Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #63 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2005
Member: 113454 Status: Offline Thanks: 5
| Hi, I had unlocked about 5 phones till now, before this error.......... It has a TOSHIBA Chip, and here is the log.......... Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 4ECEB2B9 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... ERROR: Dump Aborted, Too Much Read Failures! Total Elapsed Time 00:43:18 Any One can Confirm Please. Br GURUGSM |
| | #64 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ghana Age: 32
Member: 171776 Status: Offline Thanks: 4
| plz help me this is the error 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 02040002 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! |
| | #65 (permalink) |
| Hi Supporters, Can Somebody pls confirm My Request please. The Older phones which I had Unlocked were all Hynix Chips. Only this Phone has a TOSHIBA Ic. AMSS Dumping took approx 45mts in this case. Earlier it was within 3-5 mts. So pls confirm, customer pressure is mounting. Thanks, Br GURUGSM |
| | #67 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004
Member: 50772 Status: Offline Thanks: 4,015
| lumia 800 successfully unlocked ... thanks to advance box team ------------------------------------------------------------- ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 00C6E0FE Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:32 |
| | #68 (permalink) |
| I am seeing all Unlocked Logs, None with Toshiba chip. All success with Hynix chips Only. So Is it a Confirtmation that Toshiba Chips are not Supported? Please Confirm. I dont want to Open a New thread for this and Waste Space. Thanks, GURUGSM |
| | #69 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Age: 29
Member: 515130 Status: Offline Thanks: 163
| again successfully lumia 800 Hynix Chips unlock done 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0020F6B0 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:32 |
| | #71 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2002 Location: Croatia Age: 37
Member: 9568 Status: Offline Thanks: 13
| Lumia 800 unlocked successfully: Code: ====================================================== 22:05:24 : ====================================================== 22:05:24 : Lumia Test Point Connection Module 22:05:24 : ====================================================== 22:05:24 : ====================================================== 22:05:24 : 22:05:24 : 1. DO NOT USE THE PHONE"S BATTERY 22:05:24 : 2. Connect the Soldered TP Connections to ATF Box 22:05:24 : 3. Disconnect the USB Cable and Wait until the 22:05:24 : the ATF Software will tell you to Connect the USB. 22:05:24 : 22:05:36 : 22:05:36 : Interface Reset OK! 22:05:36 : Reading Platform Information... 22:05:36 : Selecting Active Handle... 22:05:36 : Select Handle OK! 22:05:36 : Sending Ping... 22:05:36 : Ping Reply OK! 22:05:36 : 22:05:36 : Lumia 800/800C Detected 22:05:36 : 22:05:36 : Storage Device Information 22:05:36 : Manufacturer ID: 90 22:05:36 : Application ID : 014A 22:05:36 : Product Name : HYNIX 22:05:36 : Product Rev : 5C 22:05:36 : Product SN : 001A8965 22:05:36 : 22:05:36 : Protection Information 22:05:36 : Write Protect A: OFF 22:05:36 : Write Protect B: OFF 22:05:36 : 22:05:44 : ====================================================== 22:05:44 : ====================================================== 22:05:44 : Lumia Test Point Connection Module 22:05:44 : ====================================================== 22:05:44 : ====================================================== 22:05:44 : 22:05:44 : 1. DO NOT USE THE PHONE"S BATTERY 22:05:44 : 2. Connect the Soldered TP Connections to ATF Box 22:05:44 : 3. Disconnect the USB Cable and Wait until the 22:05:44 : the ATF Software will tell you to Connect the USB. 22:05:44 : 22:05:46 : 22:05:46 : Interface Reset OK! 22:05:46 : Reading Platform Information... 22:05:46 : Selecting Active Handle... 22:05:46 : Select Handle OK! 22:05:46 : Sending Ping... 22:05:46 : Ping Reply OK! 22:05:46 : 22:05:46 : Lumia 800/800C Detected 22:05:46 : 22:05:46 : Storage Device Information 22:05:46 : Manufacturer ID: 90 22:05:46 : Application ID : 014A 22:05:46 : Product Name : HYNIX 22:05:46 : Product Rev : 5C 22:05:46 : Product SN : 001A8965 22:05:46 : 22:05:46 : Protection Information 22:05:46 : Write Protect A: OFF 22:05:46 : Write Protect B: OFF 22:05:46 : 22:05:46 : 22:05:46 : Dumping AMSS FAT16 Region 22:05:46 : Please wait for 2-4 Minutes... 22:05:48 : ====================================================== 22:05:48 : ====================================================== 22:05:48 : Lumia Test Point Connection Module 22:05:48 : ====================================================== 22:05:48 : ====================================================== 22:05:48 : 22:05:48 : 1. DO NOT USE THE PHONE"S BATTERY 22:05:48 : 2. Connect the Soldered TP Connections to ATF Box 22:05:48 : 3. Disconnect the USB Cable and Wait until the 22:05:48 : the ATF Software will tell you to Connect the USB. 22:05:48 : 22:05:50 : 22:05:50 : Interface Reset OK! 22:05:50 : Reading Platform Information... 22:05:50 : Selecting Active Handle... 22:05:51 : Select Handle OK! 22:05:51 : Sending Ping... 22:05:51 : Ping Reply OK! 22:05:51 : 22:05:51 : Lumia 800/800C Detected 22:05:51 : 22:05:51 : Storage Device Information 22:05:51 : Manufacturer ID: 90 22:05:51 : Application ID : 014A 22:05:51 : Product Name : HYNIX 22:05:51 : Product Rev : 5C 22:05:51 : Product SN : 001A8965 22:05:51 : 22:05:51 : Protection Information 22:05:51 : Write Protect A: OFF 22:05:51 : Write Protect B: OFF 22:05:51 : 22:05:51 : 22:05:51 : Dumping AMSS FAT16 Region 22:05:51 : Please wait for 2-4 Minutes... 22:10:22 : Patch Bit Found... 22:10:22 : Total Patch Bits Found: 1 22:10:22 : Patching AMSS... 22:10:22 : Patch OK! 22:10:22 : 22:10:22 : SP Unlock Done! 22:10:22 : 22:10:22 : PIN: 00000000 22:10:22 : PUK: 0000000000 22:10:22 : 22:10:22 : Total Elapsed Time 00:04:38 |
| | #72 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2011
Member: 1482280 Status: Offline Sonork: 100.1600954 Thanks: 159
| what about this error 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 00 Application ID : 0000 Product Name : Product Rev : 00 Product SN : 40030007 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... ERROR: Dump Aborted, Too much CRC Failures! Total Elapsed Time 00:00:02 |
| | #73 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 41
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks: 1,560
| Quote:
Try with RED wire connection only, means DO NOT connect YELLOW wire connection to RED, just use RED wire connection on TP. Br - srinibas | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
