Nokia N73 Security Test Failed!!! Nokia N73 Phone start up failed Contact retailer when scan phone shows security Test failed after writing modified pm with 1, 309 still same |
post phone info......... |
Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL1 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : LOCAL ================================================== ==== Selected VPL File: RM133_0537289_4.0839.42.2.1_011.vpl ================================================== ==== Variant Details : RM-133 CUST.TRX EURO 1 (Black) Software Version : 4.0839.42.2.1 Product Type : RM-133 Product Code : 0537289 Variant Version : 011 ================================================== ==== Selected VPL File: RM133_0539295_4.0839.42.2.1_011.vpl ================================================== ==== Variant Details : RM-133 CUST.TRX GULF (Black) Software Version : 4.0839.42.2.1 Product Type : RM-133 Product Code : 0539295 Variant Version : 011 this is the pm writing procedure >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-133.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 114 - Ok Field : 1 Sub : 2 Byte(s): 98 - Ok Field : 1 Sub : 4 Byte(s): 110 - Ok Field : 1 Sub : 6 Byte(s): 98 - Ok Field : 1 Sub : 8 Byte(s): 110 - Ok Field : 1 Sub : 13 Byte(s): 98 - Ok Field : 1 Sub : 16 Byte(s): 98 - Ok Field : 1 Sub : 18 Byte(s): 98 - Ok Field : 1 Sub : 20 Byte(s): 98 - Ok Field : 1 Sub : 22 Byte(s): 16 - Ok Field : 1 Sub : 23 Byte(s): 4 - Ok Field : 1 Sub : 24 Byte(s): 84 - Ok Field : 1 Sub : 25 Byte(s): 4 - Ok Field : 1 Sub : 26 Byte(s): 110 - Ok Field : 1 Sub : 28 Byte(s): 98 - Ok Field : 1 Sub : 29 Byte(s): 6 - Ok Field : 1 Sub : 31 Byte(s): 98 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 34 Byte(s): 80 - Ok Field : 1 Sub : 44 Byte(s): 182 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok PM Upload Done!... after pm writing SIMLOCK_TYPE : PA_SL1 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : LOCAL DCC ID : NOT USED |
you need to repair SD first, then write pm file, then SX4 "PM AUTH" |
Write N73_without_NPC_DATA.rpl, search on folder C:\AdvanceBox Turbo Flasher\Nokia\RPL_Wout_NPC |
The problem is easily solved with best dongle |
This is the rpl back up needed for posting to solve my problem Please ATF team? START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) OK Reading : CCC (CMT) CCC : Empty Reading : HWC (CMT) HWC : Empty Reading : R&D (CMT) OK Reading : PARTNERC (CMT) PARTNERC : Empty Reading : MDM_KEYS (CMT) MDM_KEYS : Empty Reading : NPC (APE) NPC : Empty Reading : VARIANT (APE) VARIANT : Empty Reading : CCC (APE) CCC : Empty Reading : HWC (APE) HWC : Empty Reading : R&D (APE) OK Reading : PARTNERC (APE) PARTNERC : Empty Reading : MDM_KEYS (APE) MDM_KEYS : Empty NPC CERTIFICATE INFORMATION (CMT): IMEI : 359568012510056 PRODUCT CODE : 0539295 BLUETOOTH ID : 00:1E:3B:6E:A4:3B PUBLIC_ID : 224002178DEC0154787C5357C14DB27E32FAB799 PAPUB_KEYS_HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC VARIANT CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0541421 WARNING: PRODUCT CODES MISMATCH This might cause SECURITY TEST FAILED in Phones which require them to match FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359568012510056\3595680125100 56_103235.rpl |
1st auth the phone then write 1-309 pm if still same write hwc,ccc data then try if still same contact me on sonork br, vijay |
