04-21-2013, 15:10 | #1 (permalink) |
Insane Poster Join Date: Apr 2007 Location: IR.Tehran
Member: 491308 Status: Offline Sonork: 100.1624581 Thanks Meter: 8 | Nokia lumia 900 Boot repair Problem 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! BOOT Images Written Successfully! Total Elapsed Time 00:00:10 I checked test point that show on picture every thing |
04-25-2013, 17:56 | #5 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Hanoi, Vietnam
Member: 1012390 Status: Offline Thanks Meter: 95 | I think your problem maybe get from cable not good I just buy AFT and 2 set of Lumia TP cables from GPG Today, i get a Lumia 800 to repair, and get problem as the same you with one cable, with another, it good Check the cable again |
