Nokia Lumia 800 unlocked done via TP by ATF Nitro - [Tutorial] Nokia Lumia 800 unlocked done via TP by ATF Nitro Phone is from UNITED KINGDOM CABLE USE: - modified RJ45 cable from old nokia fbus cable of twister box - mini USB 5310 cable or CA-101 usb cable http://i244.photobucket.com/albums/g...ds/cable-1.jpg PROCEDURE: -Disassembled phone first http://i244.photobucket.com/albums/g...sassembled.jpg - Now soldered TP and connect modified RJ45 cable to ATF box - and make MINI USB as your power supply that connected to PC. http://i244.photobucket.com/albums/g...ands/ready.jpg - Test point http://i244.photobucket.com/albums/g...lxands/9-2.jpg - run ATF software - select model 800 : RM-801 - click TEST CONNECTION http://i244.photobucket.com/albums/g...lxands/a-7.jpg - put check LUMIA 800 RM-801 - then click SP UNLOCK http://i244.photobucket.com/albums/g...lxands/b-7.jpg -Finish Unlocking http://i244.photobucket.com/albums/g...lxands/c-5.jpg - after unlocking process assemble the phone - power on phone with any simcard - enter 00000000 as your PIN http://i244.photobucket.com/albums/g...lxands/pin.jpg PHONE UNLOCKED DONE - now using GLOBE sim card http://i244.photobucket.com/albums/g...ds/final-1.jpg :) |
thx for ur help Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0017A6CD Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:05:11 |
use Nss Pro no need to open phone |
It only works for phone which have unlock-bootloader. For rest, you'll need to open phone and unlock by ONLY ATF Software... BR |
@7even2n Superb! Thread is now sticky. :-) BR |
Good work bro and also thanks for angel for make this sticky. |
Superb! nice help thread |
good Jobe bro, but how did u sold it? wich tools have you used? any tips plz? BR |
Code: ====================================================== thnx....................... |
nice help post bro greet |
excellent work nd it will help us alot.... |
Code: Lumia Test Point Connection Module |
good post nice dear thanks |
good post thanksssssssssssssssss keep it up |
thanks very useful post sir. |
