Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: phillippines
Member: 295944 Status: Offline Thanks: 38
| Nokia Lumia 800 unlocked done via TP by ATF Nitro - [Tutorial] Nokia Lumia 800 unlocked done via TP by ATF Nitro Phone is from UNITED KINGDOM CABLE USE: - modified RJ45 cable from old nokia fbus cable of twister box - mini USB 5310 cable or CA-101 usb cable ![]() PROCEDURE: -Disassembled phone first ![]() - Now soldered TP and connect modified RJ45 cable to ATF box - and make MINI USB as your power supply that connected to PC. ![]() - Test point ![]() - run ATF software - select model 800 : RM-801 - click TEST CONNECTION ![]() - put check LUMIA 800 RM-801 - then click SP UNLOCK ![]() -Finish Unlocking ![]() - after unlocking process assemble the phone - power on phone with any simcard - enter 00000000 as your PIN ![]() PHONE UNLOCKED DONE - now using GLOBE sim card ![]() |
| The Following 19 Users Say Thank You to 7even2nd For This Useful Post: |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ghana Age: 32
Member: 171776 Status: Offline Thanks: 4
| thx for ur help Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0017A6CD Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:05:11 |
| The Following 6 Users Say Thank You to colombia gsm For This Useful Post: |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| @7even2n Superb! Thread is now sticky. :-) BR |
| The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post: |
| | #9 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2004 Location: ALGERIA W09
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks: 34
| Code: ======================================================
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Manufacturer ID: 90
Product Rev : 5C
Product SN : 000F5078
Patch Bit Found...
Total Patch Bits Found: 1
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:18 thnx....................... |
| | #12 (permalink) |
| Junior Member ![]() ![]() Join Date: Nov 2009
Member: 1150917 Status: Offline Sonork: 100.1615812 Thanks: 92
| Code: Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0017A6CD Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:05:11 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
