03-18-2010, 19:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2005
Member: 129208 Status: Offline Sonork: 100.113419 Thanks Meter: 10 | Nokia n95 8gb flash problem [SOLVED] I HAVE ATTACHED THE LOG FOR THE NOKIA N95-8 GB. PHONE IS DEAD AFTER FLASHING AND IT IS KIND OF STUCK DURING THE ERASE .... HELP IS REQUIRED REGARDS, K Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_20.0.016_PR.C0R CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 611 Entry Point: 0x0266 Page Format : -1 MAX PAGE : 0x00020000 AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Init TRY : 2 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 4679992 (0x38) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 ALGO FILE : C:\Documents and Settings\uzair\My Documents\Downloads\AdvanceBox_BETA_V3\AdvanceBox_BETA_V3\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000003000000000000040000000203A4000003500000000000080000000106F400000894000000000009000000010F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x0063 (99) ERASE Blocks : 0x0002 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-007CFD95 1 : 00000000-0005FFFF 2 : 00880000-00FDFFFF ERASE_REQUEST_BB5 : 5003120B00000000080000007CFD95120B000000000000000005FFFF120B0000000088000000FDFFFF09 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Last edited by Javajohn; 03-18-2010 at 20:44. |
03-18-2010, 20:27 | #3 (permalink) |
Member: 129208 Status: Offline Sonork: 100.113419 Thanks Meter: 10 | THANK YOU FOR YOUR QUICK REPLY. THIS IS THE LOG AFTER I FLASHED THIS DISREGARDING THE TURBO FLASHING .... SAME OUT COME PHONE STILL DEAD.... Code: AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Init TRY : 2 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_15.0.015_PR.C0R CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 609 Entry Point: 0x0266 Page Format : -1 MAX PAGE : 0x00020000 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 009C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for APE Boot File.. SearchForBootstrap_DCT5... APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) done fur ape MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000002E0000000000004000000020384000003700000000000080000000106F400000894000000000009000000010F880000001A000098 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x0063 (99) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-007CA529 1 : 00000000-0005FFFF 2 : 00880000-00FDFFFF CurrPos : 20 CurrEraseLen : 43 1 ERASE_AREA_BB5 0x12 Block Length : 0x43 (67) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000200-0000AFFF 1 : 0000B800-000AFFFF 2 : 00000000-00001000 3 : 0000D800-0000EA00 4 : 00080000-000BFFFF 5 : 000E0000-0045FFFF 6 : 004C0000-0073FFFF 7 : 00A40000-06F3FFFF ERASE_REQUEST_BB5 : 5003120B00000000080000007CA529120B000000000000000005FFFF120B0000000088000000FDFFFFCD Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ERASE_REQUEST_BB5 : 5008120B010100000002000000AFFF120B0101000000B800000AFFFF120B0101000000000000001000120B0101000000D8000000EA00120B01010000080000000BFFFF120B010100000E00000045FFFF120B010100004C00000073FFFF120B01010000A4000006F3FFFF03 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:47 Is Flashing CLOCK AUTO : -1 Processing : RM-320_15.0.015_PR.C0R Total blocks to write : 609 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS+UPDAPP >> APE Rootkey Hash CERT : SOS+CORE >> APE Rootkey Hash CERT : SOS+ROFS ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:24 Making delay between files for 1000ms AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_15.0.015_PR.v01 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 150 Entry Point: 0x0159 Page Format : -1 MAX PAGE : 0x00020000 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 009C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for APE Boot File.. SearchForBootstrap_DCT5... APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) done fur ape MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 02E00000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000000200A4000002E0000000000004000000020384000003700000000000080000000106F400000894000000000009000000010F880000001A000098 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 05140000-06F3FFFF ERASE_REQUEST_BB5 : 5001120B0101000514000006F3FFFFCF Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Is Flashing CLOCK AUTO : -1 Processing : RM-320_15.0.015_PR.v01 Total blocks to write : 150 >> APE Rootkey Hash CERT : SOS+ROFX ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:17 Making delay between files for 1000ms AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_15.0.009_014_xxx_U05_uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 400C192101011103 > 400C192101021103 > 4003192101021103 > 400C192101021105 > 4003192101021105 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 132 Entry Point: 0x00CF Page Format : -1 MAX PAGE : 0x00020000 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME START HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 009C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for APE Boot File.. SearchForBootstrap_DCT5... APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) done fur ape MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x001D (29) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 06F40000-0F87FFFF CurrPos : 10 CurrEraseLen : 0D 1 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x01 APE ERASE_REQUEST_BB5 : 5001120B01010006F400000F87FFFF51 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001130D01534F532D55534552000000007C Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:03 Is Flashing CLOCK AUTO : -1 Processing : RM320_15.0.009_014_xxx_U05_uda.fpsx Total blocks to write : 132 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:18 Making delay between files for 1000ms Total Flashing Time (Booting + Erase + Flashing) : 00:03:05 Last edited by Javajohn; 03-18-2010 at 20:42. |
03-18-2010, 20:47 | #5 (permalink) |
Member: 129208 Status: Offline Sonork: 100.113419 Thanks Meter: 10 | MANY THANKS TO JAVAJOHN FOR HIS QUICK REPLY PHONE IS ALIVE. AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Init TRY : 2 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK Reading Phone Information... ERROR : PHONE READ INFO FAILED ERROR : FAILED TO BACKUP, TRY AGAIN... Changing MODE : FLASH AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 009C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for APE Boot File.. SearchForBootstrap_DCT5... APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) done fur ape MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Pabub KEY Request No PAPUBKeysHash Returned START READING RPL DATA Reading : NPC OK Reading : VARIANT No VARIANT for this phone / empty Reading : CCC No CCC for this phone / empty Reading : HWC No HWC for this phone / empty Reading : R&D No R&D for this phone / empty FINISHED READING RPL DATA RPL saved to: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\backup\3355739027354921\335573902735 4921_73931.rpl Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_35.0.001_PR.C0R CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 51000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 441 Entry Point: 0x026E Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_35.0.001_PR.v22 CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 71 Entry Point: 0x0159 Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_31.0.002_025_zzz_U03_uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101021103 > 400C192101021103 > 4003192101002003 > 400C192101002003 > 400C192101011103 > 4003192101011103 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP2420 UNISTORE-II-1.5.1 ALG APE Supported Hardwares : > 24200705 Number of Blocks : 145 Entry Point: 0x00D7 Page Format : -1 MAX PAGE : 0x00030000 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. v2010.0.1.22 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.22 AdvanceBox SN : DE4ABC3080AF8AB8C18D9184 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 11 (0x0B) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 24200705 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 8D80EF9C ID DWORD 1 : 2680097D ID DWORD 2 : AF2D36B8 ID DWORD 3 : 4BE87D86 ID DWORD 4 : 9EE48E1F 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : BA 87 10 A7 E1 CD 5A 29 09 B9 A8 75 DB 27 AA 24 00 00 00 00 5 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 6 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 8 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 06500102 ID DWORD 1 : 2C730052 ID DWORD 2 : 68577A59 ID DWORD 3 : AEDB2485 ID DWORD 4 : 23C982B5 9 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 10 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 11 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum C3 BootCodeLen : 9A SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 04 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 2C7E -> 72NS128N Extended/Fixed ID : 0000 Revision ID : 6921 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :2C7E ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 2C7E Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00100000 (1048576) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 9A E3 SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 009C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for APE Boot File.. SearchForBootstrap_DCT5... APE Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA2" FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) done fur ape MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 01 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00010000 (65536) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPP INFO : C: \Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\OMAP2420_XSR15_alg.fg Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : APE 1 Certificate 2 Name : HWC ASIC Index : APE 1 Certificate 3 Name : CCC ASIC Index : APE 1 Certificate 4 Name : R&D ASIC Index : APE 1 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 01 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 01 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 01 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 01 CF STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000 000200A4000003000000000000040000000203A40000035000 00000000080000000106F40000089400000000000900000001 0F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 0004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 2 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 3 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 Partition 4 ID : 00000003 COPIEDOS Attribute : 00000002 Start Address : 00A40000 Size : 03000000 PARTITION_INFO_REQUEST_BB5 : 64012F4F01010000010000FFFFFFFF00000004000000030000 000200A4000003000000000000040000000203A40000035000 00000000080000000106F40000089400000000000900000001 0F880000001A000077 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) No partition info.... StartErase_DCT5... BlockLength : 0x0063 (99) ERASE Blocks : 0x0002 (2) erase blocks : 2 CurrPos : 03 CurrEraseLen : 1B 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00080000-007CF385 1 : 00000000-0005FFFF 2 : 00880000-00FDFFFF CurrPos : 20 CurrEraseLen : 43 1 ERASE_AREA_BB5 0x12 Block Length : 0x43 (67) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 00000200-0000AFFF 1 : 0000B800-000AFFFF 2 : 00000000-00000FFF 3 : 0000D800-0000E9FF 4 : 00080000-000BFFFF 5 : 000E0000-0045FFFF 6 : 004C0000-0073FFFF 7 : 00A40000-06F3FFFF ERASE_REQUEST_BB5 : 5003120B00000000080000007CF385120B0000000000000000 05FFFF120B0000000088000000FDFFFF23 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 ERASE_REQUEST_BB5 : 5008120B010100000002000000AFFF120B0101000000B80000 0AFFFF120B0101000000000000000FFF120B0101000000D800 0000E9FF120B01010000080000000BFFFF120B010100000E00 000045FFFF120B010100004C00000073FFFF120B01010000A4 000006F3FFFF07 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) erase blocks : 1 CurrPos : 03 CurrEraseLen : 0B 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 0 : 05140000-06F3FFFF ERASE_REQUEST_BB5 : 5001120B0101000514000006F3FFFFCF Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:48 Is Flashing CLOCK AUTO : -1 //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// Processing : RM-320_35.0.001_PR.C0R Total blocks to write : 441 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS+UPDAPP >> APE Rootkey Hash CERT : SOS+CORE >> APE Rootkey Hash CERT : SOS+ROFS Processing : RM-320_35.0.001_PR.v22 Total blocks to write : 71 >> APE Rootkey Hash CERT : SOS+ROFX Processing : RM320_31.0.002_025_zzz_U03_uda.fpsx Total blocks to write : 145 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:02:03 Total Flashing Time (Booting + Erase + Flashing) : 00:02:57 REGARDS, KHURRAM |
nokia n95 8gb memoire problem | dindou78 | Nokia Base Band 5 ( BB-5 ) | 3 | 08-13-2011 04:19 |
Nokia N95 8GB LCD Problem | feraso | Nokia Hardware & Hardware Repair | 14 | 09-04-2010 06:51 |
Nokia n95 8gb sync problem | babarog | Nokia Base Band 5 ( BB-5 ) | 0 | 09-15-2008 18:17 |
