01-16-2014, 11:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | nokia n73 cannot repair security test failed with atf Basic Phone Information ================================================ MCU Version: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia. IMEI Plain : 353641019096845 IMEI Spare : A353641019096840 IMEI SV : 33536410190968453F Phone Model: Nokia N73 Category : Imaging Phone Phone Type : RM-133 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-133.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 2 Byte(s): 98 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 6 Byte(s): 98 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 98 - Ok Field : 1 Sub : 16 Byte(s): 98 - Ok Field : 1 Sub : 18 Byte(s): 98 - Ok Field : 1 Sub : 20 Byte(s): 98 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 4 - Ok Field : 1 Sub : 26 Byte(s): 110 - Ok Field : 1 Sub : 28 Byte(s): 98 - Ok Field : 1 Sub : 29 Byte(s): 6 - Ok Field : 1 Sub : 31 Byte(s): 98 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 80 - Ok Field : 1 Sub : 44 Byte(s): 182 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok PM Upload Done!... ================================================ Basic Phone Information ================================================ MCU Version: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia. IMEI Plain : 353641019096845 IMEI Spare : A353641019096840 IMEI SV : 33536410190968453F Phone Model: Nokia N73 Category : Imaging Phone Phone Type : RM-133 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-133.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 2 Byte(s): 98 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 6 Byte(s): 98 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 98 - Ok Field : 1 Sub : 16 Byte(s): 98 - Ok Field : 1 Sub : 18 Byte(s): 98 - Ok Field : 1 Sub : 20 Byte(s): 98 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 4 - Ok Field : 1 Sub : 26 Byte(s): 110 - Ok Field : 1 Sub : 28 Byte(s): 98 - Ok Field : 1 Sub : 29 Byte(s): 6 - Ok Field : 1 Sub : 31 Byte(s): 98 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 80 - Ok Field : 1 Sub : 44 Byte(s): 182 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok PM Upload Done!... ================================================ Basic Phone Information ================================================ MCU Version: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia. IMEI Plain : 353641019096845 IMEI Spare : A353641019096840 IMEI SV : 33536410190968453F Phone Model: Nokia N73 Category : Imaging Phone Phone Type : RM-133 ================================================ Extended Phone Information ================================================ Product Serial Number: CNF178756 Product Code : 0539691 Module Code : 0202855 Basic Production Code: 0527006 MCU SW Version : V 05wk47v51.5 29-08-07 RM-133 (c) Nokia. HW Version : 6000 RFIC Version : 17211721 DSP Version : scarfe_05wk46v50 Camera : 1 APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. AHNE Version : 30 APE SW Core Version : V 4.0736.3.2.1 04-09-2007 RM-133 Variant Version : V 4.0736.3.2.1-08 04-09-2007 RM-133 RETU Version : 15 TAHVO Version : 22 APE HW Version : 1 APE ADSP SW Version : 256 Bluetooth ID : 00:19:79:E9:75:B4 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL1 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST DCC ID : NOT USED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... ammyy id 21 138 049 |
01-18-2014, 05:05 | #2 (permalink) | |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote:
i am waiting fore replay | |
01-19-2014, 07:44 | #4 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.80 Software Version : v10.61 AdvanceBox SN : DB62D8AD8FA9E72FC1BFC034 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100708 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8B9190CB ID DWORD 1 : DF8F5AF9 ID DWORD 2 : 0E2ABE25 ID DWORD 3 : 7D0EB879 ID DWORD 4 : D91CAC14 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 49 A9 7E 82 6B 93 BA 20 B7 ED 0B 08 24 75 C0 05 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : 1DFD6613 CRC 1 : 2C872FD4 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01003000 7 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 8 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27200102 ID DWORD 1 : A0A20154 ID DWORD 2 : FAAC5AA5 ID DWORD 3 : 866F25AA ID DWORD 4 : E317F787 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 7A ============================================ NOR Chip Detected... Nitro Flashing Disabled ============================================ SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_2nd.fg Boot File - Version 01.030.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 22E8 -> K5G2829ATC Extended/Fixed ID : 0000 Revision ID : 6921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 20 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :00EC DevID :22E8 ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 00EC Device ID : 22E8 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 01000000 (16 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_algo.fg Algorithm File - Version 01.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Searching for APE Boot File.. SearchForBootstrap_DCT5... C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\helen3_2nd.fg Boot File - Version Boot File - Revision 0x (2) eBB5ProtocolType == New TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 02 SubBlocks : 02 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 00A1 -> K5E1G12ACM Extended/Fixed ID : 0080 Revision ID : 0015 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Device Contents : FFFFFFFFFFFFFFFFFFFF Checksum : A8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 00A1 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0015 Erase10s : 0F Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\h3_sam_nand_xsr.fg Algorithm File - Version 01.047.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 01 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC ( CMT and APE PAPUBKEYS HASH are Identical ) START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) OK Reading : CCC (CMT) CCC : Empty Reading : HWC (CMT) HWC : Empty Reading : R&D (CMT) OK Reading : PARTNERC (CMT) PARTNERC : Empty Reading : MDM_KEYS (CMT) MDM_KEYS : Empty Reading : NPC (APE) NPC : Empty Reading : VARIANT (APE) VARIANT : Empty Reading : CCC (APE) CCC : Empty Reading : HWC (APE) HWC : Empty Reading : R&D (APE) OK Reading : PARTNERC (APE) PARTNERC : Empty Reading : MDM_KEYS (APE) MDM_KEYS : Empty NPC CERTIFICATE INFORMATION (CMT): IMEI : 353641019096845 PRODUCT CODE : 0543843 BLUETOOTH ID : 00:19:79:E9:75:B4 PUBLIC_ID : 27200102A0A20154FAAC5AA5866F25AAE317F787 PAPUB_KEYS_HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC VARIANT CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0541421 WARNING: PRODUCT CODES MISMATCH This might cause SECURITY TEST FAILED in Phones which require them to match FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353641019096845\3536410190968 45_114348.rpl |
01-20-2014, 11:09 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Solution is here in the Backup RPL log: Code: NPC CERTIFICATE INFORMATION (CMT): IMEI : 353641019096845 PRODUCT CODE : 0543843 BLUETOOTH ID : 00:19:79:E9:75:B4 PUBLIC_ID : 27200102A0A20154FAAC5AA5866F25AAE317F787 PAPUB_KEYS_HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC VARIANT CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0541421 [B]WARNING: PRODUCT CODES MISMATCH This might cause SECURITY TEST FAILED in Phones which require them to match[/B] |
01-26-2014, 07:00 | #7 (permalink) | |
please till me PRODUCT CODE : 0541421 or 0543843 ????? | |
