11-13-2014, 12:30 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: Nigeria
Member: 1931004 Status: Offline Sonork: 100.1662382 Thanks Meter: 85 | Nokia N9-00 RM-696 Flashing Failed... Code: 11:50:07 : Number of Image Files: 2 11:50:07 : (Mass Memory File Detected) 11:50:07 : 11:50:08 : Processing Image File : 11:50:08 : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin 11:50:08 : CMT Type : MAEMO/MEEGO 11:50:08 : 11:50:08 : Processing Image File : 11:50:08 : DFL61_HARMATTAN_40.2012.13-7.SEAP_EMMC_SEAP.bin 11:50:08 : CMT Type : MAEMO/MEEGO 11:50:08 : 11:50:08 : D:\AdvanceBox Turbo Flasher\Logs\flasher.exe 11:50:08 : -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin 11:50:08 : E:\Users\binadam23\Desktop\Products\RM-696\ 11:50:08 : D:\AdvanceBox Turbo Flasher\Logs\flasher.exe 11:50:08 : -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin -F DFL61_HARMATTAN_40.2012.13-7.SEAP_EMMC_SEAP.bin 11:50:08 : E:\Users\binadam23\Desktop\Products\RM-696\ 11:50:08 : ====================================================== 11:50:08 : ====================================================== 11:50:08 : BB5 MEEGO / HARMATTAN FLASHER 11:50:08 : ====================================================== 11:50:08 : ====================================================== 11:50:08 : 11:50:08 : 1. Turn OFF Phone and wait 10 Seconds... 11:50:08 : 2. Connect the USB Cable to the PHONE Micro USB Port 11:50:08 : 3. Connect the USB Cable to the PC USB Port 11:50:08 : 11:50:08 : TIPS & INFORMATION: 11:50:08 : 1. To Turn OFF the Phone, PRESS and HOLD the POWER 11:50:08 : button for at least 10 Seconds... 11:50:08 : 2. Battery Charging will still work on "DEAD" Phones. 11:50:08 : 3. Factory Reset will make Flashing 15 minutes longer 11:50:08 : and it will Totally Erase the User Data and Remove 11:50:08 : the Phone Lock + Security Code as well... 11:50:08 : 4. Skip ADL Chk will Cold Flash the Device. 11:50:08 : ====================================================== 11:50:08 : ====================================================== 11:50:08 : 11:50:09 : Waiting For Phone on USB PORT/s... 11:50:09 : REQUIRED MODE: BOOTROM MODE 11:50:21 : Sending PRIMARY-BOOT: SUCCESSFUL! 11:50:25 : Waiting For Phone on USB PORT/s... 11:50:25 : REQUIRED MODE: BOOTROM MODE 11:50:25 : Sending SECONDARY-BOOT: SUCCESSFUL! 11:50:26 : Waiting For Phone on USB PORT/s... 11:50:26 : REQUIRED MODE: BOOTLOADER MODE PHONET MODE 11:50:32 : Battery Voltage Test: PASSED 11:50:32 : 11:50:32 : Ready to Flash Images to Device... 11:50:32 : ========================================= 11:50:32 : Processing Image: cert-sw 11:50:33 : 11:50:33 : ERROR: MEEGO Device Flashing Failed! 11:50:33 : Firmware Version Downgrade NOT ALLOWED 11:50:33 : Please use a HIGHER Firmware Version... whats the way-out please......... cause the firmware am using is the latest... |
11-14-2014, 18:50 | #3 (permalink) |
Member: 1931004 Status: Offline Sonork: 100.1662382 Thanks Meter: 85 | Solution Inside N9 downgrade not allowed - ultimate guide inside !!! by X-shadow |
