08-04-2015, 03:52 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: TUNISIA Age: 41
Member: 479816 Status: Offline Thanks Meter: 851 | Nokia x repair boot via usb... port com is "Qualcomm HS-USB Diagnostics 9006" and Qualcomm MMC Storage found but i have error. log : ERROR: Qualcomm MMC Storage USB is NOT FOUND Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Partitions Found: 0 |
08-04-2015, 08:49 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
If you are working with Windows XP or you do not have ADMIN rights, you can try this other EXE which I made: http://174.120.45.27/tmp/AdvanceBox_XP.rar Extract It to "C:\AdvanceBox Turbo Flasher\" or where you installed the ATF software... Then run it.. It should detect your 9006 now... | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
