Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-13-2012, 13:53   #31 (permalink)
Member: 906174
thanks thanks thanks
Old 12-13-2012, 16:21   #32 (permalink)
s1emens's Avatar
Member: 40602
my product name is empty
it should be HYNIX ?
i recieved phone form customer when insert sim it said invalid sim, it didn't ask for PIN, is this means it locked? or maybe counter blocked? still new in WP NOKIA unlocking
i'll try again tomorrow
br,
s1emens
Old 12-14-2012, 11:08   #33 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161 GSM GURU
Lumia Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Lumia 800/800C Detected
Storage Device Information
Manufacturer ID: 90
Application ID : 0042
Product Name : F
Product Rev : 0C
Product SN : 03CEF80E
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Mintues...
Patch Bit Found...
Total Patch Bits Found: 1
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:23
Old 12-18-2012, 06:53   #34 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
hello
i am facing this problem. please check this error.
Interface Reset OK!
ERROR: Connection Refused 0x03
Check your Test Point Soldering!
Old 12-18-2012, 06:53   #35 (permalink)
Member: 820592
hello
Interface Reset OK!
Old 12-18-2012, 07:04   #36 (permalink)
Member: 459329
good post thanksssssssssssssssss keep it up
Old 12-18-2012, 09:05   #37 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Originally Posted by Hafiz ArslanAli View Post
hello
Interface Reset OK!
Hi,
ATF Software already tells you where is the problem. So you just correct it...
Old 12-18-2012, 16:42   #38 (permalink)
Member: 851061
Sonork: 100.1613359
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 00
Application ID : 0100
Product Name : 016G4B
Product Rev : 00
Product SN : 8E4FB402
Total Elapsed Time 00:11:24
Old 12-18-2012, 16:53   #39 (permalink)
Member: 851061
Sonork: 100.1613359
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 00
Product Rev : 00
and phone vibrate not power
gave me a sollution
thanks
Old 12-18-2012, 17:33   #40 (permalink)
Member: 851061
Sonork: 100.1613359
gave me a sollution
thanks
prebleme solved thanks turbo flasher
Old 12-19-2012, 11:13   #41 (permalink)
Sahil2007's Avatar
Member: 598395
Lumia 800 UNLOCK DONE BY ATF
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
Manufacturer ID: 80
Application ID : 0000
Product Name :
Product Rev : 0C
Product SN : 00084302
Please wait for 2-4 Minutes...
Patch Bit Found...
Patching AMSS...
Patch OK!
SP Unlock Done!
PIN: 00000000
PUK: 0000000000
Total Elapsed Time 00:04:18
Old 12-19-2012, 11:25   #42 (permalink)
gurinder's Avatar
Member: 167191
Sonork: 100.1594058
Thumbs up another lumia 800 done
another lumia 800 from orange uk. done superbly..
13:24:19 : ======================================================
13:24:19 :        Lumia Test Point Connection Module
13:24:19 :
13:24:19 : 1. DO NOT USE THE PHONE"S BATTERY
13:24:19 : 2. Connect the Soldered TP Connections to ATF Box
13:24:19 : 3. Disconnect the USB Cable and Wait until the
13:24:19 :    the ATF Software will tell you to Connect the USB.
13:24:19 :
13:24:21 :
13:24:21 : Interface Reset OK!
13:24:21 : Reading Platform Information...
13:24:21 : Selecting Active Handle...
13:24:21 : Select Handle OK!
13:24:21 : Sending Ping...
13:24:21 : Ping Reply OK!
13:24:21 :
13:24:21 : Lumia 800/800C Detected
13:24:21 :
13:24:21 : Storage Device Information
13:24:21 : Manufacturer ID: 90
13:24:21 : Application ID : 014A
13:24:21 : Product Name   : HYNIX
13:24:21 : Product Rev    : 5C
13:24:21 : Product SN     : 01A63130
13:24:21 :
13:24:21 : Protection Information
13:24:22 : Write Protect A: OFF
13:24:22 : Write Protect B: OFF
13:24:22 :
13:24:22 :
13:24:22 : Dumping AMSS FAT16 Region
13:24:22 : Please wait for 2-4 Minutes...
13:28:52 : Patch Bit Found...
13:28:52 : Total Patch Bits Found: 1
13:28:52 : Patching AMSS...
13:28:52 : Patch OK!
13:28:52 :
13:28:52 : SP Unlock Done!
13:28:52 :
13:28:52 : PIN: 00000000
13:28:52 : PUK: 0000000000
13:28:52 :
13:28:52 : Total Elapsed Time 00:07:21
gurinder
Old 12-19-2012, 11:54   #43 (permalink)
Member: 973412
lumia 800 unlocked done
Old 12-19-2012, 12:02   #44 (permalink)
Member: 973412
Old 12-19-2012, 12:10   #45 (permalink)
Member: 973412
Page generated in 0.50399 seconds with 10 queries
