03-02-2013, 07:49 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | nokia n9error flashing..... Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 12:26:18 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Booting/Flashing Failed... Please Try Again... |
03-06-2013, 15:18 | #4 (permalink) |
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | rootfs stage error come.. pls tell me solution............ ========================================= Processing Image: cert-sw Processing Image: cmt-2nd Processing Image: cmt-algo Processing Image: cmt-mcusw Processing Image: xloader Processing Image: secondary Processing Image: kernel Processing Image: rootfs ERROR: MEEGO Device Flashing Failed! Booting/Flashing Failed... Please Try Again... |
03-06-2013, 15:31 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, 1. Flash with same Product Code files and it must be 16gb or 64gb according to your phone 2. Use both files MCU and eMMC + Tick Factory Set in ATF Software 3. Make sure phone's battery is charged enough 4. If still the same error, you can also try on it's original flasher - will find on Google 5. Check phone's hardware, if you are getting same error. BR |
