08-07-2013, 05:06 | #1 (permalink) |
Freak Poster Join Date: Mar 2011 Location: in BIGSERVER
Member: 1542932 Status: Offline Sonork: 100.1621006 Thanks Meter: 53 | nokia n9 flashing problam Code: ====================================================== ====================================================== BB5 MEEGO / HARMATTAN FLASHER ====================================================== ====================================================== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ====================================================== ====================================================== Sending PRIMARY-BOOT: SUCCESSFUL! Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending SECONDARY-BOOT: SUCCESSFUL! ====================================================== SECURE USER DATA ERASING IN PROGRESS ====================================================== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated time to Finish Erasing: 09:47:29 (24-h Time Format) ====================================================== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs ERROR: MEEGO Device Flashing Failed! Booting/Flashing Failed... Please Try Again... |
