04-25-2013, 12:08 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
The Following User Says Thank You to srinibas For This Useful Post: |
04-26-2013, 12:38 | #5 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 345808 Status: Offline Thanks Meter: 21 | Number of Image Files: 2 (Mass Memory File Detected) Processing Image File : A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO Processing Image File : 49C986EE_DFL61_HARMATTAN_40.2012.13-7.INDIA_EMMC_INDIA.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin -F 49C986EE_DFL61_HARMATTAN_40.2012.13-7.INDIA_EMMC_INDIA.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Booting/Flashing Failed... Please Try Again... |
04-26-2013, 15:49 | #7 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Have you follow this ? What is the condition of your phone ? TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. Br - srinibas |
04-27-2013, 07:17 | #8 (permalink) |
Member: 345808 Status: Offline Thanks Meter: 21 | Number of Image Files: 1 Processing Image File : A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 11:59:10 (24-h Time Format) ================================================== ==== like this running that all |
05-23-2013, 15:54 | #10 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | |
12-20-2014, 00:06 | #12 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Narsingdi, Bangladesh
Member: 2166700 Status: Offline Thanks Meter: 13 | Nokia N9 RM-696 Product Code 059K125 i need Nokia N9 RM-696 Product Code 059K125 16gb latest firmware. i am trying to flash with winflasher with verson DFL61_HARMATTAN_30.2012.07-1.280.03.1_PR_LEGACY_280_ARM_RM-696_PRD_signed and A6D5F456_DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM both are telling downgrade not allowed i am giving the full details of winflasher log. Microsoft Windows [Version 6.1.7600] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Program Files\Nokia\Flasher>Flasher.exe -F N9.bin -f -R flasher 3.12.1 (Oct 6 2011) Harmattan WARNING: This tool is intended for professional use only. Using it may result in permanently damaging your device or losing the warranty. Suitable USB interface (bootloader/phonet) not found, waiting... Found device RM-696, hardware revision 1603 NOLO version 2.3.6 Version of 'sw-release': DFL61_HARMATTAN_40.2012.21-3.441.2_PR_441 Sending ape-algo image (7096 kB)... 100% (7096 of 7096 kB, avg. 16619 kB/s) Suitable USB interface (phonet) not found, waiting... Ping attempt 1 (250 ms) Server application: 1.7.2 Found product RM-696 rev. 1603 Server implements softupd protocol version 1.8 Image SW version DFL61_HARMATTAN_40.2012.21-3_PR_005 Image moslo not present Image mmc not present Image tar skipped Image config skipped Battery level 61 %, continuing. image [state progress transfer flash speed] --------------------------------------------------------------------- [_] cert-sw [init 0 % 0 / 0 kB NA ] [ ] cmt-2nd [pending 0 % 0 / 0 kB NA ] [ ] cmt-algo [pending 0 % 0 / 0 kB NA ] [ ] cmt-mcusw [pending 0 % 0 / 0 kB NA ] [ ] xloader [pending 0 % 0 / 0 kB NA ] [ ] secondary [pending 0 % 0 / 0 kB NA ] [ ] kernel [pending 0 % 0 / 0 kB NA ] [ ] rootfs [pending 0 % 0 / 0 kB NA ] ERROR: SU_GET_UPDATE_STATUS_REQ terminated with error code 10: Security failure image [state progress transfer flash speed] --------------------------------------------------------------------- [f] cert-sw [init 0 % 1 / 1 kB NA ] [ ] cmt-2nd [pending 0 % 0 / 0 kB NA ] [ ] cmt-algo [pending 0 % 0 / 0 kB NA ] [ ] cmt-mcusw [pending 0 % 0 / 0 kB NA ] [ ] xloader [pending 0 % 0 / 0 kB NA ] [ ] secondary [pending 0 % 0 / 0 kB NA ] [ ] kernel [pending 0 % 0 / 0 kB NA ] [ ] rootfs [pending 0 % 0 / 0 kB NA ] Fetching error list: ======================================== bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed Downgrade disallowed (1352745221) [Pipe 0] Finishing in error state with status 10 ======================================== ERROR: Failed to flash images |
