Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #46 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: Vojvodina Age: 34
Member: 44395 Status: Offline Thanks: 27
| Toshiba chip Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 0C4418F0 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:06 toshiba chip, cant be unlocked? |
| | #47 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2008 Location: Algeria Age: 30
Member: 851061 Status: Offline Sonork: 100.1613359 Thanks: 47
| 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 04E25A34 Protection Information Write Protect A: OFF Write Protect B: OFF Writing MBR... Write Success! Writing SEC_BOOT... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:00:27 thanks team |
| | #48 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: May 2009
Member: 1041791 Status: Offline Thanks: 13
| please help me for this phone , is locked ,but ATF showing maybe unlock already , ........ code: 20:22:07 : ================================================== ==== 20:22:07 : ================================================== ==== 20:22:07 : Lumia Test Point Connection Module 20:22:07 : ================================================== ==== 20:22:07 : ================================================== ==== 20:22:07 : 20:22:07 : 1. DO NOT USE THE PHONE"S BATTERY 20:22:07 : 2. Connect the Soldered TP Connections to ATF Box 20:22:07 : 3. Disconnect the USB Cable and Wait until the 20:22:07 : the ATF Software will tell you to Connect the USB. 20:22:07 : 20:22:09 : 20:22:09 : Interface Reset OK! 20:22:09 : Reading Platform Information... 20:22:09 : Selecting Active Handle... 20:22:09 : Select Handle OK! 20:22:09 : Sending Ping... 20:22:09 : Ping Reply OK! 20:22:09 : 20:22:09 : 20:22:09 : Storage Device Information 20:22:09 : Manufacturer ID: 11 20:22:09 : Application ID : 0100 20:22:09 : Product Name : 016G4B 20:22:09 : Product Rev : 00 20:22:09 : Product SN : D189C986 20:22:09 : 20:22:09 : Protection Information 20:22:09 : Write Protect A: OFF 20:22:09 : Write Protect B: OFF 20:22:09 : 20:22:09 : 20:22:09 : Dumping AMSS FAT16 Region 20:22:09 : Please wait for 10-20 Minutes... 20:22:36 : ================================================== ==== 20:22:36 : ================================================== ==== 20:22:36 : Lumia Test Point Connection Module 20:22:36 : ================================================== ==== 20:22:36 : ================================================== ==== 20:22:36 : 20:22:36 : 1. DO NOT USE THE PHONE"S BATTERY 20:22:36 : 2. Connect the Soldered TP Connections to ATF Box 20:22:36 : 3. Disconnect the USB Cable and Wait until the 20:22:36 : the ATF Software will tell you to Connect the USB. 20:22:36 : 20:22:38 : 20:22:38 : Interface Reset OK! 20:22:38 : Reading Platform Information... 20:22:38 : Selecting Active Handle... 20:22:38 : Select Handle OK! 20:22:38 : Sending Ping... 20:22:38 : Ping Reply OK! 20:22:38 : 20:22:38 : 20:22:38 : Storage Device Information 20:22:38 : Manufacturer ID: 11 20:22:38 : Application ID : 0100 20:22:38 : Product Name : 016G4B 20:22:38 : Product Rev : 00 20:22:38 : Product SN : D189C986 20:22:38 : 20:22:38 : Protection Information 20:22:38 : Write Protect A: OFF 20:22:38 : Write Protect B: OFF 20:22:38 : 20:22:38 : 20:22:38 : Dumping AMSS FAT16 Region 20:22:38 : Please wait for 10-20 Minutes... 20:46:16 : 20:46:16 : WARNING: Patch Bit NOT FOUND! 20:46:16 : Maybe Phone is already UNLOCKED! 20:46:16 : |
| | #49 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2010 Location: gsm forum
Member: 1247129 Status: Offline Thanks: 89
| thanks ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 03845918 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:20 Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
| | #50 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 559460 Status: Offline Thanks: 48
| please help...unlock done but, show invalid sim. no asking code. use atf 9.15 Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 01FDB083 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:32 |
| | #51 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 41
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks: 1,560
| Quote:
Br - srinibas | |
| The Following User Says Thank You to srinibas For This Useful Post: |
| | #55 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Age: 29
Member: 515130 Status: Offline Thanks: 163
| ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 001931A2 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time |
| The Following User Says Thank You to shahzad-0004 For This Useful Post: |
| | #57 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: (¯`·._PAKISTAN_.·´¯)
Member: 1424925 Status: Offline Sonork: 100.1614407 Thanks: 11
| ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 04EEC6AE Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:30 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
