02-01-2013, 08:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: only unlock punjab india
Member: 1745576 Status: Offline Thanks Meter: 12 | nokia lumia 800 unlock paroblam plz tel me solution but after unlock this sim can onlybe used on speciffic network . contact your customr service center for the pac code. any solution plz Code: 11:29:56 : ================================================ 11:29:56 : Advance Turbo Flasher Found 11:29:56 : ================================================ 11:29:56 : Driver Version : 00020824 11:29:56 : Library Version : 00030207 11:29:58 : Box Type : AdvanceBox Turbo 11:29:58 : Box Firmware : LogiCore 10.3.30 11:29:58 : Software Version : v9.50 11:29:58 : AdvanceBox SN : ************ 11:29:58 : Box Status : ACTIVATED 11:29:58 : ================================================ 11:29:58 : Box Successfully Initialized 11:29:58 : ================================================ 11:29:58 : 11:29:58 : VBATT Powering Down <<<< 11:30:02 : VBATT Powering Up >>>> 11:30:02 : SET VCCIO Level Done 11:30:02 : SET BSI Load Done 11:30:02 : 11:30:02 : 11:30:02 : 11:30:02 : ///////// /// /// /////// /////// ///////// 11:30:02 : /// /// /// /// // /// /// /// /// 11:30:02 : /// /// /// /////// /////// /// /// 11:30:02 : /// /// /// /// /// /// /// /// /// 11:30:02 : /// ///// /// /// /////// ////// 11:30:02 : 11:30:02 : ======================================= 11:30:02 : /// /// /// ///////// /////// ////// 11:30:02 : ///// /// /// /// /// // /// /// 11:30:02 : /// ///// /// /// /////// /// /// 11:30:02 : /// //// /// /// /// /// /// /// 11:30:02 : /// /// /// /// /// /// ////// 11:30:02 : ======================================= 11:30:02 : 11:30:42 : ====================================================== 11:30:42 : ====================================================== 11:30:42 : Lumia Test Point Connection Module 11:30:42 : ====================================================== 11:30:42 : ====================================================== 11:30:42 : 11:30:42 : 1. DO NOT USE THE PHONE"S BATTERY 11:30:42 : 2. Connect the Soldered TP Connections to ATF Box 11:30:42 : 3. Disconnect the USB Cable and Wait until the 11:30:42 : the ATF Software will tell you to Connect the USB. 11:30:42 : 11:30:44 : 11:30:44 : Interface Reset OK! 11:30:44 : Reading Platform Information... 11:30:44 : Selecting Active Handle... 11:30:44 : Select Handle OK! 11:30:45 : Sending Ping... 11:30:45 : Ping Reply OK! 11:30:45 : 11:30:45 : Lumia 800/800C Detected 11:30:45 : 11:30:45 : Storage Device Information 11:30:45 : Manufacturer ID: 80 11:30:45 : Application ID : 0000 11:30:45 : Product Name : 11:30:45 : Product Rev : 0C 11:30:45 : Product SN : 00080139 11:30:45 : 11:30:45 : Protection Information 11:30:45 : Write Protect A: OFF 11:30:45 : Write Protect B: OFF 11:30:45 : 11:30:50 : ====================================================== 11:30:50 : ====================================================== 11:30:50 : Lumia Test Point Connection Module 11:30:50 : ====================================================== 11:30:50 : ====================================================== 11:30:50 : 11:30:50 : 1. DO NOT USE THE PHONE"S BATTERY 11:30:50 : 2. Connect the Soldered TP Connections to ATF Box 11:30:50 : 3. Disconnect the USB Cable and Wait until the 11:30:50 : the ATF Software will tell you to Connect the USB. 11:30:50 : 11:30:52 : 11:30:52 : Interface Reset OK! 11:30:52 : Reading Platform Information... 11:30:52 : Selecting Active Handle... 11:30:52 : Select Handle OK! 11:30:52 : Sending Ping... 11:30:52 : Ping Reply OK! 11:30:52 : 11:30:52 : Lumia 800/800C Detected 11:30:52 : 11:30:52 : Storage Device Information 11:30:52 : Manufacturer ID: 80 11:30:52 : Application ID : 0000 11:30:52 : Product Name : 11:30:52 : Product Rev : 0C 11:30:52 : Product SN : 00080139 11:30:52 : 11:30:52 : Protection Information 11:30:52 : Write Protect A: OFF 11:30:52 : Write Protect B: OFF 11:30:52 : 11:30:52 : 11:30:52 : Dumping AMSS FAT16 Region 11:30:52 : Please wait for 2-4 Minutes... 11:35:22 : Patch Bit Found... 11:35:22 : Total Patch Bits Found: 1 11:35:22 : Patching AMSS... 11:39:00 : Patch OK! 11:39:00 : 11:39:00 : SP Unlock Done! 11:39:00 : 11:39:00 : PIN: 00000000 11:39:00 : PUK: 0000000000 11:39:00 : 11:39:00 : Total Elapsed Time 00:08:10 11:39:10 : 11:39:10 : 11:39:10 : Scanning USB Ports... 11:39:16 : Operation Cancelled... 11:39:18 : ====================================================== 11:39:18 : ====================================================== 11:39:18 : Lumia Test Point Connection Module 11:39:18 : ====================================================== 11:39:18 : ====================================================== 11:39:18 : 11:39:18 : 1. DO NOT USE THE PHONE"S BATTERY 11:39:18 : 2. Connect the Soldered TP Connections to ATF Box 11:39:18 : 3. Disconnect the USB Cable and Wait until the 11:39:18 : the ATF Software will tell you to Connect the USB. 11:39:18 : 11:39:20 : 11:39:20 : Interface Reset OK! 11:39:20 : Reading Platform Information... 11:39:20 : Selecting Active Handle... 11:39:20 : Select Handle OK! 11:39:20 : Sending Ping... 11:39:20 : Ping Reply OK! 11:39:20 : 11:39:20 : Lumia 800/800C Detected 11:39:20 : 11:39:20 : Storage Device Information 11:39:20 : Manufacturer ID: 80 11:39:20 : Application ID : 0000 11:39:20 : Product Name : 11:39:20 : Product Rev : 0C 11:39:20 : Product SN : 00080139 11:39:20 : 11:39:20 : Protection Information 11:39:20 : Write Protect A: OFF 11:39:20 : Write Protect B: OFF 11:39:20 : 11:39:24 : ====================================================== 11:39:24 : ====================================================== 11:39:24 : Lumia Test Point Connection Module 11:39:24 : ====================================================== 11:39:24 : ====================================================== 11:39:24 : 11:39:24 : 1. DO NOT USE THE PHONE"S BATTERY 11:39:24 : 2. Connect the Soldered TP Connections to ATF Box 11:39:24 : 3. Disconnect the USB Cable and Wait until the 11:39:24 : the ATF Software will tell you to Connect the USB. 11:39:24 : 11:39:27 : 11:39:27 : Interface Reset OK! 11:39:27 : Reading Platform Information... 11:39:27 : Selecting Active Handle... 11:39:27 : Select Handle OK! 11:39:27 : Sending Ping... 11:39:27 : Ping Reply OK! 11:39:27 : 11:39:27 : Lumia 800/800C Detected 11:39:27 : 11:39:27 : Storage Device Information 11:39:27 : Manufacturer ID: 80 11:39:27 : Application ID : 0000 11:39:27 : Product Name : 11:39:27 : Product Rev : 0C 11:39:27 : Product SN : 00080139 11:39:27 : 11:39:27 : Protection Information 11:39:27 : Write Protect A: OFF 11:39:27 : Write Protect B: OFF 11:39:27 : 11:39:27 : 11:39:27 : Dumping AMSS FAT16 Region 11:39:27 : Please wait for 2-4 Minutes... 11:43:56 : 11:43:56 : WARNING: Patch Bit NOT FOUND! 11:43:56 : Maybe Phone is already UNLOCKED! 11:43:56 : 11:43:56 : Total Elapsed Time 00:04:31 11:44:04 : Currently Not Supported for Windows Phone |
02-01-2013, 08:42 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Flash the phone , chose file as per product code & unlock again Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
02-01-2013, 12:37 | #4 (permalink) | |
Member: 1745576 Status: Offline Thanks Meter: 12 | Quote:
Code: 16:12:43 : If the Phone is ALIVE 16:12:43 : 1. Power On the Phone and Connect it to the USB Port 16:12:43 : 16:12:43 : If the Phone is DEAD 16:12:43 : 1. Press and Hold the VOLUME UP button 16:12:43 : 2. Connect it to the USB Port while still Pressing 16:12:43 : the VOLUME UP button 16:12:43 : 3. Continue to Press the VOLUME UP button for 8 more 16:12:43 : seconds 16:12:43 : ====================================================== 16:12:43 : 16:13:13 : 16:13:13 : Sending OSBL Certificate 16:13:13 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:13:13 : Certificate Size: 452 Bytes 16:13:13 : Status : WRITE OSBL CERTIFICATE SUCCESS 16:13:13 : 16:13:13 : Sending OSBL Data Blocks 16:13:13 : [BLOCK 1 0x00000000~0x000E9627] 16:13:13 : Data Size: 0x000E9628 Bytes 16:13:13 : SHA-256 : F480E3ADA1FDD5E62C862B3A607EE0E9 16:13:13 : ---------- : FB3BA24290C63002E052A6EFD20C9C1D 16:13:14 : Status : OSBL WRITE SUCCESS 16:13:14 : 16:13:14 : Sending AMSS Certificate 16:13:14 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:13:14 : Certificate Size: 449 Bytes 16:13:15 : Status : WRITE AMSS CERTIFICATE SUCCESS 16:13:15 : 16:13:15 : Sending AMSS Data Blocks 16:13:17 : (Please Wait for 25 Seconds...) 16:13:41 : Status : AMSS WRITE SUCCESS 16:13:41 : 16:13:41 : Sending ADSP Certificate 16:13:41 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:13:41 : Certificate Size: 449 Bytes 16:13:41 : Status : WRITE ADSP CERTIFICATE SUCCESS 16:13:41 : 16:13:41 : Sending ADSP Data Blocks 16:13:42 : (Please Wait for 25 Seconds...) 16:13:49 : Status : ADSP WRITE SUCCESS 16:13:50 : 16:13:50 : Sending WPOS Certificate 16:13:51 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:13:51 : Certificate Size: 1604 Bytes 16:13:51 : Status : WRITE WPOS CERTIFICATE SUCCESS 16:13:51 : 16:13:51 : Sending WPOS Data Blocks 16:13:51 : [BLOCK 1 0x00000000~0x00FFFFFF] 16:13:51 : Data Size: 0x01000000 Bytes 16:13:51 : SHA-256 : 47160D45E844548F210F0A640C657729 16:13:51 : ---------- : 00DBE4A28978710369AA7DA8648AC215 16:13:55 : Status : WPOS WRITE FAILED 16:14:00 : 16:14:00 : ====================================================== 16:14:00 : Flash File Checksum Verification 16:14:00 : ====================================================== 16:14:00 : RM801_12w07_prod_generic_nokia_osbl.esco: CHECKSUM PASSED 16:14:00 : RM801_12w07_prod_generic_amss.esco: CHECKSUM PASSED 16:14:00 : RM801_12w07_prod_generic_adsp.esco: CHECKSUM PASSED 16:14:02 : RM801_12070_prod_210_08_boot.esco: CHECKSUM PASSED 16:14:02 : RM801_12w07_prod_generic_user_area_erase.esco: CHECKSUM PASSED 16:14:02 : ====================================================== 16:14:02 : Verification Done... 16:14:05 : Windows Phone Flashing Started 16:14:05 : 16:14:05 : OSBL File Found: 16:14:05 : RM801_12w07_prod_generic_nokia_osbl.esco 16:14:05 : AMSS File Found: 16:14:05 : RM801_12w07_prod_generic_amss.esco 16:14:05 : ADSP File Found: 16:14:05 : RM801_12w07_prod_generic_adsp.esco 16:14:07 : WPOS File Found: 16:14:07 : RM801_12070_prod_210_08_boot.esco 16:14:07 : USER AREA ERASE File Found: 16:14:07 : RM801_12w07_prod_generic_user_area_erase.esco 16:14:07 : 16:14:07 : ====================================================== 16:14:07 : Windows Phone Lumia Flasher 16:14:07 : ====================================================== 16:14:07 : 16:14:07 : If the Phone is ALIVE 16:14:07 : 1. Power On the Phone and Connect it to the USB Port 16:14:07 : 16:14:07 : If the Phone is DEAD 16:14:07 : 1. Press and Hold the VOLUME UP button 16:14:07 : 2. Connect it to the USB Port while still Pressing 16:14:07 : the VOLUME UP button 16:14:07 : 3. Continue to Press the VOLUME UP button for 8 more 16:14:07 : seconds 16:14:07 : ====================================================== 16:14:07 : 16:14:08 : 16:14:08 : Sending OSBL Certificate 16:14:08 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:14:08 : Certificate Size: 452 Bytes 16:14:09 : Status : WRITE OSBL CERTIFICATE SUCCESS 16:14:09 : 16:14:09 : Sending OSBL Data Blocks 16:14:09 : [BLOCK 1 0x00000000~0x000E9627] 16:14:09 : Data Size: 0x000E9628 Bytes 16:14:09 : SHA-256 : F480E3ADA1FDD5E62C862B3A607EE0E9 16:14:09 : ---------- : FB3BA24290C63002E052A6EFD20C9C1D 16:14:09 : Status : OSBL WRITE SUCCESS 16:14:09 : 16:14:09 : Sending AMSS Certificate 16:14:09 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:14:09 : Certificate Size: 449 Bytes 16:14:09 : Status : WRITE AMSS CERTIFICATE SUCCESS 16:14:09 : 16:14:09 : Sending AMSS Data Blocks 16:14:11 : (Please Wait for 25 Seconds...) 16:14:34 : Status : AMSS WRITE SUCCESS 16:14:34 : 16:14:34 : Sending ADSP Certificate 16:14:34 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:14:34 : Certificate Size: 449 Bytes 16:14:34 : Status : WRITE ADSP CERTIFICATE SUCCESS 16:14:34 : 16:14:34 : Sending ADSP Data Blocks 16:14:35 : (Please Wait for 25 Seconds...) 16:14:43 : Status : ADSP WRITE SUCCESS 16:14:44 : 16:14:44 : Sending WPOS Certificate 16:14:45 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:14:45 : Certificate Size: 1604 Bytes 16:14:45 : Status : WRITE WPOS CERTIFICATE SUCCESS 16:14:45 : 16:14:45 : Sending WPOS Data Blocks 16:14:45 : [BLOCK 1 0x00000000~0x00FFFFFF] 16:14:45 : Data Size: 0x01000000 Bytes 16:14:45 : SHA-256 : 47160D45E844548F210F0A640C657729 16:14:45 : ---------- : 00DBE4A28978710369AA7DA8648AC215 16:14:52 : Status : WPOS WRITE SUCCESS 16:14:52 : [BLOCK 2 0x01000000~0x016573FF] 16:14:52 : Data Size: 0x00657400 Bytes 16:14:52 : SHA-256 : 3434C223C6A2B3B4FA4469C5B4BEBC9D 16:14:52 : ---------- : 3A73E120C44D4358E0FCB512E2E41C74 16:14:55 : Status : WPOS WRITE SUCCESS 16:14:55 : [BLOCK 3 0x01697400~0x01FFFFFF] 16:14:55 : Data Size: 0x00968C00 Bytes 16:14:55 : SHA-256 : 113DFE5045F79E05FEB0FCFBDA097F95 16:14:55 : ---------- : 5347376CF4BD5910803BCD2544BE04CA 16:15:00 : Status : WPOS WRITE SUCCESS 16:15:00 : [BLOCK 4 0x02000000~0x02FFFFFF] 16:15:00 : Data Size: 0x01000000 Bytes 16:15:00 : SHA-256 : 380AF0CC6F3D830DAFE181BC83A6418B 16:15:00 : ---------- : 40543F8167A23E305839965FE4540496 16:15:07 : Status : WPOS WRITE SUCCESS 16:15:07 : [BLOCK 5 0x03000000~0x03FFFFFF] 16:15:07 : Data Size: 0x01000000 Bytes 16:15:07 : SHA-256 : 66636B9057A2F7F43A7D6E5C146E53EA 16:15:07 : ---------- : 48D661960B90D8174A98715D95FC6CF4 16:15:14 : Status : WPOS WRITE SUCCESS 16:15:14 : [BLOCK 6 0x04000000~0x04FFFFFF] 16:15:14 : Data Size: 0x01000000 Bytes 16:15:14 : SHA-256 : 87717C5582F152F9474ADD107CA184B7 16:15:14 : ---------- : 23BFC4F184777D56D59A9A811FF4A777 16:15:21 : Status : WPOS WRITE SUCCESS 16:15:21 : [BLOCK 7 0x05000000~0x05FFFFFF] 16:15:21 : Data Size: 0x01000000 Bytes 16:15:21 : SHA-256 : 4F2638CF151868844A04F283C1012CD7 16:15:21 : ---------- : E8EDE6C15D1323DB4C4117994564A036 16:15:28 : Status : WPOS WRITE SUCCESS 16:15:28 : [BLOCK 8 0x06000000~0x06FFFFFF] 16:15:28 : Data Size: 0x01000000 Bytes 16:15:28 : SHA-256 : E4E07C4CB2D014384C5CE7474C716D6C 16:15:28 : ---------- : 289F9F035CD195155ECC6F820521D0B5 16:15:35 : Status : WPOS WRITE SUCCESS 16:15:35 : [BLOCK 9 0x07000000~0x07FFFFFF] 16:15:35 : Data Size: 0x01000000 Bytes 16:15:35 : SHA-256 : 5CCCBDC461E71A148C77BD68DF1D4151 16:15:35 : ---------- : C005418F7272F4648CBBABCE8B4E2D20 16:15:42 : Status : WPOS WRITE SUCCESS 16:15:42 : [BLOCK 10 0x08000000~0x08FFFFFF] 16:15:42 : Data Size: 0x01000000 Bytes 16:15:42 : SHA-256 : 064E339847550571D61D78D312594BE3 16:15:42 : ---------- : 5377709D9F37EAA2B9822AC373692011 16:15:49 : Status : WPOS WRITE SUCCESS 16:15:49 : [BLOCK 11 0x09000000~0x09FFFFFF] 16:15:49 : Data Size: 0x01000000 Bytes 16:15:49 : SHA-256 : 3D411239BCB140C089EA1010880B7A91 16:15:49 : ---------- : 6FAB13C9031BC1470769362ABF956757 16:15:57 : Status : WPOS WRITE SUCCESS 16:15:57 : [BLOCK 12 0x0A000000~0x0AFFFFFF] 16:15:57 : Data Size: 0x01000000 Bytes 16:15:57 : SHA-256 : 6666BB36406321E2B75AA0164886496F 16:15:57 : ---------- : BF821348233C22D61A91F4B6D561F96A 16:16:04 : Status : WPOS WRITE SUCCESS 16:16:04 : [BLOCK 13 0x0B000000~0x0BFFFFFF] 16:16:04 : Data Size: 0x01000000 Bytes 16:16:04 : SHA-256 : B0D274BA2A5F88B7C5A9C58B567D830A 16:16:04 : ---------- : 80F351F8DB7A02431744AB53FAE83162 16:16:11 : Status : WPOS WRITE SUCCESS 16:16:11 : [BLOCK 14 0x0C000000~0x0CFFFFFF] 16:16:11 : Data Size: 0x01000000 Bytes 16:16:11 : SHA-256 : BBE7015E7AB8BBBC8E2183CB728A05B7 16:16:11 : ---------- : DCA005B80FE23199C7170A23DC861F61 16:16:19 : Status : WPOS WRITE SUCCESS 16:16:19 : [BLOCK 15 0x0D000000~0x0DFFFFFF] 16:16:19 : Data Size: 0x01000000 Bytes 16:16:19 : SHA-256 : FD187550A68C54DB9488CB8D6211A353 16:16:19 : ---------- : AF957D8F94DBCDFBDB968FC2C3918785 16:16:26 : Status : WPOS WRITE SUCCESS 16:16:26 : [BLOCK 16 0x0E000000~0x0EFFFFFF] 16:16:26 : Data Size: 0x01000000 Bytes 16:16:26 : SHA-256 : A0502F6889935C95F2116AF7F976965D 16:16:26 : ---------- : C3DE0CA36D4BECDD98AAFA846B668422 16:16:34 : Status : WPOS WRITE SUCCESS 16:16:34 : [BLOCK 17 0x0F000000~0x0FFFFFFF] 16:16:34 : Data Size: 0x01000000 Bytes 16:16:34 : SHA-256 : 82700E7BBFF6B09CAC1924C7F8E510E7 16:16:34 : ---------- : 86F97781D5FAF0E9814DD89C6E2EC936 16:16:41 : Status : WPOS WRITE SUCCESS 16:16:41 : [BLOCK 18 0x10000000~0x10FFFFFF] 16:16:41 : Data Size: 0x01000000 Bytes 16:16:41 : SHA-256 : 9F0B9999225D6860EC662B972D146B3C 16:16:41 : ---------- : 3587279F14F71808CB5020CFB6187EF5 16:16:48 : Status : WPOS WRITE SUCCESS 16:16:48 : [BLOCK 19 0x11000000~0x11FFFFFF] 16:16:48 : Data Size: 0x01000000 Bytes 16:16:48 : SHA-256 : 15806447D3FD738DAC1ECEA565FBD5ED 16:16:48 : ---------- : 2606908CBB86FFA00DABC8984697DAA6 16:16:56 : Status : WPOS WRITE SUCCESS 16:16:56 : [BLOCK 20 0x12000000~0x12FFFFFF] 16:16:56 : Data Size: 0x01000000 Bytes 16:16:56 : SHA-256 : D91E6AC815359F684F19563366C2F915 16:16:56 : ---------- : 3B86229C61FE79390B3ACA967783C459 16:17:03 : Status : WPOS WRITE SUCCESS 16:17:03 : [BLOCK 21 0x13000000~0x13FFFFFF] 16:17:03 : Data Size: 0x01000000 Bytes 16:17:03 : SHA-256 : 690E72BC8AFF8D688FFD0134E6BE01AF 16:17:03 : ---------- : C639BEFC38FD6D11AF55F45A2F997C42 16:17:10 : Status : WPOS WRITE SUCCESS 16:17:10 : [BLOCK 22 0x14000000~0x14FFFFFF] 16:17:10 : Data Size: 0x01000000 Bytes 16:17:10 : SHA-256 : D06298291A67DCE426FF413D57EC24F0 16:17:10 : ---------- : B6B3A7D2E526A304FA0C77E1B95CEA36 16:17:18 : Status : WPOS WRITE SUCCESS 16:17:18 : [BLOCK 23 0x15000000~0x15FFFFFF] 16:17:18 : Data Size: 0x01000000 Bytes 16:17:18 : SHA-256 : 4E7CC852EAB16EC72B7597E0FE8E597C 16:17:18 : ---------- : 040F3100A0541F1ACB89E1E98C27E00A 16:17:25 : Status : WPOS WRITE SUCCESS 16:17:25 : [BLOCK 24 0x16000000~0x16FFFFFF] 16:17:25 : Data Size: 0x01000000 Bytes 16:17:25 : SHA-256 : 352F0C43862D9358EF3A1D109F52A3B1 16:17:25 : ---------- : 81AFADF92319F9CB720F2F7B25E02A91 16:17:33 : Status : WPOS WRITE SUCCESS 16:17:33 : [BLOCK 25 0x17000000~0x17844BFF] 16:17:33 : Data Size: 0x00844C00 Bytes 16:17:33 : SHA-256 : CFEBF9D9ED13FEFD1D0E15F278F7AA0B 16:17:33 : ---------- : 9A8AD3D96A9AAE3F212CF1B5CD8367D0 16:17:37 : Status : WPOS WRITE SUCCESS 16:17:37 : 16:17:37 : Sending USER AREA ERASE Certificate 16:17:37 : HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E 16:17:37 : Certificate Size: 396 Bytes 16:17:37 : Status : WRITE ERASE CERTIFICATE SUCCESS 16:17:37 : 16:17:37 : Erasing USER AREA 16:17:49 : Status : ERASE SUCCESS 16:17:50 : 16:17:50 : Flashing Done! 16:17:50 : Total Flashing Time (Erase + Flashing) : 00:03:41 16:31:46 : Interface Reset OK! 16:31:46 : Reading Platform Information... 16:31:46 : Selecting Active Handle... 16:31:46 : Select Handle OK! 16:31:46 : Sending Ping... 16:31:46 : Ping Reply OK! 16:31:46 : 16:31:46 : Lumia 800/800C Detected 16:31:46 : 16:31:46 : Storage Device Information 16:31:46 : Manufacturer ID: 80 16:31:46 : Application ID : 0000 16:31:46 : Product Name : 16:31:46 : Product Rev : 0C 16:31:46 : Product SN : 00080139 16:31:46 : 16:31:46 : Protection Information 16:31:46 : Write Protect A: OFF 16:31:46 : Write Protect B: OFF 16:31:46 : 16:31:46 : 16:31:46 : Dumping AMSS FAT16 Region 16:31:46 : Please wait for 2-4 Minutes... 16:36:17 : Patch Bit Found... 16:36:17 : Total Patch Bits Found: 1 16:36:17 : Patching AMSS... 16:36:17 : Patch OK! 16:36:17 : 16:36:17 : SP Unlock Done! 16:36:17 : 16:36:17 : PIN: 00000000 16:36:17 : PUK: 0000000000 16:36:17 : 16:36:17 : Total Elapsed Time 00:04:37 | |
