01-07-2014, 14:10 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | nokia n9 flashing problem set having user code i download latest file same product code Number of Image Files: 1 Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTROM MODE Sending PRIMARY-BOOT: SUCCESSFUL! Booting/Flashing Failed... Please Try Again... |
01-07-2014, 14:15 | #2 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Number of Image Files: 1 Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! Waiting For Phone on USB PORT/s... REQUIRED MODE: PHONET MODE Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Booting/Flashing Failed... Please Try Again... |
