Lumia 900, Lumia 800, Lumia 710 and Lumia 610. For this type of reset will have two steps. We started with the phone off and keep pressed both volume buttons down the camera and finally the on / off . After a few seconds the phone vibrates. At that moment the phone to vibrate , will loose button on / off and keep down the other two ( volume down and camera) about five seconds. The phone should boot back to the factory settings. HARD RESET WINDOWS 8 This method applies to the Nokia Lumia 920, Lumia 820, Lumia 720, Lumia 620, Lumia 520 models and thus to have Windows Phone 8 , the method varies , and will be next. : Phone off for at least 20 seconds . The charger must be disconnected. Press the volume down while you connect the charger. Within seconds an exclamation will appear on the screen . (If your phone has enough battery , can turn on the terminal with the power button , instead of connecting the charger ) . In this state , press the following keys in order: Volume up + Volume Down - Power Volume Down - After the phone button sequence should start erasing and restoring to factory settings. Contributions of kfelabs ciao auto | |
The Following 2 Users Say Thank You to Automatico For This Useful Post: |
06-21-2014, 19:42 | #8 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Automatico, this is not a competition to see who is the most good. On the forum you helps and share you experiences, but on many threads and posts you make only the "first woman". You're just one of the many millions of users, HERE Br |
06-21-2014, 23:09 | #9 (permalink) | |
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Quote:
br auto | |
10-16-2015, 10:04 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @jasur09, But what post here?, this is Atf Section not "Nokia Generic Section", so please Not post more here you experience with a tool "C****K", are out of all rules. |
