09-26-2012, 09:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | Nokia try...than restart problem lumia 800 unlock |
09-26-2012, 09:58 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
atf 9.12 also cant unlock my lumai 800 Flash phone with suggested firmware <<<<<<<<IMPORTANT INFORMATION BEFORE YOU TP UNLOCK LUMIA 800 RM-801 or RM-819>>>>>>>> Br - srinibas | |
09-27-2012, 07:15 | #3 (permalink) |
Member: 1263622 Status: Offline Thanks Meter: 149 | unlock failed lumia 800 Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : DD91B224 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... ERROR: Dump Aborted, Too Much Read Failures! Total Elapsed Time 00:01:02 Now set dead not power on ......how to power on my set any idea need ???? |
09-27-2012, 08:21 | #4 (permalink) |
Member: 1263622 Status: Offline Thanks Meter: 149 | [QUOTE=Rotan Sarkar;8791842]unlock failed lumia 800 Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : DD91B224 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... ERROR: Dump Aborted, Too Much Read Failures! Total Elapsed Time 00:01:02 Now set dead not power on .................how to power on my set any solution need ????????? |
09-27-2012, 08:41 | #5 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | I think you have not solder the TP properly . Attach a photo of TP connection with RJ 45 cable . Use small length jumper wire Br - srinibas |
09-27-2012, 11:41 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | [QUOTE=Rotan Sarkar;8792051] Quote:
Its TOSHIBA Flash chip phone. Use ATF v9.12 for it. BR | |
09-27-2012, 12:42 | #7 (permalink) | |
Member: 1263622 Status: Offline Thanks Meter: 149 | lumia...800...dead....solution...need Quote:
thanks sir.........for........reply..........tp.......con nection ok.....because......boot..repair.......done....wit h..atf..box.........other......solution...give..me ...plz | |
09-27-2012, 12:52 | #8 (permalink) |
Member: 1263622 Status: Offline Thanks Meter: 149 | [QUOTE=..::Angel::..;8792825] thanks....sir....for.......reply...........i...kno w..&.im..see...its....toshiba flash....chip........so........im......try.......v 9.12.....but...problem....same...other.....tested idea....need....................??? |
09-27-2012, 13:41 | #9 (permalink) |
Member: 1263622 Status: Offline Thanks Meter: 149 | lumia...800...unlock.........failed...than.....res tart.....problem Help me lumia 800 unlock try......with tp atf box... tp connection ok but unlock failed .....now set power on than only show nokia logo...with restart ....how to solved that problem any idea give me plz ???????? |
09-27-2012, 14:53 | #10 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | [QUOTE=Rotan Sarkar;8793087] Quote:
Repair boot ten try to unlock Post the log of Boot repair & unlock V9.12 Br - srinibas | |
09-27-2012, 15:40 | #11 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Rotan Sarkar 1. First Flash You phone with good version as suggested here: http://forum.gsmhosting.com/vbb/f609...819-a-1540417/ FULL FLASHING will Fix your Nokia....Restart Problem 2. Make your TP Wires shorter, like maximum 5 inches or shorter. 3. Check area where you soldered the TP wires, check the resistors on those area as they may have dislodged during your soldering. 4. TP Unlock the Phone |
