11-12-2015, 10:52 | #16 (permalink) |
Crazy Poster Join Date: Jan 2012 Location: MS Repairing zone Karachi Age: 42
Member: 1712378 Status: Offline Thanks Meter: 1 | Card found: S/N : EA6B7464 , v0122 Registered to: asadnow2k Connect phone on selected interface... Core : v2.13 , NXP FlashEngine : v5.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode File : RM980_1.2.4.3_qcsblhd_cfgdata.mbn not found , break Some files absent or not passed check ! Use NaviManager and Re-download files according selected product code ! Core : v2.13 , NXP FlashEngine : v5.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode File : RM980_1.2.4.3_qcsblhd_cfgdata.mbn not found , break Some files absent or not passed check ! Use NaviManager and Re-download files according selected product code ! Core : v2.13 , NXP FlashEngine : v5.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode File : RM980_1.2.4.3_qcsblhd_cfgdata.mbn not found , break Some files absent or not passed check ! Use NaviManager and Re-download files according selected product code ! Core : v2.13 , NXP FlashEngine : v5.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode File : RM980_1.2.4.3_qcsblhd_cfgdata.mbn not found , break Some files absent or not passed check ! Use NaviManager and Re-download files according selected product code ! |
02-22-2016, 08:39 | #19 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 532257 Status: Offline Sonork: 1624266 Thanks Meter: 64 | nokia sucesfuly flash infinty log here Card found: S/N : 3503995F , v0129 Registered to: faisal123 Connect phone on selected interface... Core : v2.19 , NXP FlashEngine : v5.1 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_11.1.1_059T982_APAC_VN_variant.img Ok, Set : RM980_11.1.1_boot.img Ok, Set : RM980_11.1.1_cache.img Ok, Set : RM980_11.1.1_emmc_appsboot.mbn Ok, Set : RM980_11.1.1_emmc_appsboothd.mbn Ok, Set : RM980_11.1.1_fat.bin Ok, Set : RM980_11.1.1_oemsbl.mbn Ok, Set : RM980_11.1.1_oemsblhd.mbn Ok, Set : RM980_11.1.1_persist.img Ok, Set : RM980_11.1.1_preload.img Ok, Set : RM980_11.1.1_qcsbl.mbn Ok, Set : RM980_11.1.1_qcsblhd_cfgdata.mbn Ok, Set : RM980_11.1.1_recovery.img Ok, Set : RM980_11.1.1_system.img Ok, Set : RM980_11.1.1_udisk.bin Ok, Set : RM980_11.1.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.19 , NXP FlashEngine : v5.1 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM980_11.1.1_059T982_APAC_VN_variant.img Ok, Set : RM980_11.1.1_boot.img Ok, Set : RM980_11.1.1_cache.img Ok, Set : RM980_11.1.1_emmc_appsboot.mbn Ok, Set : RM980_11.1.1_emmc_appsboothd.mbn Ok, Set : RM980_11.1.1_fat.bin Ok, Set : RM980_11.1.1_oemsbl.mbn Ok, Set : RM980_11.1.1_oemsblhd.mbn Ok, Set : RM980_11.1.1_persist.img Ok, Set : RM980_11.1.1_preload.img Ok, Set : RM980_11.1.1_qcsbl.mbn Ok, Set : RM980_11.1.1_qcsblhd_cfgdata.mbn Ok, Set : RM980_11.1.1_recovery.img Ok, Set : RM980_11.1.1_system.img Ok, Set : RM980_11.1.1_udisk.bin Ok, Set : RM980_11.1.1_userdata.img File HW revision is : HW Revision V1 Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 7073D648 Processing : RM980_11.1.1_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_11.1.1_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM980_11.1.1_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM980_11.1.1_059T982_APAC_VN_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:04:41 Reboot phone Ok Connect phone on selected interface... Phone found! Nokia X Platform Phone detected (ADB) Read info... Ok Reading Phone Info.... Software (AOSP ver) : 4.1.2 , NXP : 11.1.1 Phone : RM-980 , Nokia_X PrCode : 059T982 HW Revision : HW Revision V1 HWVer : 0401 Serial : 7073d648 Kernel : Linux version 3.4.0-perf (ZYC@build162) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Mar 7 17:01:02 CST 2014 RootSt : Not Rooted Done! Phone disconected! Connect phone on selected interface... |
