07-05-2014, 19:31 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: hang on logo
Member: 272814 Status: Offline Thanks Meter: 43 | nokia X flashing problem |
07-05-2014, 20:28 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @muhanadhameedah Yeah... you cannot flash V2 flash files to none V2 phones... ATF actually warns you that you are not suppose to flash it... You need to click OK 3 times before it allows you to flash it... So it means you are TOTALLY AWARE of what you are getting yourself in... Also, you KILLED 5 phones before realizing something was WRONG? Come on bro... Anyway, you are in LUCK, you can fix all those phones via eMMC Boot Repair (100 % FREE via ATF Box) Check out the eMMC Boot Repair Files here: http://forum.gsmhosting.com/vbb/f609...links-1830880/ Just load .mmc file via ATF Plus ----> eMMC Tool, and it will show you pinouts. Next time follow ATF Warning Messages... because we put them there for a very GOOD Reason. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
07-05-2014, 21:37 | #3 (permalink) |
Member: 272814 Status: Offline Thanks Meter: 43 | ok thanks sir , but how to phone type if it is v2 or non v2 if there is software problem and can not check type....in other word how to determine the v type, can i know it from product code..thanks Last edited by muhanadhameedah; 07-05-2014 at 21:43. |
07-06-2014, 03:23 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | If you used ATF to flash those phones, then you should already know how to check V2 and none V2 phones because ATF software tells you how to check. The safest way is to only flash the phone with flash files matched to product code on back sticker. |
