08-24-2014, 17:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | Nokia X A110 flashing problem i've follow soft instruction does this set require a dead boot repaire procedure ?? |
The Following User Says Thank You to temp_temp For This Useful Post: |
08-24-2014, 18:14 | #2 (permalink) |
Member: 570252 Status: Offline Thanks Meter: 207 | i've sucssesfuly done boot repair Code: Default language ID 0x040C JTAG Interface Connected, S/N fffffffffffffffffff Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 16/07/2014 12:23:00 ========================================================== Phone Type : Nokia X [RM-980] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.1.2.2 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Samsung S5XKMB, 3.64 GiB Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (92056 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 29s. Code Download Speed 231 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= |
08-24-2014, 18:37 | #3 (permalink) |
Member: 570252 Status: Offline Thanks Meter: 207 | phone power normal after that other problem i've found is that atf soft do not detact phone but other android soft do !!!! Code: Shutting Down ADB Server... If your Phone is still not detected by ATF Software, manually End Process adb.exe in Windows Task Manager... Scanning USB Ports... ====================================================== ERROR: Active Phone Handle was NOT DETECTED ====================================================== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ====================================================== ====================================================== Selected VPL File: RM980_059T9D8_1.2.4.1_137.vpl ====================================================== Variant Details : RM-980 NDT EURO PL Software Version : 1.2.4.1 Product Type : RM-980 Product Code : 059T9D8 Variant Version : 137 Code: Connect the device successfully, the information of the device is as follows: Model: Nokia_X Android version: 4.1.2 Baseband: 8X25-SSRSKOLYM-3072 IMEI1: 35306106066**** >> The above information is for reference only. |
08-25-2014, 04:49 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @temp_temp Because your "other" android software is using ADB.exe and ATF always tries to shut down adb.exe before it tries to read the phone. In in any case you have other software running adb.exe, then ATF cannot shut it down, so ATF cannot read your phone. So Solution is just close your "other" android software and make sure adb.exe is not running in System Processes. Another issue would be is that your phone already has 1.2.4.1 firmware inside, in this this case the VID/PID was changed by Micro****. So Solution is to manually update to ATF 11.69 by downloading this: http://www.4shared.com/download/01RD....exe?lgfp=3000 Then put this on your: C:\AdvanceBox Turbo Flasher\ (overwrite older file) B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
