10-16-2012, 11:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: SRI LANKA
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | Nokia n9 flash problem ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! Waiting For Phone on USB PORT/s... REQUIRED MODE: PHONET MODE ABOVE LOGS HV DETAILS PHONE DOESNT FLASH HANG WITH RED FONT POSITION |
10-16-2012, 13:58 | #3 (permalink) |
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | phone restart with nokia logo when i plug charge it appear usb icon in top right side and restart with vibrate and blink white colour indicate light on bottom left side |
10-17-2012, 10:21 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @MOBILECHANNEL Tick Factory Set in ATF Software Select MCU+eMMC file Press FLASH button Connect USB cable to POWERED OFF phone Full Flash will take around 20 mins! BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
10-23-2012, 11:41 | #8 (permalink) |
Member: 746449 Status: Offline Sonork: 100.1603972 Thanks Meter: 171 | Waiting For Phone on USB PORT/s... 13:52:50 : REQUIRED MODE: BOOTLOADER MODE PHONET MODE 13:53:03 : Sending APE-ALGORITHM: SUCCESSFUL 13:53:03 : Nokia Bootloader/PhoNet Found! 13:53:06 : Waiting For Phone on USB PORT/s... 13:53:06 : REQUIRED MODE: PHONET MODE 13:53:08 : Battery Voltage Test: PASSED 13:53:08 : 13:53:08 : Ready to Flash Images to Device... 13:53:08 : ========================================= 13:53:08 : Processing Image: cert-sw 13:53:08 : Processing Image: cmt-2nd 13:53:11 : Processing Image: cmt-algo 13:53:12 : Processing Image: cmt-mcusw 13:53:12 : Processing Image: xloader 13:53:12 : Processing Image: secondary 13:53:12 : Processing Image: kernel 13:53:18 : Processing Image: rootfs 14:01:27 : Processing Image: mmc 14:08:55 : ========================================= 14:08:55 : All Images were Succssfully Uploaded! 14:08:55 : Software Update Done 14:08:55 : 14:08:58 : []: Found 1 active devices. 14:08:58 : [Nokia N900 USB Phonet]: Opening Connection 14:08:58 : [Nokia N900 USB Phonet]: Port opened OK! 14:08:58 : Rebooting Phone... 14:08:58 : 14:08:58 : Total Flashing Time (Erase + Flashing) : 00:16:06 14:08:58 : (Booting time is NOT Included) |
