01-30-2016, 16:21 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | Nokia X EMMC Repair error Tried jtag not success Tried emmc repair via tp on board not success Now trying to repair direct emmc again error Samsung Emmc - KMS5X000KM-B313 Can any budy help me here ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E |
01-30-2016, 18:38 | #2 (permalink) |
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | While Force Firmware upgrade ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E Task Selected: Samsung eMMC Firmware Update ================================================== ==== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ================================================== ==== Please Manually Select the Correct Part Number of your eMMC Device. ================================================== ==== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ================================================== ==== ================================================== ==== Loading ATF eMMC Firmware File... (Please Wait) ================================================== ==== File Author: ATF Team @ X-Shadow Date Created: 22/04/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMS5X000KM-B313 eMMC Product Name: S5XKMB eMMC Product Rev: 0.1 Preparing eMMC for Firmware Update... ERROR: CUSTOM_VENDOR_COMMAND FAILED 0x03 Total Elapsed Time 00:00:00 |
