Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 11-22-2012, 04:16   #16 (permalink)
Member: 1306303
nice work, thanks for sharing
Old 11-22-2012, 05:02   #17 (permalink)
Member: 1251098
Sonork: 100.1615825
great bossssss thankxxxxxxxxxxxxxxxxxx
Old 11-22-2012, 05:58   #18 (permalink)
..::SADHAN::..'s Avatar
Member: 1430165
Sonork: 100.1594449
thanks super job.............................
The Following User Says Thank You to ..::SADHAN::.. For This Useful Post:
Old 11-22-2012, 14:20   #19 (permalink)
azerty_soft's Avatar
Member: 168313
Sonork: 100.1609490
goooooooooooooood work
Old 11-24-2012, 05:25   #20 (permalink)
luckymobile jalandhar's Avatar
Member: 1002949
Sonork: 100.1582346
how to remove that steel shield ????
Old 11-25-2012, 09:56   #21 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
It is a mater of hardware skill . i cant write or cant give any tips on it . If you r not expert on it may b phone damage forever . Better, physically tack tanning from any expert hardware technician .
Br - srinibas
The Following 2 Users Say Thank You to srinibas For This Useful Post:
Old 11-25-2012, 15:36   #22 (permalink)
Member: 1844306
Sonork: 1623272
WAO bro great job it is very sharp
The Following User Says Thank You to potsmith2012 For This Useful Post:
Old 12-07-2012, 14:44   #23 (permalink)
Member: 180091
i encountered problem with some LUMIA 800 with TOSHIBA CHIPS. IT FAILS TO READ AND PATCH.HERE IS THE LOG
08:43:22 : 1. DO NOT USE THE PHONE"S BATTERY
08:43:22 : 2. Connect the Soldered TP Connections to ATF Box
08:43:22 : 3. Disconnect the USB Cable and Wait until the
08:43:22 : the ATF Software will tell you to Connect the USB.
08:43:22 :
08:43:25 :
08:43:25 : Interface Reset OK!
08:43:25 : Reading Platform Information...
08:43:25 : Selecting Active Handle...
08:43:25 : Select Handle OK!
08:43:25 : Sending Ping...
08:43:25 : Ping Reply OK!
08:43:25 :
08:43:25 :
08:43:25 : Storage Device Information
08:43:25 : Manufacturer ID: 00
08:43:25 : Application ID : 0000
08:43:25 : Product Name :
08:43:25 : Product Rev : 00
08:43:25 : Product SN : 480604E0
08:43:25 :
08:43:25 : Protection Information
08:43:25 : Write Protect A: OFF
08:43:25 : Write Protect B: OFF
08:43:25 :
08:43:25 :
08:43:25 : Dumping AMSS FAT16 Region
08:43:25 : Please wait for 2-4 Minutes...
08:43:25 : ERROR: Dump Aborted, Too much CRC Failures!
08:43:25 :
08:43:25 : Total Elapsed Time 00:00:03
08:44:04 : ================================================== ====
08:44:04 : Lumia Test Point Connection Module
08:44:04 :
08:44:04 : 1. DO NOT USE THE PHONE"S BATTERY
08:44:04 : 2. Connect the Soldered TP Connections to ATF Box
08:44:04 : 3. Disconnect the USB Cable and Wait until the
08:44:04 : the ATF Software will tell you to Connect the USB.
08:44:04 :
08:44:08 : ERROR: Phone WAS NOT Detected! 0x01
08:44:08 : Check your Test Point Soldering!
08:44:08 :
08:44:08 : Total Elapsed Time 00:00:04
08:44:35 : ================================================== ====
WERE this model with this TOSHIBA CHIPS NOT SUPPORTED?
Old 12-07-2012, 14:44   #24 (permalink)
Member: 180091
08:43:22 :
08:43:25 :
08:43:25 :
08:43:25 :
08:43:25 :
08:43:25 :
08:43:25 :
08:43:25 :
08:44:04 :
08:44:04 :
08:44:08 :
Old 12-08-2012, 14:07   #25 (permalink)
maruti82's Avatar
Member: 375663
SEE BELOW LINK ANY ONE CAN HELP
TP cabeL CONFUSION
Old 12-08-2012, 14:17   #26 (permalink)
Member: 1673508
Sonork: umer saleemi
thanx
very nice post
atf is the best box for all nokia
Old 12-10-2012, 13:12   #27 (permalink)
Member: 570252
Wink done! for 2nd time
12:34:32 : ======================================================
12:34:32 :        Lumia Test Point Connection Module
12:34:32 :
12:34:32 : 1. DO NOT USE THE PHONE"S BATTERY
12:34:32 : 2. Connect the Soldered TP Connections to ATF Box
12:34:32 : 3. Disconnect the USB Cable and Wait until the
12:34:32 :    the ATF Software will tell you to Connect the USB.
12:34:32 :
12:34:41 :
12:34:41 : Interface Reset OK!
12:34:41 : Reading Platform Information...
12:34:41 : Selecting Active Handle...
12:34:41 : Select Handle OK!
12:34:41 : Sending Ping...
12:34:41 : Ping Reply OK!
12:34:41 :
12:34:41 : Lumia 800/800C Detected
12:34:41 :
12:34:41 : Storage Device Information
12:34:41 : Manufacturer ID: 90
12:34:41 : Application ID : 014A
12:34:41 : Product Name   : HYNIX
12:34:41 : Product Rev    : 5C
12:34:41 : Product SN     : 08C05CA0
12:34:41 :
12:34:41 : Protection Information
12:34:41 : Write Protect A: OFF
12:34:41 : Write Protect B: OFF
12:34:41 :
12:35:13 : ======================================================
12:35:13 :        Lumia Test Point Connection Module
12:35:13 :
12:35:13 : 1. DO NOT USE THE PHONE"S BATTERY
12:35:13 : 2. Connect the Soldered TP Connections to ATF Box
12:35:13 : 3. Disconnect the USB Cable and Wait until the
12:35:13 :    the ATF Software will tell you to Connect the USB.
12:35:13 :
12:35:15 :
12:35:15 : Interface Reset OK!
12:35:15 : Reading Platform Information...
12:35:15 : Selecting Active Handle...
12:35:15 : Select Handle OK!
12:35:15 : Sending Ping...
12:35:15 : Ping Reply OK!
12:35:15 :
12:35:15 : Lumia 800/800C Detected
12:35:15 :
12:35:15 : Storage Device Information
12:35:15 : Manufacturer ID: 90
12:35:15 : Application ID : 014A
12:35:15 : Product Name   : HYNIX
12:35:15 : Product Rev    : 5C
12:35:15 : Product SN     : 08C05CA0
12:35:15 :
12:35:15 : Protection Information
12:35:15 : Write Protect A: OFF
12:35:15 : Write Protect B: OFF
12:35:16 :
12:35:16 :
12:35:16 : Dumping AMSS FAT16 Region
12:35:16 : Please wait for 2-4 Minutes...
12:39:28 : Patch Bit Found...
12:39:28 : Total Patch Bits Found: 1
12:39:28 : Patching AMSS...
12:39:29 : Patch OK!
12:39:29 :
12:39:29 : SP Unlock Done!
12:39:29 :
12:39:29 : PIN: 00000000
12:39:29 : PUK: 0000000000
12:39:29 :
12:39:29 : Total Elapsed Time 00:04:15
Old 12-13-2012, 09:12   #28 (permalink)
s1emens's Avatar
Member: 40602
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 80
Product Name :
Product Rev : 0C
Product SN : 00000C81
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:05:37
br,
s1emens
Old 12-13-2012, 10:37   #29 (permalink)
s1emens's Avatar
Member: 40602
strange still invalid sim, at first using simcard always said invalid sim, is this blocked or?
br,
s1emens
Old 12-13-2012, 12:31   #30 (permalink)
Member: 515130
dont remove the shield just moved outsid
the shield and sold it
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 90
Product Rev : 5C
Product SN : 01C69C5F
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:06:02
Page generated in 0.62114 seconds with 10 queries
