09-26-2012, 11:28 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1142718 Status: Offline Thanks Meter: 1 | nokia lumia800 unlock ok! By ATF ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0207BE30 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:26 Last edited by phamhahien; 09-26-2012 at 11:33. |
The Following User Says Thank You to phamhahien For This Useful Post: |
