04-05-2012, 07:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: algerie Age: 40
Member: 159783 Status: Offline Thanks Meter: 11 | nokia N9 error flash please help me urgen |
04-05-2012, 08:02 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Without posting LOG ? Screenshot , it is useless & waste , so pls Post the operation LOG ? Screenshot Br - srinibas ( ATF Team ) | |
04-05-2012, 11:17 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Tick Skip ADL Chk and Factory Set in ATF SW. Power off phone by pressing power button for a while. Leave phone for next 30 seconds. Press Flash button in ATF SW, and connect just USB cable to phone. It will detect it. If any error, post here logs so we could help you. BR | |
04-05-2012, 12:14 | #4 (permalink) | |
Member: 159783 Status: Offline Thanks Meter: 11 | Quote:
Processing Image File : AD6EE914_DFL61_HARMATTAN_20.2011.40-4.418.2_PR_LEGACY_418_ARM_RM-696_PRD_signed.bin CMT Type : CMT Algorithm : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 1 Entry Point: 0x0045 Page Format : -1 MAX PAGE : 0x00000580 CMT Type : CMT Algorithm : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 1 Entry Point: 0x0045 Page Format : -1 MAX PAGE : 0x00000580 ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Booting/Flashing Failed... Please Try Again... | |
04-05-2012, 13:31 | #5 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: Great India
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | Quote:
Pls use latest version {DFL61_HARMATTAN_30.2012.07-1.333.2_PR_LEGACY_333_ARM_RM-696_PRD_signed } pls chk here...... http://forum.gsmhosting.com/vbb/f609...-done-1453653/ N9 Cannot possible downgrade......... http://forum.gsmhosting.com/vbb/f609...7/#post8270442 Last edited by .::Gsm-Play::.; 04-05-2012 at 13:35. Reason: add link | |
04-05-2012, 17:24 | #6 (permalink) | |
phone not connected with pc | |
04-05-2012, 19:09 | #7 (permalink) |
Member: 1615596 Status: Offline Sonork: 100.160704? Thanks Meter: 760 | Try this...... Tick Skip ADL Chk and Factory Set in ATF SW. Power off phone by pressing power button for a while. Leave phone for next 30 seconds. Press Flash button in ATF SW, and connect just USB cable to phone. It will detect it. If any error, post here logs so we could help you. |
04-06-2012, 18:41 | #8 (permalink) | |
Processing Image File : AD6EE914_DFL61_HARMATTAN_20.2011.40-4.418.2_PR_LEGACY_418_ARM_RM-696_PRD_signed.bin CMT Type : CMT Algorithm : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 1 Entry Point: 0x0045 Page Format : -1 MAX PAGE : 0x00000580 CMT Type : CMT Algorithm : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 1 Entry Point: 0x0045 Page Format : -1 MAX PAGE : 0x00000580 ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Booting/Flashing Failed... Please Try Again... phone not conected with pc | |
04-07-2012, 08:49 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @boumediene 1. Make sure Phone is OFF and is NOT CONNECTED TO USB Port. 2. Click "Flash" Button and wait for this: ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== When you see the message above, then connect the USB Cable to the Phone. Here is the Best Flash File to use: http://forum.gsmhosting.com/vbb/f609...7/#post8270442 |
04-08-2012, 22:51 | #10 (permalink) | |
06-14-2012, 10:18 | #14 (permalink) | |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Quote:
contact me my email ids are in my profile contact me o yahoo or msn etc | |
