06-21-2014, 05:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 183 | nokia lunia 620 blue screen problem [IMG][/IMG] |
06-21-2014, 05:32 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lucky999 1. Remove battery of phone 2. Click FLASH Button on ATF Software 3. Put battery on phone 4. Hold VOLUME DOWN 5. Connect USB Cable 6 . Continue to Hold VOLUME DOWN until flashing starts B.R. |
06-21-2014, 11:50 | #3 (permalink) | |
Member: 1643797 Status: Offline Thanks Meter: 183 | Quote:
Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x02 Blocks Block ID 0x01 : 00241000 Block ID 0x04 : 01090110 Checking SD Card Size... Card Size: 0x00040004 Checking Platform Security Status... Platform Secure Boot Status: Not Active Secure FFU EFUSE Status: Not Active Debug Status: Not Active RDC Status: Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : NONE Query Flash App Information... Flash App Information: 00040004010901100000000000000000 Flash App Protocol Version: 4.0 Flash App Implementation Version: 4.1 Query ROOT KEY HASH... ROOT_KEY_HASH: 00040004010901100000000000000000 ERROR: Flash File ROOT_KEY_HASH Mismatch! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! | |
06-21-2014, 12:15 | #4 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Egypt Age: 28
Member: 1857256 Status: Offline Sonork: 1650338 Thanks Meter: 91 | ERROR: Flash File ROOT_KEY_HASH Mismatch! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! check phone rm-xxx and load the right flash files |
06-21-2014, 14:38 | #7 (permalink) | |
06-21-2014, 15:32 | #8 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Add Flash path for this Lumia, This error is because you are choosing flash file manually, add in path for detect Phone like Phoenix Path Download this files. copy inside RM, Open ATF Soft, Choice Model, Tick Phoenix, the file automatically appear so. Flash Phone.- ///.4shared.com/file/VN2hDJyWba/3C2BE1D1_RM846_304600001329200.html If you still problem, im uploading full pack files for this rm. br auto |
06-21-2014, 17:29 | #11 (permalink) | |
Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== IMEI: 354636050914236 Version: 1.1.1.2 Product Code: 059R4K7 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 020109011000 UEFI App: FLASH APP Flash App Protocol Version: 1.9 Flash App Implementation Version: 1.16 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:04:42 | |
06-21-2014, 20:17 | #12 (permalink) |
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Always looking for errors in the ATF team .. Should check that either side is the error. in this case, you are doing things wrong (please update important files) Last Version Work Perfect.- Just follow the X-Shadow Tips, Remember, he is the coder Here PIC here log If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== ================================================ Basic Phone Information ================================================ SW Version : 1030.6407.1308.0001 IMEI Plain : 356715056197273 IMEI2 Plain : 356715056197273 HW Version : 5025 Phone Type : RM-846 Product Code : 059S2V3 Module Code : 0205404 PSN Number : MIO446853 Manufacturer ID : RM-846_lta_lta_491 Operator Name : CLA-AR Phone Version : BuildDate : Feb 22 2013 , BuildType : Release , HelloString : NCSd for WP8 , Version : 1.25 Security Mode : Restricted Variant Information: VAR ARGENTINA AR CLARO SK059R4K8 RM-846 VAR APAC HK CV ================================================ Extended Phone Information ================================================ Public ID : 0E0CE0F48325C74C3C056075117F3FD069BE45C7 Wireless Lan 0 ID: 54:44:08:CB:CD:9C Wireless Lan 1 ID: 54:44:08:CB:CD:9D Wireless Lan 2 ID: 54:44:08:CB:CD:9E Wireless Lan 3 ID: 54:44:08:CB:CD:9F Bluetooth ID : 54:44:08:CA55 ================================================ Simlock Information ================================================ NETWORK NAME : AMX Argentina S.A;Argentina [GSM] PROVIDER KEY : 7223100000000000 SIMLOCK STATE : Locked Booting Flash Mode Initiated... Please wait upto 15 Seconds for HW Reset Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010C011700 UEFI App: FLASH APP Flash App Protocol Version: 1.12 Flash App Implementation Version: 1.23 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467 E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:28 Last edited by Automatico; 06-21-2014 at 20:26. |
06-23-2014, 04:13 | #14 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL Thanks for reporting. I will fix this problem before final release this month. Just few questions which will help me fix it: 1. Was your phone dead when you tried to flash it? 2. Did you enter flash mode via hold volume down button? B.R> |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-23-2014, 12:07 | #15 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: brasil -brasilia Age: 38
Member: 1379110 Status: Offline Thanks Meter: 51 | Quote:
tried to flash holding volume up and just gave this error | |
