09-18-2014, 13:07 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Nokia X still dead - (SOLVED) when i connect usb on device manager detect qualcom hs usb 9008 Code: Default language ID 0x0421 JTAG Interface Connected, S/N 0xC1C06B4C Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 16/07/2014 12:23:00 ========================================================== Phone Type : Nokia X [RM-980] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.1.2.2 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...1501005335584B4D4201C08DD4A031DE Flash Description: Samsung S5XKMB, 3.64 GiB, SN C08DD4A0, Mar 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91438 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 25s. Code Download Speed 240 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= |
The Following User Says Thank You to mr.omphonx For This Useful Post: |
09-18-2014, 13:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mr.omphonx Hi, This means your Phone is "V2" So confirm this is a "V2" phone, check the product code of the phone in the back sticker and see if it is in this list: http://forum.gsmhosting.com/vbb/10422257-post4.html If it is on that list, then your phone is really a V2 phone which means you need to use this: NOKIA_X_V2_RM-980_FULL_BOOT_1.1.3.20.afp B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
09-19-2014, 18:36 | #8 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 747697 Status: Offline Thanks Meter: 16 | wow good job mr.omphonx jadi duit euy wkkk |
09-19-2014, 20:23 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @mr.omphonx: so what was the problem? Post here for other users who might face similar problem. |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
09-20-2014, 15:27 | #10 (permalink) |
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | i dont know maybe im luck ..... i want to dump emmc with direct emmc but not connect then i try again to repair boot with this file NOKIA_X_RM-980_FULL_BOOT_1.1.2.2.afp after repair boot phone stuck on logo then reflash phone with same version with boot and phone alive |
10-08-2014, 08:57 | #11 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Quote:
Code: NOKIA_X_V2_RM-980_FULL_BOOT_1.1.3.20.afp | |
10-08-2014, 09:45 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @xerraco It is not dead, but only updated. Check new listing here: http://forum.gsmhosting.com/vbb/10399783-post1.html B.R. |
