Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-20-2014, 08:20   #1 (permalink)
Member: 1273573
Sonork: 100.1623251 QQ.2905713135
Thanks Meter: 3,780
Nokia X Atf Tools Cant Flash & No Reply Atf Team - (CHECK 11.45) - (11/15)
nokia x flashing error 62%
plz fix this 62% error
im try to unmark 2 file flash done but nokia log hang
No Reply Atf Team All Atf User W8 For Reply
aother tool done nokia x
need help atf team for all atf user
so sory im bad english
Old 06-20-2014, 08:30   #2 (permalink)
dust2dust's Avatar
Member: 1284799
Sonork: 100.1649097
Thanks Meter: 138
post the whole logs, maybe they will reply.
Old 06-20-2014, 08:34   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@zulfqarali
Special Update for you:
http://forum.gsmhosting.com/vbb/f475...014-a-1828682/
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 06-20-2014, 09:28   #4 (permalink)
Member: 1273573
Thanks Meter: 3,780
Originally Posted by Advance-Box View Post
@zulfqarali
B.R.
Thanks & Very Very Thanks Sir for Reply & Special Update for me:
Sir Im Try to Fash Nokia X With Atf Ver.11.45 & Post Result
Thanks Atf Team
The Following User Says Thank You to zulfqarali For This Useful Post:
Old 06-20-2014, 09:30   #5 (permalink)
Tiểu Đệ's Avatar
Member: 1294842
Sonork: 100.1651073vs100.1649413
Thanks Meter: 47
HI team share link full setup Atf Ver.11.45 .big thank
Old 06-20-2014, 09:33   #6 (permalink)
Member: 1273573
Thanks Meter: 3,780
Download ATF 11.45 via the AUTOUPDATE SERVER!!!
Old 06-20-2014, 09:35   #7 (permalink)
Tiểu Đệ's Avatar
Member: 1294842
Thanks Meter: 47
down update not done
Old 06-20-2014, 10:08   #8 (permalink)
Member: 1273573
Thanks Meter: 3,780
sucssfull 100%
try this
Old 06-20-2014, 12:46   #9 (permalink)
Member: 1273573
Thanks Meter: 3,780
Nokia x RM 980 Flash don with 11.45 !!!
Nokia x flashing don with great atf
log
Nokia Android Phone Flashing Started
Nokia Android Firmware Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Press and Hold the VOLUME UP button
2. Connect it to the USB Port while still Pressing
3. Continue to Press the VOLUME UP button for 15
more seconds
Establishing Connection...
Rebooting to Bootloader...
Waiting for Bootloader...
Processing QCSBL CONFIG
Initiating File Download...
Start Sending Blocks...
All Blocks Sent: OK
Writing to eMMC...
All Blocks Written: OK
Processing QCSBL
All Blocks Sent: OK
Writing to eMMC...
Processing MODEM
All Blocks Sent: OK
Writing to eMMC...
Processing OEMSBL HEADER
All Blocks Sent: OK
Writing to eMMC...
Processing OEMSBL
All Blocks Sent: OK
Writing to eMMC...
Processing APPSBOOT HEADER
All Blocks Sent: OK
Writing to eMMC...
Processing APPSBOOT
All Blocks Sent: OK
Writing to eMMC...
Processing BOOT
All Blocks Sent: OK
Writing to eMMC...
Processing RECOVERY
All Blocks Sent: OK
Writing to eMMC...
Processing PERSIST
All Blocks Sent: OK
Writing to eMMC...
Processing SYSTEM
All Blocks Sent: OK
Writing to eMMC...
Processing VARIANT
All Blocks Sent: OK
Writing to eMMC...
Processing CACHE
All Blocks Sent: OK
Writing to eMMC...
Processing USERDATA
All Blocks Sent: OK
Writing to eMMC...
Processing UDISK
All Blocks Sent: OK
Writing to eMMC...
Processing PRELOAD
All Blocks Sent: OK
Writing to eMMC...
Flashing Done!
Total Flashing Time (Erase + Flashing) : 00:05:23
Rebooting to Normal Mode
Thanks Atf Team
thanks atf team
@zulfqarali
B.R.
Advance Turbo Flasher Found
Driver Version : 00020814
Library Version : 00030204
Box Type : ATF Nitro
Box Firmware : LogiCore 11.0.00
Software Version : v11.45
AdvanceBox SN : 818F55B2EF2093E09BD12855
Box Status : ACTIVATED
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 06-24-2014, 17:29   #10 (permalink)
Member: 458017
Thanks Meter: 7
110 error
sir
nokia 110 flashing 4th section very slow flashing 32% to 100% then error in aft
tested in 2working handsets in same problem
32% to 100% processing time more than 2hoers
whats the problem... tel me any solution
[email protected]
Page generated in 0.23857 seconds with 9 queries
