09-21-2013, 09:08 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | Nokia x2-00 showing contact service after i select accept Number of Image Files: 3 Processing Image File : rm618__08.35.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 511 Entry Point: 0x01E5 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm618__08.35.ppm_mh CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 117 Entry Point: 0x0100 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm618__08.35.image_mh_0595236 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 378 Entry Point: 0x0134 Page Format : -1 MAX PAGE : 0x0000E000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005361 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00FAF27E ID DWORD 2 : 07DB51DF ID DWORD 3 : 79ED8C2F ID DWORD 4 : B2C14078 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg .fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 80106F00 FUR control Ok 0000000B START READING RPL DATA 0000081D IMEI: 356236049680176 Reading : NPC... OK! 0000000B 00000415 Reading : CCC... OK! 00000415 Reading : HWC... OK! 00000415 Reading : R&D... OK! 0000000B 0000000B NPC CERTIFICATE INFORMATION (CMT): IMEI : 356236049680176 PRODUCT CODE : 059F8H0 BLUETOOTH ID : D4:5D:42:75:87:4D PUBLIC_ID : 0000000000FAF27E07DB51DF79ED8C2FB2C14078 PAPUB_KEYS_HASH: E9700989029D9E899915F781B1582048E042A738 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059F8H0 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 0000000000FAF27E07DB51DF79ED8C2FB2C14078 PRODUCT CODE : 059F8H0 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356236049680176\3562360496801 76_13423.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 00007883 Reading : ISA-USER... OK! 004D5050562030382E31370A30392D30332D31310A524D2D36 31380A286329204E6F6B696120202020202020202020202000 FFFFFFFFFFFFFFFFFFFFFFFFFFFF4D4800005C027664E42E08 005458455438433932313036005C000000A6030000434F4D4D 800000001005050A0B0F050C01090701050B0707070B080705 080908050F07070501010608050E19050506060A0005010003 0E1E05081701030B06FF500075007200630068006100730069 006E006700200064006100740065003A004E006F006B006900 6100670A2000680A2000690A4C006900660065002000740069 006D00650072004E006500740020006D006F006E0069007400 6F00720043006100720072006900650072002000750070006C 006F00610064002E004E006F00720073006B0049006E007600 61006C006900640020006400610074006500902150006F0072 007400750067007500EA0073000C0165006101740069006E00 61009121440061006E0073006B0045006E0074006500720020 0064006100740065003A004500730070006100F1006F006C00 45006E0067006C006900730068004F00760069002E0063006F 006D005400650073007400200069006E007000750074003A00 CD0073006C0065006E0073006B006100440065007500740073 0063006800F1060C20F2060C20F30657006100720072006100 6E0074007900520065007000610069007200650064003A0049 00740061006C00690061006E006F00530075006F006D006900 410070006F0069006F0020006100200043006C00690065006E 00740065005300760065006E0073006B0061006F2031002000 3200200033006E20E70A2000E80A2000E90A2A0092216D006D 0079007900790079004600720061006E00E700610069007300 4D006100640065003A00530065007200690061006C0020006E 0075006D006200650072003A00500072006F00640075006300 740069006F006E002000730065007200690061006C0020006E 0075006D00AD00620065007200530061007600650064006709 200068092000690950006F006C0073006B0069005400FC0072 006B00E70065004E0065006400650072006C0061006E006400 7300E70C2000E80C2000E90C2300E117E217E317470072006F 00750070002F0064006900730070006C00610079003A005300 6100760069006E00670020006600610069006C00650064002C 00200063006F006E0074006100630074002000730065007200 76006900630065004D0079003100390031009503BB03BB03B7 03BD03B903BA03AC035400650073007400200069006E002000 52004E00440049005300200055005300420020006D006F0064 0065003F009321610662066306410074002E00200043006C00 690065006E00740065004D0061006700790061007200FFFF01 000000900B0200454E303098000000002000650074006F0061 006E006900730072006C00640063006D007500670070006800 7900660076002E007700620053004D006B004E004300550025 004100500049003A004400520054003F004C0078004F003100 460022002C0045004200300047002D206F206E000A00560071 00570029004800280027002F0032007A0059006A0023004B00 33002A00AD004A003413FA280F4C18F4E2172009D3CB7E00D2 1E090BF90DF917111506E4FE1900030F08EF2C005DBC0A0A18 CCC2E415ED00D1F7131A8EF3CFFE070413F608CCCE06E9F70B 7AB591FEF50B04110BFDBBEA35060F101EECF4BF1D2FB1071E 0A030CE300A4F60504050D060812EDA8DF05D7AEC62403FC00 17042D0509031F100EFE06139EE0C30C060E13E48DB7BDCE01 150CED0D0818C5EA0BD80004070D0F00150CFE001602071D1A 06041B10040B190117F001BE13FE0C04E5C51E0D0C01170104 0AF505000F13060B1002080D07C7F1FDFE0B0102F2B3B426CF E9D40C16020109FE08F9F4FDFA000A0404E31C05F10B04ECFB 00DAF80F0908030409F9DE02FE220120050315F2001BFD04E1 1A0304160102F600EEFE1D1C060711EF03120602010B02FA00 12050302FB0A012301E80E0A00110006090408F7FD060B000C 140008010704070002040405090903080210030D01050901FC 0E0007000B000402030206020001070108010A060503050100 48FF070D0A0E08040B07070907040706050707180A050B0905 0B070A05060708040808060B05070B04010A05050C0A090806 0C0A0A09040308040809070804060C03020404030406070B08 030220021009130C040406341009080B080F040A09120D1011 211C17160F100F110B120F0E0B1C0A0A1D0A1F0B0F0E180C0A 090B0B110E0C11100E0E0C0B0D0D0C0C0C040303040409060B 0A070405040604050405040E0609090403030C0D0404080A06 030B0A100D0B040503161719120604050904050704050A0906 0905090C070403050E20090B090514180A0F0A081616170609 11110C190908080E0D1F16240E0D0907180C05070707070607 03070A0B07070608030207050504030505090A12150A0A1211 0E0E090D0B180807100B0D160203020508040105080E040907 0E120513081B0F0910110C1012140E070908161362150E1908 100F060F1E1D1914151E23050B0709090E2635422B3A111810 200D0508050B0A0F0E0A0A0C0A130503050202030404040507 17070809030B060A0503060815090E0D090E0D0E0A02040303 06060A090608060608050A06070B080908050706060507080A 0507010608010605090213100E0E0505070505040A0708180D 090B0A1218130A07060403060809050405030708070B07030A 0808070D090C080B0605080303040607030304171312080205 0407060B050305090509040709020C0B030403030408030608 0808050708161818100813151B2019190B031C1F0908060507 0A08030304070B03021D0A080803020C0905070D090C050504 060D09051A191707040807051E1B0612070404040303030304 040F02070A06070C090A020203070708050310120A08030207 080203030303060202040C0203030606020202020302020303 03020E080517080C0B060B0C0D12070A0807040B09050B0309 0403080A090C0F0A0E08070308090706080307080602101007 070718160B0D0405050405090C080B06060708060706061F0A 0C07060D1E2525250606080809097A0A1507091115131D0E07 15060D000A0609090B060C1D14092A141A0A07191911711D16 0909080C090C260E17080C090C0807051B0C180F0B0A091529 0C060B09100F0E040A080C0B070607050706050A0708080C09 09071B171A2078670F0F0A09141A18221F0B0B0F0F08071D0C 13090C11230E0B0908140A080E0D100B19152B1B2F0B070613 0B071607080E0B0A280D050D1F1F190B0A00000B05160C0509 070F050405140C06031C0F040E04030B07060B150804040303 0503020404030506061E051B0037150E070305060505060600 003A0A090A0B060308070408070507040502011E2227223A08 0707060807433E3E3F05060505070709110C06081314141809 10081041050703040701260A1A5C0523060509030304040A03 1C140410044C82160806061A060C0B0611081604050F080808 0303031313070306101E0907191C38040B0302040A0304116B 0908067A09070504040E080E0504060E19093B07090503040A 07037E0606090707050A0D120E0804070A1607082F0D0F070B 060708040B040C040B060807080B070A080804070307040B04 0C040B07040A050705030804040D0A090804100A0C050B0903 07050409070506070509060B030A050A0C0605040F0C0C0704 0E0B090E09030303070208030E0A07070A0606040604020405 0603040402040403060404020405070C19081509636E0B070D 13200A0A1F15090C09180C0F0606070A100B0C0D0F0B0D120A 09090A070A040418130A06060907080A050408040803040B07 0A050708080509080506060000060C05070B080A0406080509 080A0A0A03070B070809070502080707040404080503020304 050206050A050303060A05080607090A180A0709080C050507 0A0A060807420E03090905070B14161A034A07120C07090708 06080E0D0B12070808100A0806020A0C0A08060803050B0D09 0805060A0608030403040304040404030604040605040A030B 0A130A0A150B180D0308070604030307080307030504020404 07030405080403060404070408080909060907080804030602 07040306060306030803030705060A06040A03050305080206 070403060B0A0E0D080B091505131517160A0D171A0B0F0405 080B02030B0905010306020703010204090607090B0E030E07 0C0E130A1105130E08080D0908080307090907120B0A0B0B0C 0D070B0A10090906090B0C070B050B0B0B070D07100C050404 08050A00080B0807090705060408080A0109070609040A0E09 0A070C04060805090A08060704040600050609060705080708 070809070B0A07090709020E05060505080607040B0507060F 0D090505040C0A09070909070803030605050404090906080D 090A09090E0909070408090805010303080807030B06090908 0D09060C040604080604080706060807070409070604040502 060502060907060C0A0B0906080C070B04060501030A0A0809 07090A0801090E0D0D090C050B070908050306030505030702 050B0805070B020504040B07070B0309090905040708060806 050507040507080A020407030804090504090609080307080A 080B070807060A0B040000090C000000050608070609060604 0C080C0607070B04060A0A0B0A0A06080907080C0A050B0808 09080A09080905070906080D0D0809070809090A0808050508 05090B080A040606030406050506090C030307050708080B09 0C0A07070C03020A0A0608070A070B09080B0603050807030D 030409070A0906080709080309040907060509070507070607 07070B05050F0C0306060408090905090808060B0A0803020B 67040B09120909080509060706080808040807030204070807 080608030203020408090604040407090D0303050707060603 0205070B0C0108040508070608060906030905070407090705 050803080A0B05080508050504090501070503030906070309 030304090B0408050807080A05050402040605040403030203 09040302070508030B0306080A0B05090904050505060B0B00 0707080406050A08020307070503030605050F0C0105070906 06070603060B0703020405040A040807060607060508030205 05050303030305070706010101060507090D03060709070708 0506040807040606060703060506080603080B090807050707 080707070A090908090B0A0C0A0807070A0608050906060804 08040803050507040A05080A0B060A09030307070604030304 030404030403040506030E0A120E1010090808060505060504 080803070607030C151008152A0E0A09090E1A161011231511 090C0A100F0812050D1708121A1411070B070E080508081313 1E0F111111150D131F0D1409060F0607131E0C180E1007090B 100F0E0A07161012071513090F110B0E160707050807161921 140F090C160C0A1D11140E13130913220E0A0C1A1A1A000E10 14171615383B0F1D1708080C0C0B0A0A18070A09110A070B02 0310120904161212100E12100B12053F3B668C150E0E1A0B0D 1213130913141112090A0A080C06060A091F1B1F1C11050605 0A03050504040E050901040707050A08040708040314161609 09020C0D110604040304101A160716150A0520090A110F1005 04030609090401010101010303030303030509020C09151305 09080D09030604060605060B07070408040506050804080603 0E0606060F0A08060507060806080B0F060805070C04090C05 070407090504130F0E0D0B1614161F091412080E0C13080707 1510152029241F111010060707080606050B06090E0F060606 060C0602070606050D0A0A0504090508040B11111607131C0B 072722131019040D0B05042803070A09000008090B080A0204 07040706050A0808040307070304070506040704090E090408 080603040A0405090A070709090A03060605060808080B0305 08060A0A0A0A0A070703060706060D09060707040707000503 070803030D080A0806030707020403030305070707050A0707 0704090A060A0206080A0A06080B080205060809090A0B0808 0606090305060505040A080D08070A090C0506070308080207 0504070B07090B0806050A06080707070B060E08080C070404 04050D060606070707050A04050504050C0808110607060607 0705070603050906060506030C050E06060E06050506050609 060A06050604060604070E110B0E0308020303080A03060305 0503080C08050404070B05050B0B05050605050C050C0B0405 0505050509080D050504050505050405040C060A0404030304 08050505050A0704040707060405080D04040603070407050A 050A0504070305050705040606050505060703030510040303 04050506040405040505040404090404090606050B04030505 0B090904040505070505090505090608050506080805050604 0507040505030306060410070507070C05030506040C040607 06090E0806070306050405050509060607030408090B040707 03040804080404040409030304060E040D0603030C0D070706 051306050607060704060606080504040F0A0904040907090C 0604040404060607050A0610060A0605070404040809040508 100405080704080F0C070508050E020E030505070805080504 0306040C050408050505060D040408060E0608080608080B0F 110808110E0404060904040405040906080608030609070804 0C030607030A060506050406080206050404040C090B0B070A 03090505000605050D09030503080909090909040705080904 08080909090907070D09070908060C08090A09050705080908 080C0605090305070B0A080D0A0B0A07090808090D09040707 030508090504070A070D0D0707040404090E0707030A030E06 06120C060504060A060D080D050809090808080C070A070C06 04040309060808070808060806070403060C0D030A0C0E0206 03020B0407050606030D04090B0408090B0A08040204040A07 0604040505030804040E04040806050A030A0B09080B0A0507 0A0A0705050503050709070908060806070303020305050307 0B02050605090B070807090603030905040A060A0807070A0A 0A0F030D0B060A090507040307070509000A0504090A0B0000 0B00000E0F0D00000B080B06130C06030A070903070404040A 0807070D040306070703070803040705060501070407070B05 0518080808040B0708070E070C0A090807030504050A060B05 04040E050A0C07060B00050605090D09000000000404060607 0308080B090606000000000000080005000400000905000005 06070000030000000000000004050300040805040300000300 06090B06000300000200070303080808050604020906060000 05080800000604080306070A0A0A0006070607000603000000 02000000001005060A060608070706080800060E0D00070500 0600040806060B060B0E0F0000000014000005060B07080712 11050600000005040000070603000504000000070000090300 0003050407020907020004000000030800000000040605090A 07070C0A09080D090B0B05050B09030B09060B15030B0B0A06 130409060809040604070406080608060B0A0806080A000000 05090A03060C060A040A060B0806030807030A0A0B01050502 050A0C0C0A0A060A070C0C09040808070A0B07070408060405 050D0505090A0607040504070507050B07090A070A07090506 08050C08060C080109071008090808080C0709090C0D070808 0D0809060506050506090A08070706080803030908090A0307 0703030308030A08000C090509070907050404060B04050609 040809090808060304050A08070A070604030000050000060B 05000005030709030C0706010305070B080603040403070608 0B070B0709070A0B06060808030404040606080B0B09050C04 0603070806030B03090600090B070A03050A04090904050309 01030603070708000009080B04080B10080B05060805040803 050408080908060B0D0909090B0D0B080C0A0A0A0306080405 03030B040702060D0A0309060404060A0401010A0807060407 080207040B090809060907070B0407070A0807080807060508 0806080C0A050802050305070804070A0B030A0B080B030B1C 2D14250D655D04030504040202040305050303030A08080203 02020202020304020C0C080A0B080402040302020302020203 03040608060303030908010101040305040802090905050907 05050309080A040303040722182B144F830D2A2A230D0B0703 04050C0804040B070D080801050C05040504070B0807050B06 090607090504050605060A04070904080808040A070C080806 0407070B0A040807070A060709050806070B05050506070404 0C0F080E0A050405090907070505060C0D040705080B070407 060604040504060D07080A0611030406070506060D07060503 06080607070906090605060506060503080608070A09070603 050803020803030803020803030C14088B92896E0B0C252031 07121C0D07070914070C23210C0C0A0D13171716100F070F1C 07170808080909060A1A0C0C0E1D11090A1B0D0D0C190D0905 1608151E350718210504280305412420091021030522090544 06222A130F46320F433B0505041D03081510090F0B15101410 040203040409050A06050609040305050504050A09050B0B0B 0B04223E350804050C07060505040404040A060405040A0504 0404070605040507030A0907040705050506050A050A040405 0408100A0E070A0D03050804050505030304060D0C0F090C08 0A07060E0908060506070702020202020415120D0607090A0A 0B100E0A032607040C03030207091108080804040404040304 04030304070304040603060604070503080604040303040305 0304060403110A0A0A08081D0C0C090A09050B0A0703030408 061F1209090E07030305050C0C0C0609041918181504040802 0709060A0516090F050D0D1A0E0F1A221E210D040B06060806 04080805080A0B0707090A0C1C07050C0E0C0503040B070C05 0A0605040705060B0607080517150505080C050D06030A0807 131512050607070705040B0507040605050406050508070509 06060809080705050506070408080508050504070303040405 080803080505040407030909060409040A05060B0904030606 070404070C0307050408080607040807060404030503060804 0606060806040504060B0A0804090405040506060404070608 0404030503030609050207090505050A0B0803070603030503 040907040B030303080307070403080709040503090505040A 04040905040405070403070608090509090708080906090804 0C1308160A0C06070908070806030A0805140E0607110A070E 2308070E0B09080B110B1B39050F30340C070707060B080B06 140B1B7716131707352F1E1055826B6429524931221E133608 08010D150934071B06080C071B0E0D090906110D0C100F1123 0F08110807080D0B0F2117190C0D15150B0E140C0A0807120A 170E080F0D0D1E090E0E0F0C0A141414141209161213120B07 121A0D0C0C1B141514181209090E14181C0B130B18180B0E16 131618081507060B110C0A1715090A16151010080E180C0D09 0A070F07070D0B0A0C15050909081112130D0912090C0A1204 0F170B0E230E0E0E111407080B1D1213130C17141409160B17 0B160F1613171314111312050A070A1109070D160B0A090F12 161A0C09360C0A040D120D0A260D0A322922071A1308090815 0D0A16151F100B130F0D13120F0E0A111911162E0C0D0C0B11 0B131307101311111212101113181B140F0714150A0F071010 0B10081411090B08080A1017160D120C0612151E141E1C0709 0B11100F130A0D15060B0A0A0C0A091616293A161519070807 1D08090912060E0714130B0D0A141E0E0D111B1B07110A150C 0F0E0A110E120B120B121A27131E0E21070E090B1B141B2712 10200D090D100B0E0E11170706111117170C1C130707081D0B 0B0709080710110414181C07171E1F2A0F16470F0F0D13110A 11132F0F171E3D1E2548501A171B19171311050C1E2B08090C 080F0C110B060B101227060815100F100809150A0E0C14061F 100F124B090A080F0D0F0B100F0D0D1624060F081D130B0E10 1118080A1D150B0F0E1C09090E071D0A1E2E16120B0B17130B 0B2B2C0A06110B211C1C2318180A150C0611130B1712120F10 09130C160A0D1815181515130C0B140E0E585B0A0A061C0C1E 1308421C0A30311E1B111D1E220C110A0C0617130D090A0911 1119150E0D13120F131211090B071010100E060C0D18080737 2C0E5412120E10111F0C120A53101010140F0B051508070E0D 0D092C121515110B15131C12130A0B0909070E0C0D0A0B110D 0808351B121D1407140A1E180B26041115350C2C1A0F1B0F10 0C10170E0A1616170616110811030608050A130B0C090B080D 0B0D0810051238101019250D0C050C1A13071B05051B08110B 1C1F050B130807130E290811101008120816140506120E0C0A 1716090A0D09151110130C102A100D0F0A100E140E0C271011 10130E0A0C0B06050C0B090F16150A0E140E0E2113210D0B0F 0F170F0A0F180E1811060C32170507080C19200E0A0D070E11 160E09080F081411121D07080C0E16140D1005051812160E08 0C0909060A1F2D130F0D10090A090E0C090F141D080D051309 140319060A08070505040E05110D100F0F13130D0A0D080E0C 1910060719090A100E090A0A16090C0D090B0C101012101612 0F0E1E111115131406071609111414161410110F1513150A0E 0B0E0A0D070C0F080C0F15130F10101111161404080D121E12 0F11140817121A13130D17131E10050708080A081207000700 0A0B0D1209060A110A07090C05110511070C0C100E0C0B0808 090807080608080306020606030603060A0308050608090705 0712131B060504080A0910090813200713141716181A100608 050A0C050407070D0602040704080706080A0B0D1303021208 06060A0D0C070706050404080E090E040604120607050B0707 0707060E0609090504040A040B13090B050805050303070F08 080C0D0E080507050405030B0B08060606050509070605300B 0E100F070A1E07060C0F0C0804030905040E05050302060406 050807040E16121111101C0F08030212180812040302141A19 0D101D130E16070A05070809090904070403020D0908060509 0F050303050C0708060407070904060607060A060B0C061316 13141406140707080B0B0B0D10100E0C0B1107060609080A08 090A110F090A09081113071216090809060A0C1B0A0B080907 04140A06080B0B060808060C050B130F0E0906090703091909 1A1518120919181C1A111A0B1806171908080D1B070F041517 181B08090C070706090F090A08070D07060810040406050404 1D0D0C0E100606111213131B0A07181E070809070E0B163B2A 0C162D0010110C0D15431A1418221C1D1B0D181106060C2410 1311211B275D1609161B1F0C0C000A1F190D291F220E0C2815 181A0C24070D07140A0507080F12080F130B0A0E1C1A22180F 0E18170F171810111B0A12110D15190D0A110C0C091712232D 291B0510312A102418252817140B0A0C131021162911071111 1311110610081C131E13130030100C0C292C16151513240707 2714101D120E12420E15231F1A210B061D13070B0C0A0C0F0A 0B0D0605150E100C090808080D0D090D0E0B08110C0B0E1516 0046681B3C1B1113190710170B0A1A150A0E25121209123229 24140F1D1B1A1A1C070A080A0C1A10030915150E1F2F160613 111B070608120E0C08070A080516080D060A04040906060308 0703040302080B06120F0909040A0904090506070505090406 070509060603030809090A19090C0E18170D080B050C0B0E0A 0B09030B0306040818070703050A180608060906030A130807 20060C0803140E0D0B090A0B140B100F080A09020704050707 090904070709080B0C080503060309060C04030C0504060505 04050405040605090B0B08020807030706030604080906090A 0B0E0D0F070606070707090D06070A0F0D0A0A10070C060C0A 0C04050B0D07090B0C080A080C082105080509070B040B050E 100B0D190D150D0B100905070A090705060710070306070608 160815090C090606080505070805030A0404070A0506040707 060703040A18070B090D09130A1E180E090C090B1303070405 070508180C05050E0604030F04050607070503060C06070716 070A2903080709141401090603030605050606031103060703 07050515020604020204040304020503030302070205030303 03030105060304070503060605040300060403040303040504 03030405040404050305040302040505020205020404030205 05060102050504040502060504080204040102040504030603 0302060603020306150A0E0B0A090305040303080503080607 0E0A0D170803022010080C160F110C08070A080A0A06080B1A 190D16080805050507050804061F0C180C1F0E100D0D0B0606 100F0306050808050505110106030303030807090A080E100A 0A100F05060E05090805060A0D07080B080707060709070809 0F0B0E25050E0703091203040D0E0B0805070A0507050A0606 0503050C08080509040506060A0B050F0A060522312E04040E 0706060C0A09080906070708130E0B06060C090A0311070D0A 090A0B0A0A0D040509090E03050A07060408080508040C0706 07030705050605090905060404060802040303080604010A07 080A0A090A04050A09060500040704040B070608060906040D 09060504060B07090C07050708030604080608060704040504 03070407040706070404060501040504040303040501060404 03040404020605050506080504040607070303050505040703 07060506070B050708060808050607060B1905040912141006 070B0000001D1C1D0B0B0B111314091C4B0E0813090B32270D 391D110E1A1011080B0B0B11131421101116081709370B1F1E 37222B0A000E11212324101226474500130B121D090D1A1816 141B0B1210070807090B1C11120F0A0D0A0F110E0D131B1216 1B0D210F09100809080C0B0A0A0813060808090516090B222E 0C090405040C040B030B04080A04191B1B1007060917170D0B 0B0803030205040908150A080C0B02030B0A03070B02060707 0A0A090808080407060604080A0C0B0B0709130A030D0B0C0B 0B0B0906070C0A07040C18060C050D08090B0C0E0C0A090809 0D0D0B0B09050207080607080D060B0908060706070E0D0C08 080A0A090D0B0B080505090B0A090708090A0706050507020B 09080A0E0A07100D080708050B060D0D0A0B0308070608040A 050C0E0808070C0A08090C060508090A080B03060B0A040706 0D05060E07070707090D04090C08090904080B0B0A0A03020A 070605090605090B0A17140F07150A130B131D16141A131A1C 15120B090A1515151616161219061515171716161012121212 0B0A1110100F0D070A0E0E100E2514102405050408070A050A 080C0C0B0E0B0D0C0E0C04090D0F0C1A0C07110A0B0C040907 020408050B0A0808160E0F0D0C0C0D0D080A0D030B0F070C08 040A0F0E06080C070B1610060E0E0F1025100B100D2C090607 06060F0A0D13080F0C07100605090D09050712080707060607 0E0F0F0D0B2505040F0A0C0B090D0A080A1108090C0C0A0A0B 0B0B0E0C100F03010907080609191A120606080605080A0904 060508090A050402050305080805030A0904080B0905060B06 07080B04070E09060505070709070905070707070909070606 1A1A0D071A1404050206050307070704060405060709080606 0400000605050605040708070704080B0704050B0707070508 03080A102405040505060406080911070903060A0C0E040B04 0A060905090B0A030210080703090208050303080908070D0D 0B10090608060A0A06050E060703020A070D0B0C0E05060606 09090F10100106050705040308050902030404030702030804 03050E050E04060607030404080304041B040405030706050E 06050304040E0101010303070706040508060807020405050A 0202010202020103020D0A070B07090303070408030B020A06 06080A0302060A0B060A0A0B07080D07040309070109030202 0302090704090A09020206070B060706070707040604040407 0202080102070C0D081110110908071A0C0D060E1413050707 04120709030704110B03090507091013180C0C10080F0B0A06 0C0B020809030D0704060A0B0A090B08070807090908090A05 0809070A05050303060E0C0E0303070F080C06050607080603 080609040609060A020C0806030F02020D0606030A02090308 0708060708070812090A040A0D09080507030217160B0A0704 03070906090608060C0C070408030604040A070409030A0607 0308040606060703080A060709070A090707050608050A0903 080608080705060D07040C0202030105090304020605040504 060903050508080A0505030308070409060703060709070507 0703040604080908070706070908040A0A090B030410020406 082205090D08050B09030603020A0A0B060C1107090504050D 040206030B0D040C030E020D070702070905070304020A0A04 030808070509070906080803090B0C0403080307050D050406 04040A0712040606050503030D0B0709020A0C0F0C0B090D08 02030A1008090A0A09050B0C0A060D070A06080C051108050A 0506070203040803030503040B0E1106030A02090808080909 0E0F0B0A05100E0D0D100D06090D030303030C0A0A080C0B07 080A0805030303020909080B0E030D020C0C0F0C0E0E0A1907 0E0907090D060D0602040608020401090C0A04020B07040808 08080B1806070304030906050808070C090B030E09170E0303 0803030704061C05051A05040707150E0704090D0A0D100904 0D0309030B06080610120C04080603030402020C0A07070508 0A0A0A0C07070A090506080E060F0907070A05050509060602 0405080D0706070406080905080207030A0503070505050404 0309020C1006080F050508050A0805060C130B130505070706 0309050605050B0A0503050202050503020404030402050403 03040302020303040403040303030304050304030303040104 02020203030305020404030403030203050504030404040503 050404040202060A1A11101110070504021004030709070907 080705040A0602060403050A0805020407041004071011030C 070707040203060604060709090612050E010906070D050209 05050B07020A1006030215090A03021907050B0A090A020606 09080708090A050704040C070A0309050404060405050F080D 0F12020309080811101014140B080B0C090A0B0804090C170C 1513150503060302050A07070C080906070708030904040811 131312090A15080605070A0F0F110709050B09070809090807 0D0E06080D070B07100C12100C100F0B110C0B080807080B08 0302080B030203080403020203030303050D0A06050D0A0907 0708060B0C0D07020B0A0F1106050A0E070909020507060A0A 080C0B0402010203020607080A0A4624341F3C1B311E213117 29262623281818262A0F614C29112346243C23294B1A231313 28171C17392825414724192B1F1A412D2021142D2B1712251D 0D1435251E1B211D1D1C260B131F1B213011171F5115112632 331D172139463F192638274C9616113167635A2A305B647E7C 4F1B701B333D28592C211A2D1F31492D5B1A7B7C8989848D6D 7D423B383A231B311B3735143E429B8C1C351F1F2041311E1F 131A0D1C232232652A3A46631113211A20161E141D1C252B24 1728305A637D7B451A24674A13273056637D7B4E1A1A4D7B36 4E32305A637D7B451A2B301A1F2C9544614F76661925472130 19141B571A352F305A63837B494A231F421C7B14152F151642 3054637D7B4E1A251F5030211F1716331B23821C2B2610291B 1A101D17261B1B2127331127141F1992151A16423A24305675 8687511A1E1E11211F253418212018682D642B305A637D7B43 1A20200D301A2A22221420470B123488172247651D305A507D 7B461A1E20662944231B1D242D37331C30347D7B861A13305A 637D4E4E1A828F211965163C938D161420124536182C1E0E83 0E4D10FF0000C712040D09F80F08D5E163A0DB240127F870AF C19D6001240127F870AF07A0DBD9ED00AD011E0B5107ED1162 749CE20EFAC712040D09F80F08D506F118ADE4F302EB0A2401 27F870FD011C07FEB627F870FD011E0B5107ED06F99CE20EFA 39EB0A0712E7013901A770FDF93901A707CF18ADE4F302EB0A 240127F870FD013503090D976D02C30900C16466B754EE00EE D36B5107ED111B9008F0F80F08D506F126035707CFC712040D 09F80F08D506F11C07FEB627F870FD011E0B6004B61BEF0502 0AC90500F70CFA4EF81001A707CF731A141D291C0018393E18 E018ADE429E5D307FB729AE5D307FB72073ADA00FC7C0CBC38 23A7060329000D05E7A7A3019A000D05E7A7A3F91B04F1050A E21BEF05020AC90500F70CFAA6F895E5CC3A010C0F02113830 F0FAC400FC0AE40465071B840B19D223A706037D18E018ADE4 18E018ADE4CD00DA02F93ADA00D6010CE90FF00AF2383ADAF3 10ED020B0D9938CD00950B76CADA02F93ADA00ADBADAB638CD F712E4BC0728080EEBD36310ED020B0D999CEB860710ED020B 0D02A6BEF80710ED020B0D991710ED020B0DF816E218E0DAB6 A6E2ABCB02F0F8C16466F13704D6F250E20C0002FD012150E2 0C0002AF07A0DB50E20C0002FD01DD0F0104F8C4E20C23A706 0317DA033EFEFD4201010F0008A7060300FD2550E20C28422D 0808EDC87C0CBC50FA0237E205F27100DCEAE1073A29001101 E2381E050587FAE808E0DAB6213A9A001101E2073828121228 051E00480706FD00D500EED3F50F5AF509E7A7E00127D399E6 49F00006F8DA152549F01E0F5A00E1F10EBF11E5030A061206 FB1E0F5A00C112EF050A1E0F5A00C112EF050AE622C9058404 DFDA15251E0F5A00D3F509E7A7E057F01E0F5A072D27AC94A4 0A0603A3011BEBC10701F8783107EA08F8D050156C07F5ECC9 C00D0509F9E91ACF5E196B51E9D3F410EB0EC0D01E0719D97B 07F8F797FD091178A268F31105AB08FD06E8313477D512A4D0 1303090D97D512A4D01303090D97FD180D09F70CFB9BE5070E 149CEB860F94075E0A2E0402D8E0C1120DEC11F410E20EFB9F 0A4B0A359B002E090D01F603EE359B00B627F80CC5016A1684 0B19C0ED00E70B060F06F0F816AD11A6BEDB2134731C343A1D 291C3850FAF87C000D0507D790FE0C030AFEFD50FAF87C000D 0507D790FE0C030AFED512220300C107F0DF150116F55BB807 F9F5E9BDE403DC343A321C242A31FF003833389FDF150116F5 5BB807F9F5E9BDE403DC343A321C242A31FF00383338371826 170B08060F02E9C1BFC9C00348F3D790FE6D7EE3371826170B 08060F99F5ECC9C00348F3D790FE6D7EE32408A7E69CFCF9FE 3A2E8AFF0035382408A7E69CFCE63A2E8AFF003539423837F9 D805003A202E184743FF00373837F9D805003A202E18FF0038 FF00352F3846040FEBF9FE3A2D1C1B3817060C0FE69CE63A30 2E29FF00382F432F3817060CC2009C813A302E3D43293D3817 060CC2E69CFCF9FE3A302E423846040FEBF9FE3A2017283837 F902E63A2017280032FF0038FF0038FF0035FF003933313229 33381AED0AE4003A2017283824100406003A201728382EC468 003A2017280032FF0038FF0038FF0035FF0039333132294333 381B010968003A2017283837F902E63A2017280032FF0038FF 0038FF0035FF003933313229FF003533382376EB06EB003A20 1728381BF0ACC4002D0DC30FE63A2017283817EFEE002D0DC3 0FE63A201728382EC468003A20172800FF0038FF0038FF0035 FF00393147381B110806ECE4003A201728381E08CEE4003A20 17283830E701563A20172838390116E715003A201728382490 19D310003A2017283846040FEBF9FE3A171006120231462017 38BDE4030AFE3A1C1B1731323D333837F9D805003A1E171B20 2038BDE4030AFE3A1C242A313229FF00363338BDE4030AFE3A 321C242A31FF003833381BF002E62D90E63A37FC0AC907381B 110806ECE4003A37FC0AC9073837F9D805003A37FC0AC90738 30E701563A37FC0AC90738249019D310003A37FC0AC9073839 0116E715003A37FC0AC907381E08CEE4003A37FC0AC907386F CF790CE63A37FC0AC9073824100406003A37FC0AC907381E08 CEE478A2682EC4681B0109689CFCF901CB02F0F8F00B030AF2 1B110806ECE41BF0ACC4002D0DC30F01EB17EFEE002D0DC30F 01EB1710ED020B0D9930E70119390116E71539D3651146040F EBF9011AED0AE42376EB06EB24100406249019D310BDE403DC 321C242A31FF003833001C2326076FCF790CF90137F9F82D0D C30F01EB371826170B08060F991E08CEE478A2682EC4682408 A706E3C4002E8AFF00352408A706E3E62E8AFF003539421B01 09689CFCF901202E184743FF0037202E18FF0038FF00352F1B 110806ECE42D1C1B1BF0ACC4002D0DC30F01EB17EFEE002D0D C30F01EB17060CC20612E6302E29FF00382F432F17060CC206 12E6302E3D43293D17060CC2061206C0302E4230E701193901 16E7152017282017280032FF0038FF0038FF0035FF00393331 3229332017280032FF0038FF0038FF0035FF00393331322943 332017280032FF0038FF0038FF0035FF003933313229FF0035 3320172800FF0038FF0038FF0035FF0039314746040FEBF901 1AED0AE42376EB06EB17100612023146201724100406249019 D3101C1B1731323D33BDE403DC1E171B20201C242A313229FF 003633321C242A31FF0038336FCF790CF90137F9F82D0DC30F 01EB37FC0AC907371826070B08060F02C813C406DF150116F5 5BB8071710ED020B0D9939D36511A6BE02170D160CD64E77C1 07D70DE7E6CB02FC0D0125170397D6010C07F508FE0D0507D7 0DE7E6260304DF0D0507D790FED6010C0725CB02F0F8F00B03 0AF250FAF87C000D0507D70DE7BDE4030AFEA70A0814170D16 0CD6750AC0D00F047BC0DC8BF9004D02E64EF8DA152578316D 7EF8FDE6CB127BA245E39606EC00C116FE9419FB141F047BC0 54EE3432D2332E090D01F603EEB97EE3F4EBB0ECFB22D36D7E DB213432D2334EDB00F63432D23326D3F8D5A9047BC0DC8BF9 D90DECE67F0400DC8B0125CDF813D30616B7D003EEBA2E090D 01F603EE00DC8BF978316D7EF8D512E6CB127BA245E39606EC 98FE9419FB141A0497E813FB1710EDF87997E813FB1E0BB00F F80F047BCAE73652F81289254F28EEBADC8BFEC1B80FFD0AF2 E6DDAC11251F047BCADCF1DB213432D23326D3F8D5A9047BC0 DC8BF9D90DECE6DDC29DFE0400DC8B0125DDC29DFB213432D2 33A6E2ABF4EBB0ECFBA6E2ABF4760FF1DB2E090D01F603EEF3 15D6ABC0D5122E090D01F603EEF315D6ABC0FD85AF6713D306 16B7F6F301E2ABCADC8BF99610F0002E090D01F603EE0067FD 85AF67B60C0FEDE2E1E013D30616B7F6F5EC00DC8BF93708FD 0EA994070B03DCE683D8F304970F94070B030AFEFD9803EE00 DC8BF9E6DDAC11254E77E740D7DB98E003EEBADC8B012E090D 01F603EEB97EE3D9CCFBCD00DC8BF9D9EF050A1F047BF2D9CC FB1F047BF2A80AB905E6E740D7DBD9EDF3D790D6E0E794FD07 CB05E6F6F50D0A06036B0B147F0F047BF21E0BF7A1DC8BF91F 047BC0DC8BF91E0BF7A1DC8BF92E090D01F603EE78A268B905 1435D30616E1D61132D233C78BF9D9EF050A2694F812EF05DF DC13142E090D01F603EE00FC12032E090D01F603EE1F047BC0 DC8BF91F94070B03DC75DF058E00DC8B01281212280539EB0A 0712E7011B760F0DD83901A707CF39065BF028EEFA39EB0A07 CFBD19DA150550156CE913D30616F124010C0FE613D30616F1 1715D6AB00FD002E090D01F603EED97B07022E090D01F603EE 006716AD11E6240811F50E04FC14DD6D7EF8ADF23432D23322 D36D7EDB213432D233C79D6004C6E70C03C64AE5030AFE127B 070222D36D7EF8157BFB6B5107EDE0127B0702839329FF0036 000A8A06F80B03DCDD0C03C64AE5030A63F7EC6B6001C813C4 06DF0F047BF261B97E77C1BFC9C016E032D2331A0497C4E7A7 E00127D39928050911F50D0A0603D9E1F99606EC98FEACEB07 12FA08FB1F047BCAC1E813FB1F047BF2F364FBA40A0603B97E E3F509E7A7E00127D3998003E5EB116BF7A1DC8BF9CDF30F9D FE7C00058E00DC8BF98CF6F410EB8613D30616E1E61510E1FE DC8BF9B97EDB3FF9281212280522D36D7E021710C90500F6F5 EC39065BF0CD61F301E2AB1F047BC0DC8BF9001F0904E0AA04 002E090D01F603EE23F004A585AF13D30616F1214F2E090D01 F603EE750AC0D00F047BC0DC8BF9004D024EDBA80AF55BC0D0 0F047BC0DC8BF9004D024EE3D9CCFB1F94070B030AFEC1F0D8 C081F7A5E6DDAC1114DDC29DC054EE214F8003E5EB116BF7A1 DC8BF9E622D36D7EF80400DC8BFE127B0702E64EF8040D0A06 039606EE253432D2334EF854EE253432D2332206C43195B97E E39606EE253432D23371C96B51E9D0CB9202E91611250032D2 33DDB006A16ED989253432D233DD0C03C64AB97EE39606EE25 3432D23317FA06C4A9EDF86D7EE39606EE253432D2332204EA 00ACEB0712FAB97EE39606EE253432D2332D27ABEB866E9606 EE253432D2331710EDF879A52183D8A994070B03DC2185FD01 3BE979A5214E77D0D1DC8BFE54EC98FE840702E6CB02FC0D01 25001715D6AB00FD002E090D01F603EED97B07022571C900EE 67DC8BFEF6B97EF8040DF6A268BF1125009C030307CA3B3FF9 3BF5ECC907B97EE3E9D0EA19FEC29DFE040DF6A268BFE054EE EFF86D127B0CBCE69C030307CA3BCD3BE501EB07B97E77E736 5202E954EC00E7360D7BFED408B9127B0CBC1422D36D7EF8BF 6BF7A12E090D01F603EE00DC8BF92522D36D7EF8127B070225 3432D2332E090D01F603EE9606EC986315D6ABC0D512E6CB02 FC0D012522D36D7E022534D2C8D80501F86D7EE39606EE2500 32D2331715D6AB00FD002E090D01F603EE257F0F047BF225DD C29DFEEB000127D302CADC8B0125230D0505F2F50F0FE6E736 520221001715D6AB00FD002E090D01F603EE25230D0505F2F5 0F0FE62E2400E7365202210039060AFE70AF1289F5EC25230D 0505CA2E2400E736520221A910AF13D30616B7F6F5EC251F04 7BCA54EC00C116FEE813FBE6CB02FC0D0125A6F870AF13D306 16B7F6F5ECF301E2ABCADC8BF925A6F870FD013BE92E090D01 F603EE0013D3061609D6E0D03B39065BF03B25A6F870FD013B E92E090D01F603EE0013D30616E1D6E0D03B50156CE913D306 16F13B2578316D7E021E07078A05F310EDF879A52E090D01F6 03EE85AF13D30616E1D61118E070FD013BE979A54E77E740D7 DB98E003EEBADC8B014EE3D9CCFBE69CD756EE04F803EEBADC 8BFE6754EE8108EB86EBDF2E090D01F603EE0067FD1485AFC1 6D7EEA16B7D003EEBADC8BF9000A0DFEF66BF7A16D7EE307E6 80E50419FE70AF6D7EEA16F159F0DFAFEDE5EDFE6D7EE30714 85AFC113D30616B7EDB97EEA16B7D003EEBADC8BF9000A0DFE F66BF7A16D7EE307E680E50419FE70AF13D30616B7EB0AB97E EA16F159F0DFAFEDE5EDFE6D7EE307144E77E73652F8E740D7 DBE64E77D032731C3300C1BFC9C016E01D291CE622D36D7EF8 EBDFAC11F50E04FC14CD00DC8BF9D9EF050AE69CD756EE04F8 D1DC8BFED4F5086301E2ABF2D9ED001004E92E090D01F603EE F315D6ABC0FD7DD3F301F813D30616F11485AFDA15B97EEA16 B7D0E70C03C6DC8BF985AFDA150013D30616B7EB0AB97EEA16 B7D003EEBADC8BF91F047BCAE740D7DB98E003EEBADC8B0137 08FD0EA994070B03DCE683D8F304970F94070B030AFEFD9803 EE00DC8BF914750ACAD00F047BC0DC13E64D021BEBB0ECF24E 02CAF63432D23322D36D7EB11F047BCA54EE003234D233A6E2 ABF2D9ED00DC8BF91715D6ABCAD512002E090D01F603EE1715 D6ABCAFD002E090D01F603EE22D36D7EDB213432D2337831DC F1C6DC9D6004DB2204C607010FE20465F3A0DB359B002E090D 01F603EE1B04F1050AE2F509E20CF3DA033EFE9D6004DB2D27 0F142150E20C2E7BEEBB111BBFAEB62D0AD61801CFF218010C 0318031301DD0CFC0AFA2204C6EBDFF7A5CDC6030B0B90E9FD 09E0FDB0E6CD00E70F0104F807CF141E12932900BB111E1293 29960101197100030B0B9008F051A6E2AB300300D080310A03 004D02C807FAF8DAB62805FE030B0B9008F0B0DD0CFC0AFA82 130137010156AA8E170F08CA2AF960C480B5F31501010FCABB E03AFF0051CA18CA4606013826EBD805002AF960C42208040E FD002E0304F82AF90214FF0037EE001A8A10F82AF960C43010 0307F82AF960C418060A31A4020D0C05002AF9021422EF16B7 FF0039EE002AF960C4FF0038EE00D500293DEE0018FDEE6100 3F01E23BE92D13019C0D2601040F18FDEEFF00B7FF005A10F0 0E2606009C0D05FF00589B00FF005A1006FF00589B03001710 0D22040017100D260600FF0051060D9C0D0017100D2E040600 260DFF0051060D002AF039EB00260D17100DEB0E004606EB0E 26060022FD0E3F0D0017100D06FF00589B0300FF00580D0122 0400FF00580D0122FD0E00FF005A1006FF00589B030039EB22 040039EB46CAFF005A10019C0D05002AF0FF0051CA18F2300D 003F0D260600FF00589BFF00589B030018EB18EB0E00FF005A 10FD0E26030BBC2117EA08F8BBB6215C3A070F04B038DD0CFC 0ABADAB6213150E20C00D51250E20C00FD2204C607010FE204 65C872830A6BF7A10BBFA80AA80715FAF3D7FD0A7225A40A06 030058DB00D010EB0A0712E701A40A06030058DB00D010EB0A 07CFA40A06030058DB00D01001A707CF22D36D7EB139EB0A07 CF39EB0A0712E70139EB0A07CF3901A707CF9F0AA3011715D6 AB00D0AADC03722805001003090ACB02FC0DFE0BBF25203B0C 98ADE0088A10F8DA15E6203BEC7200D4000904D81449F00009 EF0A070F010419FA2578A268D909941000FD2A099410F315D6 ABC0D5122A099410F315D6ABC0FDD2F3A0DB1434342A099410 F301F8D0D512141BEBC1E70BEDDFAADC03D9ED00181817E69C EB8607CF74148CF6F304A10B760FF1C67003F6F301360DF0B0 2AC407FE0B0309EF080730E711070B04F11A010E0460011AED 0CC4A60F9B170309E2D3012E088A100205F907C712040D09F8 F702F12D1212D7992A0994101B040CFA041803DC1FE7AA8E00 F7A58503D0360DC4D6118503F6F3063E01A6091231F70CBA09 8A1099A6091231F70CFA17CF741B040CFA04F3EF050A078503 F6F365040E016FDC03F4040CFA046FDC03A9E7AA8E6FDC03F4 09060F00360DC4D6116FDC0300B803090DE36FDC03F409060F 00F1050EEE3710D6FE16C4EBB0C712040D09F81203090AFA18 018F114B0A85AFA58F1128EEFAD903090AFA2E94E4398A101A ED0CC4C712040D0902180427060C0D0C398A102E94E41AED0C C4800057F0001B040CFA042CF48407FE0B9008F0F8040F5A17 650486840BBCF410EB0EC0F6E5018F114B0A17650486840BBC F410EB0EC0D070AFA58F112E088A100205F907AEB62D1212D7 992A0994102A09941000D5122A09941000FD26EB0A070B040F FE7CA20285AFA58F11180DB661A91003F66100AADC03F40906 0F1B040CFA041FEDAC0406F87CA20223F004A5A6091231F70C FAA6091231F70CBAD5129F0A8503F6F301360DF00BFED51285 03F6F301360DF00BFEFD17CF74BD0C0DB6398A102E94E41AED 0CC46FDC03F4040CFA0478A268226C098A10022A090DEDF90B F002C80BEB0AF90BF0023710D6FE16C4EBB0FF005A0376FF00 5A037600FCFF005A037600EF021B040CFA0400FDF302EB0A16 11E618018FE0120DEC141B040CFA0400FDF302EB0A1611E61B BF00FCA9C30EB807141B040CFA0400FDF302EB0A1611E649F0 00F10507F4034814731A141D291A181F001D3D1A271D431A73 1A141D291A181F1FC35107F2E5018F114B0AE682A1D070FD01 251FC35107CA70AFA58F11E682A1F6E5018F114B0A25CB92F8 C4E7A711B9EAFC07A80006A20E01E6DDC29DFE06A20E0125BD 07950FEDDB9610F000AADC03F409060F00F1050EEE00D3F301 F87C001818178503F6F301360DF00BFEFD1434342A099410F3 01F8D0D512148503F6F3063EFEC107950FEDDB00FCF301360D F00BFE0C03DCC712040D09F81203090AFA78A2686FDC0300B8 03090DE3F301F8D03B26C93BD9EDE50D09F70CFB9BA3016FDC 0300B803090DE3F301F8D03B18FB060D0C3BD9EDE50D09F70C FB9BA301C712040D09F80C03DC28EEFAD903090AFA9AF3D7FD 0A07CDA9E7AA8E830AE5EB0DBF118503D00FE7AA8E00F7A585 03D0360DC4D6112E94E4398A101AED0CC48503F6F3063E01A6 091231F70CBA098A109928121228052A09941000C107950FED DB9610F0003B8503F6F301360DF00BFEFD3B141B040CFA04F3 EF050A0718042714F51366F12AED00181817A3012812122805 8503F63CAADC03F365040E01C712040D09F8F702F118E0F702 F16FDC03A9E7AA8E6FDC03F409060F00360DC4D6116FDC0300 B803090DE36FDC03F409060F00F1050EEECB02FC0D01CB02FC 0D011E02EAAB1B040F020DE71B040CFA0400FDF302EB0A1611 1FC35107CA7003F6078213CAD0D278D909941000FD14343437 10D6FE16C4EB0B6301F8D03B783B142A09941000FD14343437 10D6FE16C4EB0B6301F8D03B783B141B040CFA0400FDF302EB 0A1611E6CDE5018F11F3A0DB14BD0A03F3A0E3071BEBB0097F BFA3F9D9894F258213C0D6010C076AC1E813FB180D09F70CFB 9BA3FE0BEBC116FEE7AC060113FBE6DD0C03A10F890F022518 0D09F70CFB9BA3FEE7AC060113C4D9CCFBE6240811F50E04FC 2582A10CC5012585AFC18110039705CF5E19E6CB02FC0D0125 9CD719F3EA02ADEB2CA80E0B2CF410F059F00E125910FC59F2 055909085909072CF3103E593E101EB58A0DEFE90FFC11FC62 B1F364FBAEDB850894FEE813FB1EB58A0DEFE90FFC11FC61A9 100894011C07BA700894F9850894FEC4E7A7E00127D399C813 C406DF700894011EB58A0DEFE90FFC11FCAEB67FBF2D0AD6C8 0F0DF80C03DC1C07BA700894F983D8A91008940121AEB62534 D27FBF255305AB08FD06E84577840E07F4F1E2FB1BF1E2F5EC F31105AB08FD06E877840E07251BF1E2F5ECF311050B0723F2 CA02AF07A0DB1E0F08A40E2204C610065BF02204C60AD3C26C FB22D73018242A01162A08062204B62406973EFD01040C0F0C 3018244FA6F8F797EBDFBBC6127B070246EB460D09460D0539 060AFEBBB61710C900BBB618E2186C18FDCD13280B028202A6 0F170D0524100D240D0137FBA6BEDB9610D6FE16C4EBB02134 D2281640D7F8A70AFBAEB62534D2180427060C0D0CA363063E FE0127B0FBC016E09A00192EDD0C03A106A20E01DD0C03A107 EF050AF409060FDD0C03A1AADC03F409060F280D021603271A 0497D572BAD3F310C9051A0497D572BA67C10710C90578A268 B902FC0DBC00F0CE09FBCB02FC0DF2F512D8B9127B0CBC00F0 CE09FBAEDB213432D233230D0505F2213432D2338213FB2134 32D233AEDB213432D2337FF70CFA1BEF05020AC90500F70CFA C8D813C400F70CFA071FFA06030A8000050127F80FFA06030A 17CF7417EA08F8F70CFAD98924060CFA78A268CB127B0CD97B 070271A9FA06030AE9DCF1DB7100F70CFAE9DCF1DB8393F797 04E910100C0C070718FC060C0D0C00F7976729F3D7FD0ACDA9 FA06030A07F364FBC8D813C400F70CBA67080D0505F275DF05 8E00F70CFA75DF0FFA06030A78A268CB127B0CD97B07022D0A 06F80FFA06030A2D0A06F8F70CFA7F0FFA06030AC8D813C400 F70CFA17CF7417EA08F8F70CFA1AED0CC400F70CFA6F8E00F7 0CFA293D1A04977CA9FA0603DF731A3C1D291A212406977CA9 FA0603DF731A3C1D291A2124060CBA79A521AEB6253432D233 AEB6253432D23318018FE0120DECE67FAFD5000127D302CA0F FA06030A072518018FE0120DECE67FAFD5000127D302CAF70C FA07251BEF05020AC90500F70CFACB02E6D0050127F80FFA06 030A1A01270223F9EA08021B0309EF081E0F5A071E0F0F0714 290095BBDB003AD238731A0095BBDB003A1D291C382900058E 003AD238731A00058E003A1D291C382900058EA3019A00058E A3F9290095BBDBE5CC9A0095BBDBE5CC072900058EE5CC9A00 058EE5CC07C712040D0902C813C406DF6E71C9F50F5A00F6F5 0ADF058E00ED6B5107F5EC00D4080009EB0A0CE2190725750A C0D00E580F004D02750AC0D02018B992992134D22E0D5B11F5 5BFBCB92F8A70AFB750AC0D0CB92F826D3022134D2CB92F8C4 E7A711B9EAFCE90F0307EA09F55BB807E6DDC29DFEA70AB807 25A6BEF80EF0FAC400FC0AE40465E95777F6F301FEFC0AE404 65E9FC6BF7A1390397070BE7F0A6BEF80EF0FAC400FC0AE404 65E95777F6F301FEFC0AE40465E9FC6BF7A1390397070BE7F0 A6BEF80EF0FAC400FC0AE40465E95777F6F301FEFC0AE40465 E9FC6BF7A1390397070BE7F050E20CF364FB509B07F364FB1A E4197997E813FB1AE4197997E813FB411AE4197997E813FB1A E4561A04978213FB3FEF001004A1070D16070B080616C0D018 112A64F95918111B760C0D05D6117D181185FD0116030319E6 80E5EB0486D408002A64F97DF6F31105AB08FDD3FED408B992 99F50DF6A268BF112CA9B8E93B1E0BB00F023BE63FEFF4EBF5 09070300F0CEB7071105ABC3450506E87781D13B53050B6274 3BE5F00D1471A3F900DCF1DBD9894F7100DA02F900FCF3A0DB 00F7970FFA0603DFDCF1DBCD02F900DCF1DB7100DA02F900DC F1DB7100DA02F9000D05F70900F6BBE0DCF1DB71C9F50F5A00 F6F3EA08F81510F000DAF71206FB2571C9F50F5A00D0ADFE6D 7E60D611F50F5A0725260402F9F8480706FD4FF509E7A7E0FC 07EAECFBE649F00006F8DA15251E05C4030E0DFE0B840B19F3 A0DB17CF74F364FB211E0F5AE56CF3F0DFE70BED0AC06EE6CB 02FC0D0125293D43F3A0DBA4EEED06E8E3E5030AFEE813FB78 31078A0500FDF3A0DB78316D7EF8FDA4D0178A0500C800FD78 A26800840E81D5127831178A0500280500D51278314EF8D512 2206E816B7A4D0178A0500C878A26800840E81FD00FC450702 EBF80CF945DE45F2F3EA0802FF20119578A26800840E81FDA9 10AF07EA08023195F3A0DB1E1366E1D611F3A0DB1BE20AF364 C0D070AFA58F11E6A6BEF870AFA58FE0EDF403B5FCFBE5018F E0D0AA8EB992F881CB9299148393EE670F94070B030AFEFD00 03EEBADC8B01212203F9F4030AFEA202AB9606EEF4030AFEFD 0003EEBADC8B012532731C3300321D291C33CB48E877F00AFB 8003E5EB11F50F5AE957F0E6A6BEF8040F5A00F6F484070125 17F7EC00F603E5EB11F50F5AE957F0E61B8407FEEB03EEFA25 D2000E580FF301F8D0390397070BE7F0003FEF001004A1070D 16070B080616C0D018111B760C0D05D6113C00181185FD0116 030319E680F31105AB08FDD3FED408B99299F50DF645A268BF E054EE5F07FA482CA9B8E93B1E0BB00F023BE63FEFF4EBF509 070300F0CEB7071105AB08FD06E87781D13B53050B0017CF74 3BE5F00D142204EAF365048667E7A731FD0911E61B5711F50F 5A00D070AFA58F11251E0F5AF4EBB97EF8040DF6A268BF11E6 CB02FC0D01251BE704C60BBF00F6212204C6EBDFF79707CF22 04E0AA8EF3A0DBC813C4060AF50F5AE6AEB6251710ED020B0D F8D0D2AEB62500731C00FD001D291CAE02CA54ECF509070300 DCF1C6D11203ECC9F2F50F5A077DEE017BB902F099E6CB02FC 0D01251E0F5A00C107950FEDDBE6AEB625AEB1E56CF51212D7 F803EEFAF50F5A07E6CB02FC0D0125AE02CAFCD80895DB228A 06EA09F4840B19F3A0DB220DC4E5030A63A0DB2D0C0F02E00E 580F009E0F021B8407FE040F5A251B5706C0F634D28213C0D0 D22A098A10F80F08D5E1FE9D6001E6716BF7A16D7E45E3E9F0 0AFB14830AF5EC6BF7A16D7EE307253FEF001004A10D0507F0 F80CC5F9E6830AF5ECB97EE307252D2706F812098A10F80F08 D506F1252A098A10F8360DFAE0D5122A098A10F8360DFAE0FD 17063E63A0DB2134D271C9F50F5A00D00E01F8D408F49008F0 F8840BBC2571C9F50F5A00D00E01F8D408F49008F0F8EBDF12 0D0290FE840BBCE90D05F709F50F5A000127D60725CDF8A70A C0D00E580F004D02301718F3A0DB39030209FCFE69FAF364FB 75DFD02018B9929925C80702EBF80CC5FEC4FAF802AF07A0DB 3B82A10F94075E0A3BF301F8D0D5123B82A10F94075E0A3BF3 01F8D0FD6ADCF1DB4603FCC00E580F2134D232293D4333F3A0 DB268A10F8011212D702E9D512268A10F8011212D702E9FD26 030E0EC0EF02178A05C0D51226030E0EC0EF02412D2706DB17 8A05C0280D02260357CAD512260357CAFD18EB040EBA69FAF3 64FB6A0B5706C0D0D22E840B19FB2134D2200E05EDFB2134D2 731AA3F9F45706C0D01D291CBD16840B19FB2134D218FDEE00 AA8EF3A0DB9AA3F900DCF1DB2ACCFBA80AF4EBB0ECFBE5070E 07E6DCF1DBD98900280D0216032718EDFEEEEB00AF1C07BA20 22F51366F1E6A6BEF8FD011418EDFEEEEB00AF18F907F00EBA 2022F51366F1E6A6BEF8FD011424900500D5120030580FE9FD 00390397070BE7F000F66B51E9390397070BE7F03FEF001004 A1070D16070B080616C0D018112A64F900FC0B090D0ACA1811 85FD0116030319E680E5EB0486D408002A64F97DF6F31105AB 08FDD3FED408B99299F50DF645A268BF112CA9B8E93B1E0BB0 0F023BE63FEFF4EBF509070300F0CEB7071105AB08FD06E877 81D13B53050B0017CF743BE5F00D143FEF001004A1070D1607 0B080616C0D0181185FD0116030319E680F31105AB08FDD3FE D408B99299F50DF64545A268BFE054EE5F07FA482CA9B8E93B 1E0BB00F023BE63FEFF4EBF509070300F0CEB7071105AB08FD 06E87781D13B53050B0017CF743BE5F00D14CB48E8E3F364C0 54EEEFF8ABEB0EF9419C04F8E813C054EEEFF8ABEB0EF91A04 970AD3C26CF3A0DBCDF410EB0EF9E504DC178A0500FCF50DF6 A268BFE081D1120D020DE7251C07BA7997EDA994075EDFFC0B EDE70B02E6240811F50E04FC25180316E1FE69FAD9EDA2F80D 0519DA1505E69CD75669FA143706EEF5D9E7FECD199B6B0BEF 05F8D4F4EB00ADFE28AAF3FA8BF9E6CB02FC0D01252410FE09 94F86D9202E981D200E70C0313FBE630580F9606EC98FEDCF1 DB14CDC607F00AF2F4EBB0ECFBCDC607F00AF2F4EBB0ECFB2D 2706F8D51209FCFE0F08D506F1253976F90BE7F00002110F63 A0DB214F2815050069BAD5122815050069BAFDFF00A41710ED 020B0D99F410EB0EC0D0DC12040D09F80710ED020B0D991710 ED020B0DF894078A05FB731CF507078A05FBF5E9420111B992 F81D291A420111B992F8DCF1DB7100420111B99202E9DCF1DB 78A268F38A053181D028AA00D36B6004DB280D99060AFE1003 9705CF5E56C3040CF2F4030702E9A211F50FC211E6CB02FC0D 01251FFA07FDC4F3EA020DE90CC563CF1F096C169D19F4EBB0 ECFB78F3EA08029500D51278F3EA08029500FD1E0B6004DBF5 E90FE712FA08FB6B51E90F03FC021FC327E00A06E81609FB1F C327E0F0CE09FB1715D6AB00D5120002AFC1C26CFB1715D6AB 00D5120002AFC26CFB1E0B6004C612098A10F80F08D506F125 DDA7A3F900DCF1DBD9894F71C9F50F5A00D0ADFE0CE4C370AF 7C00130355E70BED0AF22571C9F50F5A00D0ADFEEED3F4040C FA04A91003F62571C9F50F5A00D0ADFE0B040CFA04A80AE5E4 45C370AF7C00E70BED0A45CA0D05F709F50F0FE60127D60725 71C9F50F5A00D0ADFE0B040CFA04D9ED00AADC0300E70BED0A F225CD199B6B0BEF05F854EC98FEE70C0313FBD989A910FD01 E620F854ECF3F7EC000127D3F8FD09FC01E6CB02FC0D0125AE DBD989000E580F004D022E0D5BE0DCF1DBCB92F8DCF1DBDD0C 0313FBD98900C80702EBF80CC5F2B99299AEDBD98900CB92F8 26D3021A0497ABEB0EFBDDC29DFE731C9606EE00058EBA4807 06FD001D291C25DD3652F8BFC9FBDD3652F80AF006FBDDAC06 0113C4E501EE030AF3A0DB2303040CCADC02D777D512230304 0CCADC02D777FD2204EAF365048667E7A731FD0911E61E0F5A 9606EC98FE080D05D98900731CD903090ABA1D291C1417D790 D611F4030AFE0BE704DB9F022134D2A6F804E9DC12040D0902 2134D217060C0D0902EB01EF07F50DF63107EA08F8EBDF05CF 5E196B51E9C1BFC9FB17F1010FE5030AFE57E3F364F9980402 D811E61715D6AB00D512A811156C2571C9F50F5A00F6F4760C 0D05E404C654EEF30CE2F80BE20A2517EA020DE9B627F8E813 FB4112E7FEB627F8E813FB24010CC204C608F0040CFB4330F3 A0DB7100DA02F9000D05F709F3A0DB000A0DFEBBC6DCF1DB1C 0FBBC60B760FF1B62134D2CDC6E813FB37010156AA8EF3A0DB D200E70C0313FB4E02CAF6F301F895E5CC6B0BEF05021F9D9E F86E4E60D6111F9D9EF86ECB92F8DCF1DB000A90F2F3110545 AB08FD06E8E3FF003CA40A0603A301FF003E411BEBB0ECFB2A CCFBFF003C180D09F70CFB9BA3FE1504D6CAD016FEE7AC0601 13FBFF003EFF003C180D09F70CFB9BA301FF003E1FF00AF2FF 003C1FE40290FE0CC501FF003EDDB087F29F0AF2FF003CBDE7 A7CEF1FF003ECB48E877DCF1DB1B57E012CCFB1B5711F30D0B 5107120D091FB8E93B4E023B00F6F4E704C6058EE5CCF55BB8 0720A2860BC30F0FFB2E090D012E08C90530E71130E7F02808 EB0E011FFC1923FB6F03F1021ACF5E19509B071AE41979A541 1AE41979A51AE4561A04A56A54EC98FEDCF1DBF5090703D989 0003EEFAB948E8E307E6CB02FC0D01257F6D48E8E38000ADFE EE67480706FD00DCF1C60127D302CA480706FDD97B07021E0B B00F02CA0F890FF854ECF509156C07F5ECC9F50F5A00F66B51 E96E7D54ECF410EB861E0F5A001E0B51076202CAD050156CE9 71C9FBC7EAE100DCF1DB000A90F2F31105AB08FD06E845E371 C9F50F5A00D0E704DF6E00FC211E0502FD110C072D27D62603 0356955305FD110C0722E4E3E21122E4E3E21122D3C26C6274 C70904E0F7A51BEBC1ADFEFFF7062B442C3CFF005C21FF003B FF003CFF003E25FF007CFF00A5341A04970BEBC107EA08F854 EED90DECF3F60F00EDF30F04B014CD0013C406DF09E4F0B01E 0B6004C66D02F00226E4F00BFE88C16466F126E4F00BFEE7B0 87FB34D229001001A7FA29A3011E0B51E90F03FC021BFAF712 E404B6CB02F0991BEF05AC11F403DC22F90B08060FE3CDF864 66F128080EEB06E8E335F00AED35FA0706FD3FF9CDC80BEDE7 0BF81718241F00ADBA7997EDA994075E0AE69CD719E5CC6274 14D296EB02E9F6F50ADFD4F507F5980D5B11E671C900EE670F FA07FD00F6F50ADFD425D296EB02E9F6F50ADFD4F507F5003F 04100303FF00210018F907F00EFAB99202E6CB02FC0D012517 FA13BA0A03F900C107950FEDF8040DEEF068BC0013C40D01E6 9CD719E5CC6274141BE704B1F5989D1995E504E0EA19630148 C4E5FC0D02F9E6220300C1E70C03A1D200EDF315D6AB00D512 A910AF0A90CAD1169D1995A9C35107142E9D1995B902F0023A 301718006E383A0F9D9EF86E383A37261E1A381BFAF712E404 B6212AE1FE02110FF92805FED55F3B1B760C0D05E4BC3B6274 7DD13B180D09F70CFB9B00E70B143B62B1F5086301F8D03B50 156C07F5ECC9FB3BE61E0F5AF4EBF3F0DF6EF50DF6A268BF11 142805FED55F3B1B760C0D05E4BC3B62747DD13B1F030706E3 F23B62B1F5086301F8D03B50156C07F5ECC9FB3BE61E0F5AF4 EBF3F0DF6EF50DF6A268BF11142805FED55F3B1B760C0D05E4 BC3B62747DD13BDD04DFADBA6E3B62B1F5086301F8D03B5015 6C07F5ECC9FB3BE61E0F5AF4EBF3F0DF6EF50DF6A268BF1114 2805FED55F3B1B760C0D05E4BC3B62747DD13B170CE2F80BE2 0A3B62B1F5086301F8D03B50156C07F5ECC9FB3BE61E0F5AF4 EBF3F0DF6EF50DF6A268BF11141B760FF1B628121209FC0128 0509FC012303040CF25305AB08FDD3F24EE3F3EA02AD211BEF 05AC11F403DC2171C9F50F5A00F6F50ADF058E006E00FC216A DCF1DB9606EEEFF8E7A7F26ADC0987FAFB91F900DC0987FAFB 29A3FEDC0987FAFB592900DC0987FAE012CCFB29A3FEDC0987 FAFB599A00DC0987FA06F9D9CCFB9AA3F900DC0987FAFB5929 00DC0987FAE012CCFB731AA3F900DC0987FAFB591D291A00DC 0987FA06F9D9CCFBC70987FA06F9D9CCFB3704D6F2D9ED00DC 0987FAE0DCEAE107C70987FAE012CCFB3704D6F2D9ED00DC09 87FAE0DCEAE107CB128A90BC62B1E90FC3AA0AC016E032D233 E617FA8BFE0FC3AA0ABA54EC00FC7C0C00D49610F000058EA9 10AF07D50215E2FEEB0AF50F5A6274F508FE6466F114220804 129922F90B08060FE31A04A535F00AED9A001001A7FA075C22 03A2FCF55BB8E9FDF3FA13BA0A03F900C1A202AB000A03A2FC F55BB8E9FCF4FAF712E404B66AC112EF05DFFDF3FA488CD0E7 AC06011301E65C0009E20EBAEEEBA910AF07950FED99143FEF 9606EC98FE0E0D060AC0F6E5CC629596063EE2DF1510FAFED4 F4EB000194E111F301F895E5CC160327F900EE04F8F0CEB7D4 00F6F3F00A7DE7B006A10CCCE9FD00D408E50316E1FE70FD01 E61FB8E93B4E023B00F6F3EA0802141BEBB0ECFB17FA13BA0A 03F900C107950FEDF8012702F00706FD0013C40D01E69CD719 E5CC627414C80B760FF1B62A06F1214FDDB087FBD906F1214F 7003F68503F67003F6078503F6072A03090AFA210032D2331A 23372410670CCCF4EB00FD09E016FEE7AC060113C054EEF502 EAAB0CF099220300D496EBF8D00E0300D0150116F55BB80721 39241826C80702EBF80CC5F2A80AE5E00FB8F0B0C8160327C8 07EAECBC9606ECA9C3B0C00D05F709F4760FF1B6E685AF0BEB C116FEADC00A90CAD1FC07EAECBC590113F0D9ED00010CFA0E F00B06F9E62290CAD1FC07EAECBC5F70AF54EC00B8EA080214 2204EAA80AB902F0F8169D56950067E70B760CF00AC016017C FED1FC07EAECBCE63FEFF4EBF4E704C604989D19959811F3A0 02CA3B49E3073B00FF003E003B1BE704C6169D19953BE685AF 0BEBC116FEADC00A90CAD1FC07EAECBC590113F0D9ED00010C FA0EF00B06F9E62290CAD1FC07EAECBC00D408A910AF54EC00 B8EA080214C80BEDE70BF86E9801E2FA62B1E69CD719E5CC62 741428080EEB06E8E32135FA0706FD21CB128A90BC21241067 D3F50009FC56D0731CE620F867840B04DBF5F81D291C141F08 D506F121260402F9F807F00AF22134D22694F895BBDB213432 D23326030BBC214F5C1603270081ADFE1611F5DAEEBADC8B01 DDB087C006A286D271C9F50F5A00D0FB06F8EB0AF50ADF058E 006E00FC211A04A52117063E01211ACF5E56FA08EDE66AC112 EF050A146AE7B087F2D9CCFB6A07F00AF2D9CCFB6A02110F01 2134D29AA3F929A3019AA3F91ACF5E1998AD11E6240811F50E 04810904D8141ACF5E56FA08EDE6240811F50E04810904D814 3ADAF55BB80738CDA3F93ADA0079A5386AC107950FEDDB98E0 E70B060F06F002CD0005CF5E19F3950FEDF87CA3F9E6CB92F8 D408F3FA8BFE0FC3AA0AFA143ADAF30D1640D70238CD006EF5 1366F1CDF8F0EF0E10A910AFA58FE0F6F304A1D1E7B087C006 A20E01DD0B060F06F0F8EDA3FE0BF0ACFE69BAC1FDD90627C0 0A06BFCA4D02610095BBC66466B712890032731C33E61C0FBB 02CA67E70B760CF00AFBE68000E7B006A1D195BBC6D4000501 C0F6B97EF8D0321D291C331485AFADFA1F0307020BE20AF3FA 8B01398A1026C91AED0CC46A0F0806EDD6112134D26AE7A7DD B087F2C80BEDE70BF8E70B060F06F0F8A70AB807350355E70B 030E050677AC04FCCAD3F516EFF8F6F3EA0802E61FF194FE6D 7EF81001A70701F8061200D40005ED0CBFE0ADFE06F854EE00 130355E70B030E0506E3E6350355E70B030E050677AC04FCF2 F310EF09DFEA19FEC29DFEFCF500360D0601F8F0AA08FD0CF0 0214DDC29DFE1206F1254FDD3652F8E740D7DBDD40D7DB214F CB02F0F8D016FEB865C054EC0003481508D6FEE8976D02F0F8 02110FFEA70AC0D0D170AF07FC0BFED1169D1995E6220300C1 E70C03A1D200EDF315D6AB00D512A910AF0A90CAB865F2E63F EF9606EC00C116FECEB7D0ADFE70FD01590113F0D9ED00010C FA0EF00B06F9E685AFA2E01004A1D016FEB8EA08DB1417EA02 AD213432D2338213C0D6010C071E08AB870129A9E2029AA9E2 99C80BEDE70BF807F00AFAF55BB8079F0AF2D9CCFB214F6A07 F00ACAE740D7DB98E04A4B0A9F0AF2214F9F02214F9FF8D601 0C071ACF5E56FA08EDE68CF6F3F00A1417FA8BFE0D791366F1 E6CB92F8D408F3FA8BFE0FC3AA0AFA1417FA8BFE0FC3AA0AFA 1E0F5A6B51E9D3F301F8D03B1E0719D97B07F8F7A53BE61E0B B00F02CA0F890FF8BFC907F50F5A00F66B51E96E000D05F709 F50F5A000127D607149CD719A363CF7449FA046500FC120321 1BEBB0ECFB2ACCFB1FF00AF2171C1F26A9030706E3F224010C C20402F980BB11350355E70B030E050677AC04FCCA1004E916 01F0F4760FF1DBE6350355E70B030E0506E3F4EB98FE9D6004 DB98E01003090ACA0AC9055F088A10F807A077888139039707 0BE7F000ED00AA04001001A707CFE6350355E70B030E050677 AC04FCF2F310EF09DF16FEE70F0104DB000612001001A70701 F8D3F410EB0EFB14A40A0603A3012A099410A301180D09F70C FB9BA3011F0307020BE20A240127F80CC50137261E1A72CB02 F0F8C107950FEDDBBD19DA15050005CF5E56FA08ED6A6DEAFC E90D0507950FEDDB00031640D7991C0FBBC6FC06F704DB9811 2134D21CC203A7F3FA8B01220887016FDC03F310E2F2C8D805 01F8B6F170FD014EF8D0D115011600D00AC9058404DF058EF3 FA8B012537261E1A6274211A0DB5BAC181AD01D2000501FBE9 B8EF085100ADC01611A80057F0F50F5AE61E050057F0F50F5A E5ADF816FE0B8407C0F6B902FC0D01141F04ADFBE61FF194FE 1504D6141FB8E93B9F0A3B00F6F3F0DF69FA21A6F816E0EE01 A5A4D0160814FF00266DAC1478F40309EF08A4D0F113010907 2A06EC00098A10B12E03090A2E0309DF0D050AFA09FC0120EA 09E420EA09E4000D050AFA09FC011F0904FC1F0904810D050A FA09FC0120A286FB06652AFDF80B0309EF08C807FAF8B62702 C807FAF8120804A5C807FAF80B09060F31E202C807FAF8B627 027540ADEA16B707063E011BC30F0006A20E012AFDF80B0309 EF081AED0CC42AFDF807063E01170CBF2AFDF8070211F12E03 090A2E0309DF0D050AFA09FC0120EA09E420EA09E4000D050A FA09FC011F0904FC1F0904810D050AFA09FC012D27AC04F30C BF180313011FEDAC0406F807063E0123F90B04F12303EAC6B6 270224012702212ACCFBCDF8E7AC060113FBDDB087F21FF00A F2178A790290FEC1FC0B090D0AFB1E02EAAB0CF0992134D25C F3F002213432D2335CE5070EE6FA08ED1FF00AF228088AFCC4 E5CCF3063E01213432D2333704D6F2D9ED00E7AC143220181E 1F4733A994075E0A28EEFA6274321F281F4333A994075E0A17 18241FA994075E0A5C6274C80B76F2F3FA485CF55BB8076100 79A5DDC21131F6F55BB80761F38A79020DE72A892134D25C00 1001A7FA3220181E1F4733260402F902260402F9F80D05E7A7 321F281F4333DDACE654EEF502EAAB07145CA301C80B76F2E5 CCF3FA482118E079A521DDC21131F6F55BB80721280D020E03 F2E5CCF3FA4821DDB087FB214F8213FB214F9F02214FC80B76 E63220181E1F4733F3FA13143220181E1F473300ADBA79A5C8 0B7614F3FA13BA02110F015C1603270079A518E079A5C80B76 CA321F281F4333F3FA1314321F281F433300ADBA79A5DDC211 31F6F55BB807280D020E03CA1718241FF3FA13141718241F00 ADBA79A51B0B212A89219F0221170D1640D70221802149F0F2 E5CC1603271BBFF2350355AC04FCCAE70B760CF00AFB7540AD 020CF099F364FB1A0497ABEB0EFB1E0B6004DB214F7540AD02 0CF0F812CCFB2D360DC4D3FA1B099407E4C446043E3E2D360D C4D3FA1AED0CC41F5723030B191E0B6004B61B099407E4C42D 0AD646043E3E1AED0CC41F5723F004A523030B19A6F89A1B09 9407E4C446043E3E1AED0CC41F5723030B19610079A5211BBF 00E740D7DBBD19DA1505F3FA13BAFA08ED1BFAF712E404C6FC 13C4060A6B0BED0ACAD070FD013BE9BBB69CD719B97EE36274 2D0808ED00030B0B9008FBE6AE77C10B760FF1DB1430580FF4 E7BCD9CCFBC813C4060AE50316E1FE69FAD9EDA202E6FF000D 348393D1FCD805BCC4F4EF05AC11F4030AFEFF002B731A003A 1D291C38D903ECC9C016E0D10C0316E1FE69FA2CD9ED000127 040CC2FEFF002B1D3D1A3D2F293D4347FF0035FF0036FF0037 FF003714C813C4060AE50316E1FE69FAD9EDA202E6FF000D34 8393D1FCD805BCC4F4EF05AC11F4030AFEFF002B731A003A1D 291C38D903ECC9C016E0D10C0316E1FE69BA54EEEFF8F1A7CA 3EFA032CD9ED000127040CC2FE00FF002B1D3D1A3D2F293D43 47FF0035FF0036FF0037FF003714C8AAEAE3F3F00AF2D9CCFB C813C406DF79A5CD0013C4060AF4FAF712E404B61C07BA2022 00C1E70B030E05D3C01611F3FA48412410FEADBAD400F0D8C0 0A03F900C10127D302E61FF194FEAC11F50E04FC146FDC0300 C107950FEDDB4603FCCA0E580FD9CCFB1BEBC109040D05AB98 08C907FAE61EDAEEBA466404F50FC2E6080D0505F21417F7EC 0095BBB1F3FA48E61BEBC19D5107F50F5A14CD006E00D00AD3 C26CCD0005CF5E19F40348040E01CDC607F00AF2D9CCFB731C F509E7A711F507078A05FBF5E9420111B992F81D291A1F0486 E73652F80BEBB0ECFB1BFAF712E404C6C1FDA910AFED004AA6 E2ABD9CCFB9F0AF2D9CCFB17FA13BA0AC90517FA8BFEC10795 0FEDDBA6E2ABF40806D89B00F6030009E20E018CF6E5E219E5 018F114B0A8CF6E5E219F30397D6010C078CF6E5E219F31107 B60CD906F18CF6E5E219F31107B60CD903090AFA8CF6F310C9 00031640D7028CF6F310C9F5EC00031640D79926D3F8D5000D C203A7F3FA8BF900C1E7A7111B030AFEF603F310ED0218E219 F5EC003BD23B1A0DB5BAC112EF050ABD0CE219F5EC003BD23B 2EADFCF9074B0A1B04F1050AE200F0AC111B5711F2180313F2 CDF8F0EF0E10E5018FE0FDE5018F114BDFF6F304A11206F1CD F8F0EF0E10A910AFA58FE0F6F304A11206F11F04EE00F60300 09FD0E2A099410A301C712040D090230580F0006A20E012130 580F0079A52130580F0002FD01214201110F04DF02FDF9211E 861289211E86F6211E02EAAB0CF002212E0B0B212204C6D598 7BEE211B0B211BD611211BEF05AC113CDD0E06FD212AE7FEB6 2702212A0806F00A09E079A52130F00AFA213903161606F921 78A26800840EFC217831178A0500FD2178314E0221FF00A478 A268B97E77A4D0178A0500FC212203A2FC211F94075E0A211C 07BA202221411C07FA79A53F04100303FF002100202221C802 F0E3211BF0ACFE79A5212D310CCCF3FA13BADA14215CF4F0AC FEDA1421750A06E3C4F55B0814211BD611211BEF05AC112130 E7CFCAB627022120A20E01211F0307EA09F403DC21DD0B060F 06F0022117EAB63C1FC313FCB0211F0307EA09F55BB8072118 E206EA09F3EA02AD219101211BF0ACFE79A52118070E14F4F0 ACFEDA1421280B0B9406FD2182A10F94075E0A2117EF050AF4 09060F21170D1640D70221240127022180216FDC03F409060F 2118EB040EBA79A518EB040EBA69FA71F3A0DB1BEBB0099CEB 0E011BF1E2D90601090AA6BEF8BB1128121228052D27D62603 0EFC178A0500FD4E0241178A0500C8178A0500FCC807FAF86D 92F8DCEAE11AAF07A0DB1F096C821301A648C4F3A0DB83DFD5 004DF802FD012150FAF87C21CDEECAD00AD3C26CCD0006A20E 019CEB0EF9F364FB2A060109DFC16466F1440028088AFCC4A3 FE449CEB0EF99606EC00C116FEE813FBE62D2706F8EB11156C 25C80B761472F509FA022123F2CA02FD012123F2CA1303090D A5211F08D5E1FE79A52118070E14F509FAF802FD01215CF4F0 02E76A0BF002E74AA3FE0BF002E72018F509FAF802FD01216F 160804B1F509FA0221D2E5FC0D02F926F9E9EEEB003D2F22F9 0B08060FE31C0FBBC66466B712890032731C333417063E0121 001D291C341E0F0FC32706A2C6FC07EAECBC00F7A521001D3D 1CE5FC0D02F93422F90B08060FE32100321D431C332D270FD7 DB00FC07EAECBC00F7A5CD199B0D05070FD7061206FB1C0FBB C6FC7CA2021417371C1F222E090D01F603EEA6BEF86D7E7702 110F0121DD31FC07FAF8A58F114BDFF6B902FC0DFE95BBB618 018F114BDFE70C0313FBE622C9058404DF12CCFB14CDF8F0EF 0E10E5018FE0FDA910FD01E61C0FBBC60BEBB0ECFB149F0AF2 2E090D01F603EEB97E77C112EF050AE685AF0501FBE9F6F3F0 DFE70FEDF8D5F30D0B5107120D090095BBB6E64E02CAD00F9D 9EF86EE62204EA72F40307F8A211F50FC211E64EF8DA1525DD B087FBD906F1CDF8F0EF0E10E5018FE0D0E7B006A11206F16F DC03F409060F00E7B087FB2AE1FEE7B087FB9AD9E1F900E7B0 87FB20A286E7B087FB24100197E7B087FB24AFE7B087FB4EF8 F6F3950FED023220181E1F47336B51E90F03FC02321F281F43 336B51E90F03FC021718241F6B51E90F03FC02230D09F9D9ED D90D029063FA48F311050B2150156C07F5ECC9CB127B0CD97B 070250156CE9E740D7027100D6010CE9DCF1DBD989D903090A FA22C90584A7F4EBB0ECFB2A03090ABADCF1DB180313C0D0D2 AEDB18018F114BDF7CA202DB18018F114BDF7997ABEB0EFB1F 94075E0AF410EB0EFB1F94075EDFDCF1DB1F94075E0A629F0A F2F4EBB0ECFB17EDDB6F8EF3A0DB1F94075EDFFC0BEDE70B02 1F94075E0AE90A0300C1A202AB8CF6F502EAABD906F1C7EAE1 E9C16466F18CD0DCF1B68CD008F004A5CDF8F0EF0E10E5018F 119F0AF2D9CCFB8CF6F304A11206F118ADE43503E4018503F6 23A706036FDC03DD0BED0ACBAC9402C7EAE10730BFFA118213 0122C90584A7072EE0BBB62EE079A52E11F3063E012EE07CA2 023008060A26D3F854EE00DCEAE10726D3021A0497C4E7A7E0 0127D3998CF66B6004C66D02F0022410FE12E1FED3F4571108 8A10F80FC302D7DB2900D6010C00C1DCF1DB9A00D6010CE9C1 DCF1DB18018FE0120DECE67FD6010CE912890030BFFA111418 018F114BDFC17CA202DB1A04970BEBC107EA08F854EED90DEC F3F60F00EDF30F04B0A6BEF8EA080E01F81203090AFA43303D 18112A64E6E4FD0775DF1203090AFA50FAF802FDF91E0F5A07 1E35202E181F1B09060F31E2021B57E01203090AFA1B57111B 5711088A10021AFD011FC302D7DB1BE704DB7FBFC7EAE10726 F00EEE2D0A06F87003F61A04A52AEDA2022A08040CF924110F FED500AA8ED200302E30202A30080470E407461F2D30D20019 2E18E219CA57E307D200182E18018F11F3EA02AD9CEB860F94 075E0A2AEDA2F8A58F114B0A18010C144BDF57E3077F0F9407 5E0A23F00497A50C144B0AA6F80F94075E0A3A0D057CA202DB 381803A11203090AFA18031301181F4718ADE4D9E1F949F049 F00030BFFA1120A20EF91F1A307F1203090AFA23F903090DE3 24FDF923F2CA02FDF9821301170BE7F0F364FA07A4EEED24D6 F1370116F55BB807A6360DF0B022C90584A707A6F804E915BF 0F040FFAA6F86DAC940217063E0149F000FCF301360DF0B017 ED022410010CF943301FBD19DA15056FDC03F409060F076F8E DD0BED0AF20737BF0F040FFA07372E181F37183518018F114B 0A83D8E5018F114BDF79A5218393058EA994075E0A2183D8E5 018F114BDF0F94075E0A2135FA0612E0058EA994075E0A212A 03090ABA79A5211BEBB009000AC90584A72522C90584A7F2D9 CCFB49F0D9E1FEDA1525002AE1FE0AC90584A7C0D0D214AEB6 2534D22A03090ABAC1010C0F0211E6AEB6253432D233CDF8F0 EF0E10E5018FE0FD4B0AE682A1D070FD0125CDF8F0EF0E10A9 10AFA58F11E682A1F6E5018F114B0A25CDF8F0EF0E10A910AF A58FE0D00AC9058404DF1206F12AEDA2F8A58F114B0A257FBF 006E00FDE5018F114B0A2518018F114BDF54EC98FE0D05840B 19FBE6CB02FC0D0125D2E5EDFEA58FE00501FBFBE6A6BEF812 E1F900D016FEDCF1DB257F1203090AFA253432D2332AE1FEF6 030009E286D00AC90584A717063E01FF005A037622C90584A7 F234D22AEDA202B1E5018F114B0AAEB117EDB19CD719F2F3A0 DB00D6010C3004970AC90584A7072DB5FB0AFBCD2812121710 C900DAB63FF94E77F7A531EF0278A268CD3FF96FDC03721BEF 05D807F4F1E2FB509B07F364FB1E0B6004DB214F24060CFA07 F4F1E2FB1F9D9EF86EB97EE36B60011F9D9EF86EB97E77FD00 1003090A9A002E1F9D9EF86EF50DEEF068BCD9CCFB830A72D9 7B07021F9D9EF86EB97E77C16466F183DF0F9D9EF86EB97EE3 D97B070283DF0127D302CA0F9D9EF86EB97EE3D97B07021F9D 9EF86E00C1BFC9FB1F9D9EF86E6B51E90F03FCF8C113C4060A CDF8BFC9FB170D16070B080616FED00F9D9EF86ED97B070283 DF0F9D9EF86EB97EE3D97B07021BF1E2F4EF05D8071BF1E200 F70CFA072D0A06F89DF7A19D51E90F02141F9D9EF86E00F70C FA1E0B51E90F03FC99301F2317E503DC0C17CF742204EAF4EF 05D81F9D19E66E00F70CFA1E0B51E90F03FCF89A2204EAF4EF 05D81F9D9EF86EB97EE3F48407C016E005CF5E191F9D9EF86E B97E77F00AFB1F9D9EF86E00C16466F11F9D9EF86EB97E7784 07021F9D9EF86EB97E7784070250156CE9FD09FCFEC16466F1 1710E2FBB97EE3E68CD0F00A141ACF5E1998AD111F9D9EF86E B97E7784070217FA8BFEC107950FEDDB24010C0FEDE2E005CF 5E19A9C316F10C371E1FB97E77F00AFB1E0B51E90F03FCF89A 61F5099B07211E0B51E90F03FC02212290BC00D5F5ECF3F907 14DDB087C0810994F807F907147100E7B087C06E9FF8810994 F807F90706FD71F3F0F86E1F9D9EF86E6B0BE60F02141E0BF7 A19D51E90F03FC021E0B51E90F03FCF8C49B071F9D9EF86 |
09-21-2013, 09:09 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | rocessing Image File : rm618__08.35.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 511 Entry Point: 0x01E5 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm618__08.35.ppm_mh CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 117 Entry Point: 0x0100 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm618__08.35.image_mh_0595236 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 378 Entry Point: 0x0134 Page Format : -1 MAX PAGE : 0x0000E000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005361 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00FAF27E ID DWORD 2 : 07DB51DF ID DWORD 3 : 79ED8C2F ID DWORD 4 : B2C14078 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0131 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg .fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 80106F00 FUR control Ok 0000000B START READING RPL DATA 0000081D IMEI: 356236049680176 Reading : NPC... OK! 0000000B 00000415 Reading : CCC... OK! 00000415 Reading : HWC... OK! 00000415 Reading : R&D... OK! 0000000B 0000000B NPC CERTIFICATE INFORMATION (CMT): IMEI : 356236049680176 PRODUCT CODE : 059F8H0 BLUETOOTH ID : D4:5D:42:75:87:4D PUBLIC_ID : 0000000000FAF27E07DB51DF79ED8C2FB2C14078 PAPUB_KEYS_HASH: E9700989029D9E899915F781B1582048E042A738 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 059F8H0 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 0000000000FAF27E07DB51DF79ED8C2FB2C14078 PRODUCT CODE : 059F8H0 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356236049680176\3562360496801 76_13423.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 00007883 Reading : ISA-USER... OK! 004D5050562030382E31370A30392D30332D31310A524D2D36 31380A286329204E6F6B696120202020202020202020202000 FFFFFFFFFFFFFFFFFFFFFFFFFFFF4D4800005C027664E42E08 005458455438433932313036005C000000A6030000434F4D4D 800000001005050A0B0F050C01090701050B0707070B080705 080908050F07070501010608050E19050506060A0005010003 0E1E05081701030B06FF500075007200630068006100730069 006E006700200064006100740065003A004E006F006B006900 6100670A2000680A2000690A4C006900660065002000740069 006D00650072004E006500740020006D006F006E0069007400 6F00720043006100720072006900650072002000750070006C 006F00610064002E004E006F00720073006B0049006E007600 61006C006900640020006400610074006500902150006F0072 007400750067007500EA0073000C0165006101740069006E00 61009121440061006E0073006B0045006E0074006500720020 0064006100740065003A004500730070006100F1006F006C00 45006E0067006C006900730068004F00760069002E0063006F 006D005400650073007400200069006E007000750074003A00 CD0073006C0065006E0073006B006100440065007500740073 0063006800F1060C20F2060C20F30657006100720072006100 6E0074007900520065007000610069007200650064003A0049 00740061006C00690061006E006F00530075006F006D006900 410070006F0069006F0020006100200043006C00690065006E 00740065005300760065006E0073006B0061006F2031002000 3200200033006E20E70A2000E80A2000E90A2A0092216D006D 0079007900790079004600720061006E00E700610069007300 4D006100640065003A00530065007200690061006C0020006E 0075006D006200650072003A00500072006F00640075006300 740069006F006E002000730065007200690061006C0020006E 0075006D00AD00620065007200530061007600650064006709 200068092000690950006F006C0073006B0069005400FC0072 006B00E70065004E0065006400650072006C0061006E006400 7300E70C2000E80C2000E90C2300E117E217E317470072006F 00750070002F0064006900730070006C00610079003A005300 6100760069006E00670020006600610069006C00650064002C 00200063006F006E0074006100630074002000730065007200 76006900630065004D0079003100390031009503BB03BB03B7 03BD03B903BA03AC035400650073007400200069006E002000 52004E00440049005300200055005300420020006D006F0064 0065003F009321610662066306410074002E00200043006C00 690065006E00740065004D0061006700790061007200FFFF01 000000900B0200454E303098000000002000650074006F0061 006E006900730072006C00640063006D007500670070006800 7900660076002E007700620053004D006B004E004300550025 004100500049003A004400520054003F004C0078004F003100 460022002C0045004200300047002D206F206E000A00560071 00570029004800280027002F0032007A0059006A0023004B00 33002A00AD004A003413FA280F4C18F4E2172009D3CB7E00D2 1E090BF90DF917111506E4FE1900030F08EF2C005DBC0A0A18 CCC2E415ED00D1F7131A8EF3CFFE070413F608CCCE06E9F70B 7AB591FEF50B04110BFDBBEA35060F101EECF4BF1D2FB1071E 0A030CE300A4F60504050D060812EDA8DF05D7AEC62403FC00 17042D0509031F100EFE06139EE0C30C060E13E48DB7BDCE01 150CED0D0818C5EA0BD80004070D0F00150CFE001602071D1A 06041B10040B190117F001BE13FE0C04E5C51E0D0C01170104 0AF505000F13060B1002080D07C7F1FDFE0B0102F2B3B426CF E9D40C16020109FE08F9F4FDFA000A0404E31C05F10B04ECFB 00DAF80F0908030409F9DE02FE220120050315F2001BFD04E1 1A0304160102F600EEFE1D1C060711EF03120602010B02FA00 12050302FB0A012301E80E0A00110006090408F7FD060B000C 140008010704070002040405090903080210030D01050901FC 0E0007000B000402030206020001070108010A060503050100 48FF070D0A0E08040B07070907040706050707180A050B0905 0B070A05060708040808060B05070B04010A05050C0A090806 0C0A0A09040308040809070804060C03020404030406070B08 030220021009130C040406341009080B080F040A09120D1011 211C17160F100F110B120F0E0B1C0A0A1D0A1F0B0F0E180C0A 090B0B110E0C11100E0E0C0B0D0D0C0C0C040303040409060B 0A070405040604050405040E0609090403030C0D0404080A06 030B0A100D0B040503161719120604050904050704050A0906 0905090C070403050E20090B090514180A0F0A081616170609 11110C190908080E0D1F16240E0D0907180C05070707070607 03070A0B07070608030207050504030505090A12150A0A1211 0E0E090D0B180807100B0D160203020508040105080E040907 0E120513081B0F0910110C1012140E070908161362150E1908 100F060F1E1D1914151E23050B0709090E2635422B3A111810 200D0508050B0A0F0E0A0A0C0A130503050202030404040507 17070809030B060A0503060815090E0D090E0D0E0A02040303 06060A090608060608050A06070B080908050706060507080A 0507010608010605090213100E0E0505070505040A0708180D 090B0A1218130A07060403060809050405030708070B07030A 0808070D090C080B0605080303040607030304171312080205 0407060B050305090509040709020C0B030403030408030608 0808050708161818100813151B2019190B031C1F0908060507 0A08030304070B03021D0A080803020C0905070D090C050504 060D09051A191707040807051E1B0612070404040303030304 040F02070A06070C090A020203070708050310120A08030207 080203030303060202040C0203030606020202020302020303 03020E080517080C0B060B0C0D12070A0807040B09050B0309 0403080A090C0F0A0E08070308090706080307080602101007 070718160B0D0405050405090C080B06060708060706061F0A 0C07060D1E2525250606080809097A0A1507091115131D0E07 15060D000A0609090B060C1D14092A141A0A07191911711D16 0909080C090C260E17080C090C0807051B0C180F0B0A091529 0C060B09100F0E040A080C0B070607050706050A0708080C09 09071B171A2078670F0F0A09141A18221F0B0B0F0F08071D0C 13090C11230E0B0908140A080E0D100B19152B1B2F0B070613 0B071607080E0B0A280D050D1F1F190B0A00000B05160C0509 070F050405140C06031C0F040E04030B07060B150804040303 0503020404030506061E051B0037150E070305060505060600 003A0A090A0B060308070408070507040502011E2227223A08 0707060807433E3E3F05060505070709110C06081314141809 10081041050703040701260A1A5C0523060509030304040A03 1C140410044C82160806061A060C0B0611081604050F080808 0303031313070306101E0907191C38040B0302040A0304116B 0908067A09070504040E080E0504060E19093B07090503040A 07037E0606090707050A0D120E0804070A1607082F0D0F070B 060708040B040C040B060807080B070A080804070307040B04 0C040B07040A050705030804040D0A090804100A0C050B0903 07050409070506070509060B030A050A0C0605040F0C0C0704 0E0B090E09030303070208030E0A07070A0606040604020405 0603040402040403060404020405070C19081509636E0B070D 13200A0A1F15090C09180C0F0606070A100B0C0D0F0B0D120A 09090A070A040418130A06060907080A050408040803040B07 0A050708080509080506060000060C05070B080A0406080509 080A0A0A03070B070809070502080707040404080503020304 050206050A050303060A05080607090A180A0709080C050507 0A0A060807420E03090905070B14161A034A07120C07090708 06080E0D0B12070808100A0806020A0C0A08060803050B0D09 0805060A0608030403040304040404030604040605040A030B 0A130A0A150B180D0308070604030307080307030504020404 07030405080403060404070408080909060907080804030602 07040306060306030803030705060A06040A03050305080206 070403060B0A0E0D080B091505131517160A0D171A0B0F0405 080B02030B0905010306020703010204090607090B0E030E07 0C0E130A1105130E08080D0908080307090907120B0A0B0B0C 0D070B0A10090906090B0C070B050B0B0B070D07100C050404 08050A00080B0807090705060408080A0109070609040A0E09 0A070C04060805090A08060704040600050609060705080708 070809070B0A07090709020E05060505080607040B0507060F 0D090505040C0A09070909070803030605050404090906080D 090A09090E0909070408090805010303080807030B06090908 0D09060C040604080604080706060807070409070604040502 060502060907060C0A0B0906080C070B04060501030A0A0809 07090A0801090E0D0D090C050B070908050306030505030702 050B0805070B020504040B07070B0309090905040708060806 050507040507080A020407030804090504090609080307080A 080B070807060A0B040000090C000000050608070609060604 0C080C0607070B04060A0A0B0A0A06080907080C0A050B0808 09080A09080905070906080D0D0809070809090A0808050508 05090B080A040606030406050506090C030307050708080B09 0C0A07070C03020A0A0608070A070B09080B0603050807030D 030409070A0906080709080309040907060509070507070607 07070B05050F0C0306060408090905090808060B0A0803020B 67040B09120909080509060706080808040807030204070807 080608030203020408090604040407090D0303050707060603 0205070B0C0108040508070608060906030905070407090705 050803080A0B05080508050504090501070503030906070309 030304090B0408050807080A05050402040605040403030203 09040302070508030B0306080A0B05090904050505060B0B00 0707080406050A08020307070503030605050F0C0105070906 06070603060B0703020405040A040807060607060508030205 05050303030305070706010101060507090D03060709070708 0506040807040606060703060506080603080B090807050707 080707070A090908090B0A0C0A0807070A0608050906060804 08040803050507040A05080A0B060A09030307070604030304 030404030403040506030E0A120E1010090808060505060504 080803070607030C151008152A0E0A09090E1A161011231511 090C0A100F0812050D1708121A1411070B070E080508081313 1E0F111111150D131F0D1409060F0607131E0C180E1007090B 100F0E0A07161012071513090F110B0E160707050807161921 140F090C160C0A1D11140E13130913220E0A0C1A1A1A000E10 14171615383B0F1D1708080C0C0B0A0A18070A09110A070B02 0310120904161212100E12100B12053F3B668C150E0E1A0B0D 1213130913141112090A0A080C06060A091F1B1F1C11050605 0A03050504040E050901040707050A08040708040314161609 09020C0D110604040304101A160716150A0520090A110F1005 04030609090401010101010303030303030509020C09151305 09080D09030604060605060B07070408040506050804080603 0E0606060F0A08060507060806080B0F060805070C04090C05 070407090504130F0E0D0B1614161F091412080E0C13080707 1510152029241F111010060707080606050B06090E0F060606 060C0602070606050D0A0A0504090508040B11111607131C0B 072722131019040D0B05042803070A09000008090B080A0204 07040706050A0808040307070304070506040704090E090408 080603040A0405090A070709090A03060605060808080B0305 08060A0A0A0A0A070703060706060D09060707040707000503 070803030D080A0806030707020403030305070707050A0707 0704090A060A0206080A0A06080B080205060809090A0B0808 0606090305060505040A080D08070A090C0506070308080207 0504070B07090B0806050A06080707070B060E08080C070404 04050D060606070707050A04050504050C0808110607060607 0705070603050906060506030C050E06060E06050506050609 060A06050604060604070E110B0E0308020303080A03060305 0503080C08050404070B05050B0B05050605050C050C0B0405 0505050509080D050504050505050405040C060A0404030304 08050505050A0704040707060405080D04040603070407050A 050A0504070305050705040606050505060703030510040303 04050506040405040505040404090404090606050B04030505 0B090904040505070505090505090608050506080805050604 0507040505030306060410070507070C05030506040C040607 06090E0806070306050405050509060607030408090B040707 03040804080404040409030304060E040D0603030C0D070706 051306050607060704060606080504040F0A0904040907090C 0604040404060607050A0610060A0605070404040809040508 100405080704080F0C070508050E020E030505070805080504 0306040C050408050505060D040408060E0608080608080B0F 110808110E0404060904040405040906080608030609070804 0C030607030A060506050406080206050404040C090B0B070A 03090505000605050D09030503080909090909040705080904 08080909090907070D09070908060C08090A09050705080908 080C0605090305070B0A080D0A0B0A07090808090D09040707 030508090504070A070D0D0707040404090E0707030A030E06 06120C060504060A060D080D050809090808080C070A070C06 04040309060808070808060806070403060C0D030A0C0E0206 03020B0407050606030D04090B0408090B0A08040204040A07 0604040505030804040E04040806050A030A0B09080B0A0507 0A0A0705050503050709070908060806070303020305050307 0B02050605090B070807090603030905040A060A0807070A0A 0A0F030D0B060A090507040307070509000A0504090A0B0000 0B00000E0F0D00000B080B06130C06030A070903070404040A 0807070D040306070703070803040705060501070407070B05 0518080808040B0708070E070C0A090807030504050A060B05 04040E050A0C07060B00050605090D09000000000404060607 0308080B090606000000000000080005000400000905000005 06070000030000000000000004050300040805040300000300 06090B06000300000200070303080808050604020906060000 05080800000604080306070A0A0A0006070607000603000000 02000000001005060A060608070706080800060E0D00070500 0600040806060B060B0E0F0000000014000005060B07080712 11050600000005040000070603000504000000070000090300 0003050407020907020004000000030800000000040605090A 07070C0A09080D090B0B05050B09030B09060B15030B0B0A06 130409060809040604070406080608060B0A0806080A000000 05090A03060C060A040A060B0806030807030A0A0B01050502 050A0C0C0A0A060A070C0C09040808070A0B07070408060405 050D0505090A0607040504070507050B07090A070A07090506 08050C08060C080109071008090808080C0709090C0D070808 0D0809060506050506090A08070706080803030908090A0307 0703030308030A08000C090509070907050404060B04050609 040809090808060304050A08070A070604030000050000060B 05000005030709030C0706010305070B080603040403070608 0B070B0709070A0B06060808030404040606080B0B09050C04 0603070806030B03090600090B070A03050A04090904050309 01030603070708000009080B04080B10080B05060805040803 050408080908060B0D0909090B0D0B080C0A0A0A0306080405 03030B040702060D0A0309060404060A0401010A0807060407 080207040B090809060907070B0407070A0807080807060508 0806080C0A050802050305070804070A0B030A0B080B030B1C 2D14250D655D04030504040202040305050303030A08080203 02020202020304020C0C080A0B080402040302020302020203 03040608060303030908010101040305040802090905050907 05050309080A040303040722182B144F830D2A2A230D0B0703 04050C0804040B070D080801050C05040504070B0807050B06 090607090504050605060A04070904080808040A070C080806 0407070B0A040807070A060709050806070B05050506070404 0C0F080E0A050405090907070505060C0D040705080B070407 060604040504060D07080A0611030406070506060D07060503 06080607070906090605060506060503080608070A09070603 050803020803030803020803030C14088B92896E0B0C252031 07121C0D07070914070C23210C0C0A0D13171716100F070F1C 07170808080909060A1A0C0C0E1D11090A1B0D0D0C190D0905 1608151E350718210504280305412420091021030522090544 06222A130F46320F433B0505041D03081510090F0B15101410 040203040409050A06050609040305050504050A09050B0B0B 0B04223E350804050C07060505040404040A060405040A0504 0404070605040507030A0907040705050506050A050A040405 0408100A0E070A0D03050804050505030304060D0C0F090C08 0A07060E0908060506070702020202020415120D0607090A0A 0B100E0A032607040C03030207091108080804040404040304 04030304070304040603060604070503080604040303040305 0304060403110A0A0A08081D0C0C090A09050B0A0703030408 061F1209090E07030305050C0C0C0609041918181504040802 0709060A0516090F050D0D1A0E0F1A221E210D040B06060806 04080805080A0B0707090A0C1C07050C0E0C0503040B070C05 0A0605040705060B0607080517150505080C050D06030A0807 131512050607070705040B0507040605050406050508070509 06060809080705050506070408080508050504070303040405 080803080505040407030909060409040A05060B0904030606 070404070C0307050408080607040807060404030503060804 0606060806040504060B0A0804090405040506060404070608 0404030503030609050207090505050A0B0803070603030503 040907040B030303080307070403080709040503090505040A 04040905040405070403070608090509090708080906090804 0C1308160A0C06070908070806030A0805140E0607110A070E 2308070E0B09080B110B1B39050F30340C070707060B080B06 140B1B7716131707352F1E1055826B6429524931221E133608 08010D150934071B06080C071B0E0D090906110D0C100F1123 0F08110807080D0B0F2117190C0D15150B0E140C0A0807120A 170E080F0D0D1E090E0E0F0C0A141414141209161213120B07 121A0D0C0C1B141514181209090E14181C0B130B18180B0E16 131618081507060B110C0A1715090A16151010080E180C0D09 0A070F07070D0B0A0C15050909081112130D0912090C0A1204 0F170B0E230E0E0E111407080B1D1213130C17141409160B17 0B160F1613171314111312050A070A1109070D160B0A090F12 161A0C09360C0A040D120D0A260D0A322922071A1308090815 0D0A16151F100B130F0D13120F0E0A111911162E0C0D0C0B11 0B131307101311111212101113181B140F0714150A0F071010 0B10081411090B08080A1017160D120C0612151E141E1C0709 0B11100F130A0D15060B0A0A0C0A091616293A161519070807 1D08090912060E0714130B0D0A141E0E0D111B1B07110A150C 0F0E0A110E120B120B121A27131E0E21070E090B1B141B2712 10200D090D100B0E0E11170706111117170C1C130707081D0B 0B0709080710110414181C07171E1F2A0F16470F0F0D13110A 11132F0F171E3D1E2548501A171B19171311050C1E2B08090C 080F0C110B060B101227060815100F100809150A0E0C14061F 100F124B090A080F0D0F0B100F0D0D1624060F081D130B0E10 1118080A1D150B0F0E1C09090E071D0A1E2E16120B0B17130B 0B2B2C0A06110B211C1C2318180A150C0611130B1712120F10 09130C160A0D1815181515130C0B140E0E585B0A0A061C0C1E 1308421C0A30311E1B111D1E220C110A0C0617130D090A0911 1119150E0D13120F131211090B071010100E060C0D18080737 2C0E5412120E10111F0C120A53101010140F0B051508070E0D 0D092C121515110B15131C12130A0B0909070E0C0D0A0B110D 0808351B121D1407140A1E180B26041115350C2C1A0F1B0F10 0C10170E0A1616170616110811030608050A130B0C090B080D 0B0D0810051238101019250D0C050C1A13071B05051B08110B 1C1F050B130807130E290811101008120816140506120E0C0A 1716090A0D09151110130C102A100D0F0A100E140E0C271011 10130E0A0C0B06050C0B090F16150A0E140E0E2113210D0B0F 0F170F0A0F180E1811060C32170507080C19200E0A0D070E11 160E09080F081411121D07080C0E16140D1005051812160E08 0C0909060A1F2D130F0D10090A090E0C090F141D080D051309 140319060A08070505040E05110D100F0F13130D0A0D080E0C 1910060719090A100E090A0A16090C0D090B0C101012101612 0F0E1E111115131406071609111414161410110F1513150A0E 0B0E0A0D070C0F080C0F15130F10101111161404080D121E12 0F11140817121A13130D17131E10050708080A081207000700 0A0B0D1209060A110A07090C05110511070C0C100E0C0B0808 090807080608080306020606030603060A0308050608090705 0712131B060504080A0910090813200713141716181A100608 050A0C050407070D0602040704080706080A0B0D1303021208 06060A0D0C070706050404080E090E040604120607050B0707 0707060E0609090504040A040B13090B050805050303070F08 080C0D0E080507050405030B0B08060606050509070605300B 0E100F070A1E07060C0F0C0804030905040E05050302060406 050807040E16121111101C0F08030212180812040302141A19 0D101D130E16070A05070809090904070403020D0908060509 0F050303050C0708060407070904060607060A060B0C061316 13141406140707080B0B0B0D10100E0C0B1107060609080A08 090A110F090A09081113071216090809060A0C1B0A0B080907 04140A06080B0B060808060C050B130F0E0906090703091909 1A1518120919181C1A111A0B1806171908080D1B070F041517 181B08090C070706090F090A08070D07060810040406050404 1D0D0C0E100606111213131B0A07181E070809070E0B163B2A 0C162D0010110C0D15431A1418221C1D1B0D181106060C2410 1311211B275D1609161B1F0C0C000A1F190D291F220E0C2815 181A0C24070D07140A0507080F12080F130B0A0E1C1A22180F 0E18170F171810111B0A12110D15190D0A110C0C091712232D 291B0510312A102418252817140B0A0C131021162911071111 1311110610081C131E13130030100C0C292C16151513240707 2714101D120E12420E15231F1A210B061D13070B0C0A0C0F0A 0B0D0605150E100C090808080D0D090D0E0B08110C0B0E1516 0046681B3C1B1113190710170B0A1A150A0E25121209123229 24140F1D1B1A1A1C070A080A0C1A10030915150E1F2F160613 111B070608120E0C08070A080516080D060A04040906060308 0703040302080B06120F0909040A0904090506070505090406 070509060603030809090A19090C0E18170D080B050C0B0E0A 0B09030B0306040818070703050A180608060906030A130807 20060C0803140E0D0B090A0B140B100F080A09020704050707 090904070709080B0C080503060309060C04030C0504060505 04050405040605090B0B08020807030706030604080906090A 0B0E0D0F070606070707090D06070A0F0D0A0A10070C060C0A 0C04050B0D07090B0C080A080C082105080509070B040B050E 100B0D190D150D0B100905070A090705060710070306070608 160815090C090606080505070805030A0404070A0506040707 060703040A18070B090D09130A1E180E090C090B1303070405 070508180C05050E0604030F04050607070503060C06070716 070A2903080709141401090603030605050606031103060703 07050515020604020204040304020503030302070205030303 03030105060304070503060605040300060403040303040504 03030405040404050305040302040505020205020404030205 05060102050504040502060504080204040102040504030603 0302060603020306150A0E0B0A090305040303080503080607 0E0A0D170803022010080C160F110C08070A080A0A06080B1A 190D16080805050507050804061F0C180C1F0E100D0D0B0606 100F0306050808050505110106030303030807090A080E100A 0A100F05060E05090805060A0D07080B080707060709070809 0F0B0E25050E0703091203040D0E0B0805070A0507050A0606 0503050C08080509040506060A0B050F0A060522312E04040E 0706060C0A09080906070708130E0B06060C090A0311070D0A 090A0B0A0A0D040509090E03050A07060408080508040C0706 07030705050605090905060404060802040303080604010A07 080A0A090A04050A09060500040704040B070608060906040D 09060504060B07090C07050708030604080608060704040504 03070407040706070404060501040504040303040501060404 03040404020605050506080504040607070303050505040703 07060506070B050708060808050607060B1905040912141006 070B0000001D1C1D0B0B0B111314091C4B0E0813090B32270D 391D110E1A1011080B0B0B11131421101116081709370B1F1E 37222B0A000E11212324101226474500130B121D090D1A1816 141B0B1210070807090B1C11120F0A0D0A0F110E0D131B1216 1B0D210F09100809080C0B0A0A0813060808090516090B222E 0C090405040C040B030B04080A04191B1B1007060917170D0B 0B0803030205040908150A080C0B02030B0A03070B02060707 0A0A090808080407060604080A0C0B0B0709130A030D0B0C0B 0B0B0906070C0A07040C18060C050D08090B0C0E0C0A090809 0D0D0B0B09050207080607080D060B0908060706070E0D0C08 080A0A090D0B0B080505090B0A090708090A0706050507020B 09080A0E0A07100D080708050B060D0D0A0B0308070608040A 050C0E0808070C0A08090C060508090A080B03060B0A040706 0D05060E07070707090D04090C08090904080B0B0A0A03020A 070605090605090B0A17140F07150A130B131D16141A131A1C 15120B090A1515151616161219061515171716161012121212 0B0A1110100F0D070A0E0E100E2514102405050408070A050A 080C0C0B0E0B0D0C0E0C04090D0F0C1A0C07110A0B0C040907 020408050B0A0808160E0F0D0C0C0D0D080A0D030B0F070C08 040A0F0E06080C070B1610060E0E0F1025100B100D2C090607 06060F0A0D13080F0C07100605090D09050712080707060607 0E0F0F0D0B2505040F0A0C0B090D0A080A1108090C0C0A0A0B 0B0B0E0C100F03010907080609191A120606080605080A0904 060508090A050402050305080805030A0904080B0905060B06 07080B04070E09060505070709070905070707070909070606 1A1A0D071A1404050206050307070704060405060709080606 0400000605050605040708070704080B0704050B0707070508 03080A102405040505060406080911070903060A0C0E040B04 0A060905090B0A030210080703090208050303080908070D0D 0B10090608060A0A06050E060703020A070D0B0C0E05060606 09090F10100106050705040308050902030404030702030804 03050E050E04060607030404080304041B040405030706050E 06050304040E0101010303070706040508060807020405050A 0202010202020103020D0A070B07090303070408030B020A06 06080A0302060A0B060A0A0B07080D07040309070109030202 0302090704090A09020206070B060706070707040604040407 0202080102070C0D081110110908071A0C0D060E1413050707 04120709030704110B03090507091013180C0C10080F0B0A06 0C0B020809030D0704060A0B0A090B08070807090908090A05 0809070A05050303060E0C0E0303070F080C06050607080603 080609040609060A020C0806030F02020D0606030A02090308 0708060708070812090A040A0D09080507030217160B0A0704 03070906090608060C0C070408030604040A070409030A0607 0308040606060703080A060709070A090707050608050A0903 080608080705060D07040C0202030105090304020605040504 060903050508080A0505030308070409060703060709070507 0703040604080908070706070908040A0A090B030410020406 082205090D08050B09030603020A0A0B060C1107090504050D 040206030B0D040C030E020D070702070905070304020A0A04 030808070509070906080803090B0C0403080307050D050406 04040A0712040606050503030D0B0709020A0C0F0C0B090D08 02030A1008090A0A09050B0C0A060D070A06080C051108050A 0506070203040803030503040B0E1106030A02090808080909 0E0F0B0A05100E0D0D100D06090D030303030C0A0A080C0B07 080A0805030303020909080B0E030D020C0C0F0C0E0E0A1907 0E0907090D060D0602040608020401090C0A04020B07040808 08080B1806070304030906050808070C090B030E09170E0303 0803030704061C05051A05040707150E0704090D0A0D100904 0D0309030B06080610120C04080603030402020C0A07070508 0A0A0A0C07070A090506080E060F0907070A05050509060602 0405080D0706070406080905080207030A0503070505050404 0309020C1006080F050508050A0805060C130B130505070706 0309050605050B0A0503050202050503020404030402050403 03040302020303040403040303030304050304030303040104 02020203030305020404030403030203050504030404040503 050404040202060A1A11101110070504021004030709070907 080705040A0602060403050A0805020407041004071011030C 070707040203060604060709090612050E010906070D050209 05050B07020A1006030215090A03021907050B0A090A020606 09080708090A050704040C070A0309050404060405050F080D 0F12020309080811101014140B080B0C090A0B0804090C170C 1513150503060302050A07070C080906070708030904040811 131312090A15080605070A0F0F110709050B09070809090807 0D0E06080D070B07100C12100C100F0B110C0B080807080B08 0302080B030203080403020203030303050D0A06050D0A0907 0708060B0C0D07020B0A0F1106050A0E070909020507060A0A 080C0B0402010203020607080A0A4624341F3C1B311E213117 29262623281818262A0F614C29112346243C23294B1A231313 28171C17392825414724192B1F1A412D2021142D2B1712251D 0D1435251E1B211D1D1C260B131F1B213011171F5115112632 331D172139463F192638274C9616113167635A2A305B647E7C 4F1B701B333D28592C211A2D1F31492D5B1A7B7C8989848D6D 7D423B383A231B311B3735143E429B8C1C351F1F2041311E1F 131A0D1C232232652A3A46631113211A20161E141D1C252B24 1728305A637D7B451A24674A13273056637D7B4E1A1A4D7B36 4E32305A637D7B451A2B301A1F2C9544614F76661925472130 19141B571A352F305A63837B494A231F421C7B14152F151642 3054637D7B4E1A251F5030211F1716331B23821C2B2610291B 1A101D17261B1B2127331127141F1992151A16423A24305675 8687511A1E1E11211F253418212018682D642B305A637D7B43 1A20200D301A2A22221420470B123488172247651D305A507D 7B461A1E20662944231B1D242D37331C30347D7B861A13305A 637D4E4E1A828F211965163C938D161420124536182C1E0E83 0E4D10FF0000C712040D09F80F08D5E163A0DB240127F870AF C19D6001240127F870AF07A0DBD9ED00AD011E0B5107ED1162 749CE20EFAC712040D09F80F08D506F118ADE4F302EB0A2401 27F870FD011C07FEB627F870FD011E0B5107ED06F99CE20EFA 39EB0A0712E7013901A770FDF93901A707CF18ADE4F302EB0A 240127F870FD013503090D976D02C30900C16466B754EE00EE D36B5107ED111B9008F0F80F08D506F126035707CFC712040D 09F80F08D506F11C07FEB627F870FD011E0B6004B61BEF0502 0AC90500F70CFA4EF81001A707CF731A141D291C0018393E18 E018ADE429E5D307FB729AE5D307FB72073ADA00FC7C0CBC38 23A7060329000D05E7A7A3019A000D05E7A7A3F91B04F1050A E21BEF05020AC90500F70CFAA6F895E5CC3A010C0F02113830 F0FAC400FC0AE40465071B840B19D223A706037D18E018ADE4 18E018ADE4CD00DA02F93ADA00D6010CE90FF00AF2383ADAF3 10ED020B0D9938CD00950B76CADA02F93ADA00ADBADAB638CD F712E4BC0728080EEBD36310ED020B0D999CEB860710ED020B 0D02A6BEF80710ED020B0D991710ED020B0DF816E218E0DAB6 A6E2ABCB02F0F8C16466F13704D6F250E20C0002FD012150E2 0C0002AF07A0DB50E20C0002FD01DD0F0104F8C4E20C23A706 0317DA033EFEFD4201010F0008A7060300FD2550E20C28422D 0808EDC87C0CBC50FA0237E205F27100DCEAE1073A29001101 E2381E050587FAE808E0DAB6213A9A001101E2073828121228 051E00480706FD00D500EED3F50F5AF509E7A7E00127D399E6 49F00006F8DA152549F01E0F5A00E1F10EBF11E5030A061206 FB1E0F5A00C112EF050A1E0F5A00C112EF050AE622C9058404 DFDA15251E0F5A00D3F509E7A7E057F01E0F5A072D27AC94A4 0A0603A3011BEBC10701F8783107EA08F8D050156C07F5ECC9 C00D0509F9E91ACF5E196B51E9D3F410EB0EC0D01E0719D97B 07F8F797FD091178A268F31105AB08FD06E8313477D512A4D0 1303090D97D512A4D01303090D97FD180D09F70CFB9BE5070E 149CEB860F94075E0A2E0402D8E0C1120DEC11F410E20EFB9F 0A4B0A359B002E090D01F603EE359B00B627F80CC5016A1684 0B19C0ED00E70B060F06F0F816AD11A6BEDB2134731C343A1D 291C3850FAF87C000D0507D790FE0C030AFEFD50FAF87C000D 0507D790FE0C030AFED512220300C107F0DF150116F55BB807 F9F5E9BDE403DC343A321C242A31FF003833389FDF150116F5 5BB807F9F5E9BDE403DC343A321C242A31FF00383338371826 170B08060F02E9C1BFC9C00348F3D790FE6D7EE3371826170B 08060F99F5ECC9C00348F3D790FE6D7EE32408A7E69CFCF9FE 3A2E8AFF0035382408A7E69CFCE63A2E8AFF003539423837F9 D805003A202E184743FF00373837F9D805003A202E18FF0038 FF00352F3846040FEBF9FE3A2D1C1B3817060C0FE69CE63A30 2E29FF00382F432F3817060CC2009C813A302E3D43293D3817 060CC2E69CFCF9FE3A302E423846040FEBF9FE3A2017283837 F902E63A2017280032FF0038FF0038FF0035FF003933313229 33381AED0AE4003A2017283824100406003A201728382EC468 003A2017280032FF0038FF0038FF0035FF0039333132294333 381B010968003A2017283837F902E63A2017280032FF0038FF 0038FF0035FF003933313229FF003533382376EB06EB003A20 1728381BF0ACC4002D0DC30FE63A2017283817EFEE002D0DC3 0FE63A201728382EC468003A20172800FF0038FF0038FF0035 FF00393147381B110806ECE4003A201728381E08CEE4003A20 17283830E701563A20172838390116E715003A201728382490 19D310003A2017283846040FEBF9FE3A171006120231462017 38BDE4030AFE3A1C1B1731323D333837F9D805003A1E171B20 2038BDE4030AFE3A1C242A313229FF00363338BDE4030AFE3A 321C242A31FF003833381BF002E62D90E63A37FC0AC907381B 110806ECE4003A37FC0AC9073837F9D805003A37FC0AC90738 30E701563A37FC0AC90738249019D310003A37FC0AC9073839 0116E715003A37FC0AC907381E08CEE4003A37FC0AC907386F CF790CE63A37FC0AC9073824100406003A37FC0AC907381E08 CEE478A2682EC4681B0109689CFCF901CB02F0F8F00B030AF2 1B110806ECE41BF0ACC4002D0DC30F01EB17EFEE002D0DC30F 01EB1710ED020B0D9930E70119390116E71539D3651146040F EBF9011AED0AE42376EB06EB24100406249019D310BDE403DC 321C242A31FF003833001C2326076FCF790CF90137F9F82D0D C30F01EB371826170B08060F991E08CEE478A2682EC4682408 A706E3C4002E8AFF00352408A706E3E62E8AFF003539421B01 09689CFCF901202E184743FF0037202E18FF0038FF00352F1B 110806ECE42D1C1B1BF0ACC4002D0DC30F01EB17EFEE002D0D C30F01EB17060CC20612E6302E29FF00382F432F17060CC206 12E6302E3D43293D17060CC2061206C0302E4230E701193901 16E7152017282017280032FF0038FF0038FF0035FF00393331 3229332017280032FF0038FF0038FF0035FF00393331322943 332017280032FF0038FF0038FF0035FF003933313229FF0035 3320172800FF0038FF0038FF0035FF0039314746040FEBF901 1AED0AE42376EB06EB17100612023146201724100406249019 D3101C1B1731323D33BDE403DC1E171B20201C242A313229FF 003633321C242A31FF0038336FCF790CF90137F9F82D0DC30F 01EB37FC0AC907371826070B08060F02C813C406DF150116F5 5BB8071710ED020B0D9939D36511A6BE02170D160CD64E77C1 07D70DE7E6CB02FC0D0125170397D6010C07F508FE0D0507D7 0DE7E6260304DF0D0507D790FED6010C0725CB02F0F8F00B03 0AF250FAF87C000D0507D70DE7BDE4030AFEA70A0814170D16 0CD6750AC0D00F047BC0DC8BF9004D02E64EF8DA152578316D 7EF8FDE6CB127BA245E39606EC00C116FE9419FB141F047BC0 54EE3432D2332E090D01F603EEB97EE3F4EBB0ECFB22D36D7E DB213432D2334EDB00F63432D23326D3F8D5A9047BC0DC8BF9 D90DECE67F0400DC8B0125CDF813D30616B7D003EEBA2E090D 01F603EE00DC8BF978316D7EF8D512E6CB127BA245E39606EC 98FE9419FB141A0497E813FB1710EDF87997E813FB1E0BB00F F80F047BCAE73652F81289254F28EEBADC8BFEC1B80FFD0AF2 E6DDAC11251F047BCADCF1DB213432D23326D3F8D5A9047BC0 DC8BF9D90DECE6DDC29DFE0400DC8B0125DDC29DFB213432D2 33A6E2ABF4EBB0ECFBA6E2ABF4760FF1DB2E090D01F603EEF3 15D6ABC0D5122E090D01F603EEF315D6ABC0FD85AF6713D306 16B7F6F301E2ABCADC8BF99610F0002E090D01F603EE0067FD 85AF67B60C0FEDE2E1E013D30616B7F6F5EC00DC8BF93708FD 0EA994070B03DCE683D8F304970F94070B030AFEFD9803EE00 DC8BF9E6DDAC11254E77E740D7DB98E003EEBADC8B012E090D 01F603EEB97EE3D9CCFBCD00DC8BF9D9EF050A1F047BF2D9CC FB1F047BF2A80AB905E6E740D7DBD9EDF3D790D6E0E794FD07 CB05E6F6F50D0A06036B0B147F0F047BF21E0BF7A1DC8BF91F 047BC0DC8BF91E0BF7A1DC8BF92E090D01F603EE78A268B905 1435D30616E1D61132D233C78BF9D9EF050A2694F812EF05DF DC13142E090D01F603EE00FC12032E090D01F603EE1F047BC0 DC8BF91F94070B03DC75DF058E00DC8B01281212280539EB0A 0712E7011B760F0DD83901A707CF39065BF028EEFA39EB0A07 CFBD19DA150550156CE913D30616F124010C0FE613D30616F1 1715D6AB00FD002E090D01F603EED97B07022E090D01F603EE 006716AD11E6240811F50E04FC14DD6D7EF8ADF23432D23322 D36D7EDB213432D233C79D6004C6E70C03C64AE5030AFE127B 070222D36D7EF8157BFB6B5107EDE0127B0702839329FF0036 000A8A06F80B03DCDD0C03C64AE5030A63F7EC6B6001C813C4 06DF0F047BF261B97E77C1BFC9C016E032D2331A0497C4E7A7 E00127D39928050911F50D0A0603D9E1F99606EC98FEACEB07 12FA08FB1F047BCAC1E813FB1F047BF2F364FBA40A0603B97E E3F509E7A7E00127D3998003E5EB116BF7A1DC8BF9CDF30F9D FE7C00058E00DC8BF98CF6F410EB8613D30616E1E61510E1FE DC8BF9B97EDB3FF9281212280522D36D7E021710C90500F6F5 EC39065BF0CD61F301E2AB1F047BC0DC8BF9001F0904E0AA04 002E090D01F603EE23F004A585AF13D30616F1214F2E090D01 F603EE750AC0D00F047BC0DC8BF9004D024EDBA80AF55BC0D0 0F047BC0DC8BF9004D024EE3D9CCFB1F94070B030AFEC1F0D8 C081F7A5E6DDAC1114DDC29DC054EE214F8003E5EB116BF7A1 DC8BF9E622D36D7EF80400DC8BFE127B0702E64EF8040D0A06 039606EE253432D2334EF854EE253432D2332206C43195B97E E39606EE253432D23371C96B51E9D0CB9202E91611250032D2 33DDB006A16ED989253432D233DD0C03C64AB97EE39606EE25 3432D23317FA06C4A9EDF86D7EE39606EE253432D2332204EA 00ACEB0712FAB97EE39606EE253432D2332D27ABEB866E9606 EE253432D2331710EDF879A52183D8A994070B03DC2185FD01 3BE979A5214E77D0D1DC8BFE54EC98FE840702E6CB02FC0D01 25001715D6AB00FD002E090D01F603EED97B07022571C900EE 67DC8BFEF6B97EF8040DF6A268BF1125009C030307CA3B3FF9 3BF5ECC907B97EE3E9D0EA19FEC29DFE040DF6A268BFE054EE EFF86D127B0CBCE69C030307CA3BCD3BE501EB07B97E77E736 5202E954EC00E7360D7BFED408B9127B0CBC1422D36D7EF8BF 6BF7A12E090D01F603EE00DC8BF92522D36D7EF8127B070225 3432D2332E090D01F603EE9606EC986315D6ABC0D512E6CB02 FC0D012522D36D7E022534D2C8D80501F86D7EE39606EE2500 32D2331715D6AB00FD002E090D01F603EE257F0F047BF225DD C29DFEEB000127D302CADC8B0125230D0505F2F50F0FE6E736 520221001715D6AB00FD002E090D01F603EE25230D0505F2F5 0F0FE62E2400E7365202210039060AFE70AF1289F5EC25230D 0505CA2E2400E736520221A910AF13D30616B7F6F5EC251F04 7BCA54EC00C116FEE813FBE6CB02FC0D0125A6F870AF13D306 16B7F6F5ECF301E2ABCADC8BF925A6F870FD013BE92E090D01 F603EE0013D3061609D6E0D03B39065BF03B25A6F870FD013B E92E090D01F603EE0013D30616E1D6E0D03B50156CE913D306 16F13B2578316D7E021E07078A05F310EDF879A52E090D01F6 03EE85AF13D30616E1D61118E070FD013BE979A54E77E740D7 DB98E003EEBADC8B014EE3D9CCFBE69CD756EE04F803EEBADC 8BFE6754EE8108EB86EBDF2E090D01F603EE0067FD1485AFC1 6D7EEA16B7D003EEBADC8BF9000A0DFEF66BF7A16D7EE307E6 80E50419FE70AF6D7EEA16F159F0DFAFEDE5EDFE6D7EE30714 85AFC113D30616B7EDB97EEA16B7D003EEBADC8BF9000A0DFE F66BF7A16D7EE307E680E50419FE70AF13D30616B7EB0AB97E EA16F159F0DFAFEDE5EDFE6D7EE307144E77E73652F8E740D7 DBE64E77D032731C3300C1BFC9C016E01D291CE622D36D7EF8 EBDFAC11F50E04FC14CD00DC8BF9D9EF050AE69CD756EE04F8 D1DC8BFED4F5086301E2ABF2D9ED001004E92E090D01F603EE F315D6ABC0FD7DD3F301F813D30616F11485AFDA15B97EEA16 B7D0E70C03C6DC8BF985AFDA150013D30616B7EB0AB97EEA16 B7D003EEBADC8BF91F047BCAE740D7DB98E003EEBADC8B0137 08FD0EA994070B03DCE683D8F304970F94070B030AFEFD9803 EE00DC8BF914750ACAD00F047BC0DC13E64D021BEBB0ECF24E 02CAF63432D23322D36D7EB11F047BCA54EE003234D233A6E2 ABF2D9ED00DC8BF91715D6ABCAD512002E090D01F603EE1715 D6ABCAFD002E090D01F603EE22D36D7EDB213432D2337831DC F1C6DC9D6004DB2204C607010FE20465F3A0DB359B002E090D 01F603EE1B04F1050AE2F509E20CF3DA033EFE9D6004DB2D27 0F142150E20C2E7BEEBB111BBFAEB62D0AD61801CFF218010C 0318031301DD0CFC0AFA2204C6EBDFF7A5CDC6030B0B90E9FD 09E0FDB0E6CD00E70F0104F807CF141E12932900BB111E1293 29960101197100030B0B9008F051A6E2AB300300D080310A03 004D02C807FAF8DAB62805FE030B0B9008F0B0DD0CFC0AFA82 130137010156AA8E170F08CA2AF960C480B5F31501010FCABB E03AFF0051CA18CA4606013826EBD805002AF960C42208040E FD002E0304F82AF90214FF0037EE001A8A10F82AF960C43010 0307F82AF960C418060A31A4020D0C05002AF9021422EF16B7 FF0039EE002AF960C4FF0038EE00D500293DEE0018FDEE6100 3F01E23BE92D13019C0D2601040F18FDEEFF00B7FF005A10F0 0E2606009C0D05FF00589B00FF005A1006FF00589B03001710 0D22040017100D260600FF0051060D9C0D0017100D2E040600 260DFF0051060D002AF039EB00260D17100DEB0E004606EB0E 26060022FD0E3F0D0017100D06FF00589B0300FF00580D0122 0400FF00580D0122FD0E00FF005A1006FF00589B030039EB22 040039EB46CAFF005A10019C0D05002AF0FF0051CA18F2300D 003F0D260600FF00589BFF00589B030018EB18EB0E00FF005A 10FD0E26030BBC2117EA08F8BBB6215C3A070F04B038DD0CFC 0ABADAB6213150E20C00D51250E20C00FD2204C607010FE204 65C872830A6BF7A10BBFA80AA80715FAF3D7FD0A7225A40A06 030058DB00D010EB0A0712E701A40A06030058DB00D010EB0A 07CFA40A06030058DB00D01001A707CF22D36D7EB139EB0A07 CF39EB0A0712E70139EB0A07CF3901A707CF9F0AA3011715D6 AB00D0AADC03722805001003090ACB02FC0DFE0BBF25203B0C 98ADE0088A10F8DA15E6203BEC7200D4000904D81449F00009 EF0A070F010419FA2578A268D909941000FD2A099410F315D6 ABC0D5122A099410F315D6ABC0FDD2F3A0DB1434342A099410 F301F8D0D512141BEBC1E70BEDDFAADC03D9ED00181817E69C EB8607CF74148CF6F304A10B760FF1C67003F6F301360DF0B0 2AC407FE0B0309EF080730E711070B04F11A010E0460011AED 0CC4A60F9B170309E2D3012E088A100205F907C712040D09F8 F702F12D1212D7992A0994101B040CFA041803DC1FE7AA8E00 F7A58503D0360DC4D6118503F6F3063E01A6091231F70CBA09 8A1099A6091231F70CFA17CF741B040CFA04F3EF050A078503 F6F365040E016FDC03F4040CFA046FDC03A9E7AA8E6FDC03F4 09060F00360DC4D6116FDC0300B803090DE36FDC03F409060F 00F1050EEE3710D6FE16C4EBB0C712040D09F81203090AFA18 018F114B0A85AFA58F1128EEFAD903090AFA2E94E4398A101A ED0CC4C712040D0902180427060C0D0C398A102E94E41AED0C C4800057F0001B040CFA042CF48407FE0B9008F0F8040F5A17 650486840BBCF410EB0EC0F6E5018F114B0A17650486840BBC F410EB0EC0D070AFA58F112E088A100205F907AEB62D1212D7 992A0994102A09941000D5122A09941000FD26EB0A070B040F FE7CA20285AFA58F11180DB661A91003F66100AADC03F40906 0F1B040CFA041FEDAC0406F87CA20223F004A5A6091231F70C FAA6091231F70CBAD5129F0A8503F6F301360DF00BFED51285 03F6F301360DF00BFEFD17CF74BD0C0DB6398A102E94E41AED 0CC46FDC03F4040CFA0478A268226C098A10022A090DEDF90B F002C80BEB0AF90BF0023710D6FE16C4EBB0FF005A0376FF00 5A037600FCFF005A037600EF021B040CFA0400FDF302EB0A16 11E618018FE0120DEC141B040CFA0400FDF302EB0A1611E61B BF00FCA9C30EB807141B040CFA0400FDF302EB0A1611E649F0 00F10507F4034814731A141D291A181F001D3D1A271D431A73 1A141D291A181F1FC35107F2E5018F114B0AE682A1D070FD01 251FC35107CA70AFA58F11E682A1F6E5018F114B0A25CB92F8 C4E7A711B9EAFC07A80006A20E01E6DDC29DFE06A20E0125BD 07950FEDDB9610F000AADC03F409060F00F1050EEE00D3F301 F87C001818178503F6F301360DF00BFEFD1434342A099410F3 01F8D0D512148503F6F3063EFEC107950FEDDB00FCF301360D F00BFE0C03DCC712040D09F81203090AFA78A2686FDC0300B8 03090DE3F301F8D03B26C93BD9EDE50D09F70CFB9BA3016FDC 0300B803090DE3F301F8D03B18FB060D0C3BD9EDE50D09F70C FB9BA301C712040D09F80C03DC28EEFAD903090AFA9AF3D7FD 0A07CDA9E7AA8E830AE5EB0DBF118503D00FE7AA8E00F7A585 03D0360DC4D6112E94E4398A101AED0CC48503F6F3063E01A6 091231F70CBA098A109928121228052A09941000C107950FED DB9610F0003B8503F6F301360DF00BFEFD3B141B040CFA04F3 EF050A0718042714F51366F12AED00181817A3012812122805 8503F63CAADC03F365040E01C712040D09F8F702F118E0F702 F16FDC03A9E7AA8E6FDC03F409060F00360DC4D6116FDC0300 B803090DE36FDC03F409060F00F1050EEECB02FC0D01CB02FC 0D011E02EAAB1B040F020DE71B040CFA0400FDF302EB0A1611 1FC35107CA7003F6078213CAD0D278D909941000FD14343437 10D6FE16C4EB0B6301F8D03B783B142A09941000FD14343437 10D6FE16C4EB0B6301F8D03B783B141B040CFA0400FDF302EB 0A1611E6CDE5018F11F3A0DB14BD0A03F3A0E3071BEBB0097F BFA3F9D9894F258213C0D6010C076AC1E813FB180D09F70CFB 9BA3FE0BEBC116FEE7AC060113FBE6DD0C03A10F890F022518 0D09F70CFB9BA3FEE7AC060113C4D9CCFBE6240811F50E04FC 2582A10CC5012585AFC18110039705CF5E19E6CB02FC0D0125 9CD719F3EA02ADEB2CA80E0B2CF410F059F00E125910FC59F2 055909085909072CF3103E593E101EB58A0DEFE90FFC11FC62 B1F364FBAEDB850894FEE813FB1EB58A0DEFE90FFC11FC61A9 100894011C07BA700894F9850894FEC4E7A7E00127D399C813 C406DF700894011EB58A0DEFE90FFC11FCAEB67FBF2D0AD6C8 0F0DF80C03DC1C07BA700894F983D8A91008940121AEB62534 D27FBF255305AB08FD06E84577840E07F4F1E2FB1BF1E2F5EC F31105AB08FD06E877840E07251BF1E2F5ECF311050B0723F2 CA02AF07A0DB1E0F08A40E2204C610065BF02204C60AD3C26C FB22D73018242A01162A08062204B62406973EFD01040C0F0C 3018244FA6F8F797EBDFBBC6127B070246EB460D09460D0539 060AFEBBB61710C900BBB618E2186C18FDCD13280B028202A6 0F170D0524100D240D0137FBA6BEDB9610D6FE16C4EBB02134 D2281640D7F8A70AFBAEB62534D2180427060C0D0CA363063E FE0127B0FBC016E09A00192EDD0C03A106A20E01DD0C03A107 EF050AF409060FDD0C03A1AADC03F409060F280D021603271A 0497D572BAD3F310C9051A0497D572BA67C10710C90578A268 B902FC0DBC00F0CE09FBCB02FC0DF2F512D8B9127B0CBC00F0 CE09FBAEDB213432D233230D0505F2213432D2338213FB2134 32D233AEDB213432D2337FF70CFA1BEF05020AC90500F70CFA C8D813C400F70CFA071FFA06030A8000050127F80FFA06030A 17CF7417EA08F8F70CFAD98924060CFA78A268CB127B0CD97B 070271A9FA06030AE9DCF1DB7100F70CFAE9DCF1DB8393F797 04E910100C0C070718FC060C0D0C00F7976729F3D7FD0ACDA9 FA06030A07F364FBC8D813C400F70CBA67080D0505F275DF05 8E00F70CFA75DF0FFA06030A78A268CB127B0CD97B07022D0A 06F80FFA06030A2D0A06F8F70CFA7F0FFA06030AC8D813C400 F70CFA17CF7417EA08F8F70CFA1AED0CC400F70CFA6F8E00F7 0CFA293D1A04977CA9FA0603DF731A3C1D291A212406977CA9 FA0603DF731A3C1D291A2124060CBA79A521AEB6253432D233 AEB6253432D23318018FE0120DECE67FAFD5000127D302CA0F FA06030A072518018FE0120DECE67FAFD5000127D302CAF70C FA07251BEF05020AC90500F70CFACB02E6D0050127F80FFA06 030A1A01270223F9EA08021B0309EF081E0F5A071E0F0F0714 290095BBDB003AD238731A0095BBDB003A1D291C382900058E 003AD238731A00058E003A1D291C382900058EA3019A00058E A3F9290095BBDBE5CC9A0095BBDBE5CC072900058EE5CC9A00 058EE5CC07C712040D0902C813C406DF6E71C9F50F5A00F6F5 0ADF058E00ED6B5107F5EC00D4080009EB0A0CE2190725750A C0D00E580F004D02750AC0D02018B992992134D22E0D5B11F5 5BFBCB92F8A70AFB750AC0D0CB92F826D3022134D2CB92F8C4 E7A711B9EAFCE90F0307EA09F55BB807E6DDC29DFEA70AB807 25A6BEF80EF0FAC400FC0AE40465E95777F6F301FEFC0AE404 65E9FC6BF7A1390397070BE7F0A6BEF80EF0FAC400FC0AE404 65E95777F6F301FEFC0AE40465E9FC6BF7A1390397070BE7F0 A6BEF80EF0FAC400FC0AE40465E95777F6F301FEFC0AE40465 E9FC6BF7A1390397070BE7F050E20CF364FB509B07F364FB1A E4197997E813FB1AE4197997E813FB411AE4197997E813FB1A E4561A04978213FB3FEF001004A1070D16070B080616C0D018 112A64F95918111B760C0D05D6117D181185FD0116030319E6 80E5EB0486D408002A64F97DF6F31105AB08FDD3FED408B992 99F50DF6A268BF112CA9B8E93B1E0BB00F023BE63FEFF4EBF5 09070300F0CEB7071105ABC3450506E87781D13B53050B6274 3BE5F00D1471A3F900DCF1DBD9894F7100DA02F900FCF3A0DB 00F7970FFA0603DFDCF1DBCD02F900DCF1DB7100DA02F900DC F1DB7100DA02F9000D05F70900F6BBE0DCF1DB71C9F50F5A00 F6F3EA08F81510F000DAF71206FB2571C9F50F5A00D0ADFE6D 7E60D611F50F5A0725260402F9F8480706FD4FF509E7A7E0FC 07EAECFBE649F00006F8DA15251E05C4030E0DFE0B840B19F3 A0DB17CF74F364FB211E0F5AE56CF3F0DFE70BED0AC06EE6CB 02FC0D0125293D43F3A0DBA4EEED06E8E3E5030AFEE813FB78 31078A0500FDF3A0DB78316D7EF8FDA4D0178A0500C800FD78 A26800840E81D5127831178A0500280500D51278314EF8D512 2206E816B7A4D0178A0500C878A26800840E81FD00FC450702 EBF80CF945DE45F2F3EA0802FF20119578A26800840E81FDA9 10AF07EA08023195F3A0DB1E1366E1D611F3A0DB1BE20AF364 C0D070AFA58F11E6A6BEF870AFA58FE0EDF403B5FCFBE5018F E0D0AA8EB992F881CB9299148393EE670F94070B030AFEFD00 03EEBADC8B01212203F9F4030AFEA202AB9606EEF4030AFEFD 0003EEBADC8B012532731C3300321D291C33CB48E877F00AFB 8003E5EB11F50F5AE957F0E6A6BEF8040F5A00F6F484070125 17F7EC00F603E5EB11F50F5AE957F0E61B8407FEEB03EEFA25 D2000E580FF301F8D0390397070BE7F0003FEF001004A1070D 16070B080616C0D018111B760C0D05D6113C00181185FD0116 030319E680F31105AB08FDD3FED408B99299F50DF645A268BF E054EE5F07FA482CA9B8E93B1E0BB00F023BE63FEFF4EBF509 070300F0CEB7071105AB08FD06E87781D13B53050B0017CF74 3BE5F00D142204EAF365048667E7A731FD0911E61B5711F50F 5A00D070AFA58F11251E0F5AF4EBB97EF8040DF6A268BF11E6 CB02FC0D01251BE704C60BBF00F6212204C6EBDFF79707CF22 04E0AA8EF3A0DBC813C4060AF50F5AE6AEB6251710ED020B0D F8D0D2AEB62500731C00FD001D291CAE02CA54ECF509070300 DCF1C6D11203ECC9F2F50F5A077DEE017BB902F099E6CB02FC 0D01251E0F5A00C107950FEDDBE6AEB625AEB1E56CF51212D7 F803EEFAF50F5A07E6CB02FC0D0125AE02CAFCD80895DB228A 06EA09F4840B19F3A0DB220DC4E5030A63A0DB2D0C0F02E00E 580F009E0F021B8407FE040F5A251B5706C0F634D28213C0D0 D22A098A10F80F08D5E1FE9D6001E6716BF7A16D7E45E3E9F0 0AFB14830AF5EC6BF7A16D7EE307253FEF001004A10D0507F0 F80CC5F9E6830AF5ECB97EE307252D2706F812098A10F80F08 D506F1252A098A10F8360DFAE0D5122A098A10F8360DFAE0FD 17063E63A0DB2134D271C9F50F5A00D00E01F8D408F49008F0 F8840BBC2571C9F50F5A00D00E01F8D408F49008F0F8EBDF12 0D0290FE840BBCE90D05F709F50F5A000127D60725CDF8A70A C0D00E580F004D02301718F3A0DB39030209FCFE69FAF364FB 75DFD02018B9929925C80702EBF80CC5FEC4FAF802AF07A0DB 3B82A10F94075E0A3BF301F8D0D5123B82A10F94075E0A3BF3 01F8D0FD6ADCF1DB4603FCC00E580F2134D232293D4333F3A0 DB268A10F8011212D702E9D512268A10F8011212D702E9FD26 030E0EC0EF02178A05C0D51226030E0EC0EF02412D2706DB17 8A05C0280D02260357CAD512260357CAFD18EB040EBA69FAF3 64FB6A0B5706C0D0D22E840B19FB2134D2200E05EDFB2134D2 731AA3F9F45706C0D01D291CBD16840B19FB2134D218FDEE00 AA8EF3A0DB9AA3F900DCF1DB2ACCFBA80AF4EBB0ECFBE5070E 07E6DCF1DBD98900280D0216032718EDFEEEEB00AF1C07BA20 22F51366F1E6A6BEF8FD011418EDFEEEEB00AF18F907F00EBA 2022F51366F1E6A6BEF8FD011424900500D5120030580FE9FD 00390397070BE7F000F66B51E9390397070BE7F03FEF001004 A1070D16070B080616C0D018112A64F900FC0B090D0ACA1811 85FD0116030319E680E5EB0486D408002A64F97DF6F31105AB 08FDD3FED408B99299F50DF645A268BF112CA9B8E93B1E0BB0 0F023BE63FEFF4EBF509070300F0CEB7071105AB08FD06E877 81D13B53050B0017CF743BE5F00D143FEF001004A1070D1607 0B080616C0D0181185FD0116030319E680F31105AB08FDD3FE D408B99299F50DF64545A268BFE054EE5F07FA482CA9B8E93B 1E0BB00F023BE63FEFF4EBF509070300F0CEB7071105AB08FD 06E87781D13B53050B0017CF743BE5F00D14CB48E8E3F364C0 54EEEFF8ABEB0EF9419C04F8E813C054EEEFF8ABEB0EF91A04 970AD3C26CF3A0DBCDF410EB0EF9E504DC178A0500FCF50DF6 A268BFE081D1120D020DE7251C07BA7997EDA994075EDFFC0B EDE70B02E6240811F50E04FC25180316E1FE69FAD9EDA2F80D 0519DA1505E69CD75669FA143706EEF5D9E7FECD199B6B0BEF 05F8D4F4EB00ADFE28AAF3FA8BF9E6CB02FC0D01252410FE09 94F86D9202E981D200E70C0313FBE630580F9606EC98FEDCF1 DB14CDC607F00AF2F4EBB0ECFBCDC607F00AF2F4EBB0ECFB2D 2706F8D51209FCFE0F08D506F1253976F90BE7F00002110F63 A0DB214F2815050069BAD5122815050069BAFDFF00A41710ED 020B0D99F410EB0EC0D0DC12040D09F80710ED020B0D991710 ED020B0DF894078A05FB731CF507078A05FBF5E9420111B992 F81D291A420111B992F8DCF1DB7100420111B99202E9DCF1DB 78A268F38A053181D028AA00D36B6004DB280D99060AFE1003 9705CF5E56C3040CF2F4030702E9A211F50FC211E6CB02FC0D 01251FFA07FDC4F3EA020DE90CC563CF1F096C169D19F4EBB0 ECFB78F3EA08029500D51278F3EA08029500FD1E0B6004DBF5 E90FE712FA08FB6B51E90F03FC021FC327E00A06E81609FB1F C327E0F0CE09FB1715D6AB00D5120002AFC1C26CFB1715D6AB 00D5120002AFC26CFB1E0B6004C612098A10F80F08D506F125 DDA7A3F900DCF1DBD9894F71C9F50F5A00D0ADFE0CE4C370AF 7C00130355E70BED0AF22571C9F50F5A00D0ADFEEED3F4040C FA04A91003F62571C9F50F5A00D0ADFE0B040CFA04A80AE5E4 45C370AF7C00E70BED0A45CA0D05F709F50F0FE60127D60725 71C9F50F5A00D0ADFE0B040CFA04D9ED00AADC0300E70BED0A F225CD199B6B0BEF05F854EC98FEE70C0313FBD989A910FD01 E620F854ECF3F7EC000127D3F8FD09FC01E6CB02FC0D0125AE DBD989000E580F004D022E0D5BE0DCF1DBCB92F8DCF1DBDD0C 0313FBD98900C80702EBF80CC5F2B99299AEDBD98900CB92F8 26D3021A0497ABEB0EFBDDC29DFE731C9606EE00058EBA4807 06FD001D291C25DD3652F8BFC9FBDD3652F80AF006FBDDAC06 0113C4E501EE030AF3A0DB2303040CCADC02D777D512230304 0CCADC02D777FD2204EAF365048667E7A731FD0911E61E0F5A 9606EC98FE080D05D98900731CD903090ABA1D291C1417D790 D611F4030AFE0BE704DB9F022134D2A6F804E9DC12040D0902 2134D217060C0D0902EB01EF07F50DF63107EA08F8EBDF05CF 5E196B51E9C1BFC9FB17F1010FE5030AFE57E3F364F9980402 D811E61715D6AB00D512A811156C2571C9F50F5A00F6F4760C 0D05E404C654EEF30CE2F80BE20A2517EA020DE9B627F8E813 FB4112E7FEB627F8E813FB24010CC204C608F0040CFB4330F3 A0DB7100DA02F9000D05F709F3A0DB000A0DFEBBC6DCF1DB1C 0FBBC60B760FF1B62134D2CDC6E813FB37010156AA8EF3A0DB D200E70C0313FB4E02CAF6F301F895E5CC6B0BEF05021F9D9E F86E4E60D6111F9D9EF86ECB92F8DCF1DB000A90F2F3110545 AB08FD06E8E3FF003CA40A0603A301FF003E411BEBB0ECFB2A CCFBFF003C180D09F70CFB9BA3FE1504D6CAD016FEE7AC0601 13FBFF003EFF003C180D09F70CFB9BA301FF003E1FF00AF2FF 003C1FE40290FE0CC501FF003EDDB087F29F0AF2FF003CBDE7 A7CEF1FF003ECB48E877DCF1DB1B57E012CCFB1B5711F30D0B 5107120D091FB8E93B4E023B00F6F4E704C6058EE5CCF55BB8 0720A2860BC30F0FFB2E090D012E08C90530E71130E7F02808 EB0E011FFC1923FB6F03F1021ACF5E19509B071AE41979A541 1AE41979A51AE4561A04A56A54EC98FEDCF1DBF5090703D989 0003EEFAB948E8E307E6CB02FC0D01257F6D48E8E38000ADFE EE67480706FD00DCF1C60127D302CA480706FDD97B07021E0B B00F02CA0F890FF854ECF509156C07F5ECC9F50F5A00F66B51 E96E7D54ECF410EB861E0F5A001E0B51076202CAD050156CE9 71C9FBC7EAE100DCF1DB000A90F2F31105AB08FD06E845E371 C9F50F5A00D0E704DF6E00FC211E0502FD110C072D27D62603 0356955305FD110C0722E4E3E21122E4E3E21122D3C26C6274 C70904E0F7A51BEBC1ADFEFFF7062B442C3CFF005C21FF003B FF003CFF003E25FF007CFF00A5341A04970BEBC107EA08F854 EED90DECF3F60F00EDF30F04B014CD0013C406DF09E4F0B01E 0B6004C66D02F00226E4F00BFE88C16466F126E4F00BFEE7B0 87FB34D229001001A7FA29A3011E0B51E90F03FC021BFAF712 E404B6CB02F0991BEF05AC11F403DC22F90B08060FE3CDF864 66F128080EEB06E8E335F00AED35FA0706FD3FF9CDC80BEDE7 0BF81718241F00ADBA7997EDA994075E0AE69CD719E5CC6274 14D296EB02E9F6F50ADFD4F507F5980D5B11E671C900EE670F FA07FD00F6F50ADFD425D296EB02E9F6F50ADFD4F507F5003F 04100303FF00210018F907F00EFAB99202E6CB02FC0D012517 FA13BA0A03F900C107950FEDF8040DEEF068BC0013C40D01E6 9CD719E5CC6274141BE704B1F5989D1995E504E0EA19630148 C4E5FC0D02F9E6220300C1E70C03A1D200EDF315D6AB00D512 A910AF0A90CAD1169D1995A9C35107142E9D1995B902F0023A 301718006E383A0F9D9EF86E383A37261E1A381BFAF712E404 B6212AE1FE02110FF92805FED55F3B1B760C0D05E4BC3B6274 7DD13B180D09F70CFB9B00E70B143B62B1F5086301F8D03B50 156C07F5ECC9FB3BE61E0F5AF4EBF3F0DF6EF50DF6A268BF11 142805FED55F3B1B760C0D05E4BC3B62747DD13B1F030706E3 F23B62B1F5086301F8D03B50156C07F5ECC9FB3BE61E0F5AF4 EBF3F0DF6EF50DF6A268BF11142805FED55F3B1B760C0D05E4 BC3B62747DD13BDD04DFADBA6E3B62B1F5086301F8D03B5015 6C07F5ECC9FB3BE61E0F5AF4EBF3F0DF6EF50DF6A268BF1114 2805FED55F3B1B760C0D05E4BC3B62747DD13B170CE2F80BE2 0A3B62B1F5086301F8D03B50156C07F5ECC9FB3BE61E0F5AF4 EBF3F0DF6EF50DF6A268BF11141B760FF1B628121209FC0128 0509FC012303040CF25305AB08FDD3F24EE3F3EA02AD211BEF 05AC11F403DC2171C9F50F5A00F6F50ADF058E006E00FC216A DCF1DB9606EEEFF8E7A7F26ADC0987FAFB91F900DC0987FAFB 29A3FEDC0987FAFB592900DC0987FAE012CCFB29A3FEDC0987 FAFB599A00DC0987FA06F9D9CCFB9AA3F900DC0987FAFB5929 00DC0987FAE012CCFB731AA3F900DC0987FAFB591D291A00DC 0987FA06F9D9CCFBC70987FA06F9D9CCFB3704D6F2D9ED00DC 0987FAE0DCEAE107C70987FAE012CCFB3704D6F2D9ED00DC09 87FAE0DCEAE107CB128A90BC62B1E90FC3AA0AC016E032D233 E617FA8BFE0FC3AA0ABA54EC00FC7C0C00D49610F000058EA9 10AF07D50215E2FEEB0AF50F5A6274F508FE6466F114220804 129922F90B08060FE31A04A535F00AED9A001001A7FA075C22 03A2FCF55BB8E9FDF3FA13BA0A03F900C1A202AB000A03A2FC F55BB8E9FCF4FAF712E404B66AC112EF05DFFDF3FA488CD0E7 AC06011301E65C0009E20EBAEEEBA910AF07950FED99143FEF 9606EC98FE0E0D060AC0F6E5CC629596063EE2DF1510FAFED4 F4EB000194E111F301F895E5CC160327F900EE04F8F0CEB7D4 00F6F3F00A7DE7B006A10CCCE9FD00D408E50316E1FE70FD01 E61FB8E93B4E023B00F6F3EA0802141BEBB0ECFB17FA13BA0A 03F900C107950FEDF8012702F00706FD0013C40D01E69CD719 E5CC627414C80B760FF1B62A06F1214FDDB087FBD906F1214F 7003F68503F67003F6078503F6072A03090AFA210032D2331A 23372410670CCCF4EB00FD09E016FEE7AC060113C054EEF502 EAAB0CF099220300D496EBF8D00E0300D0150116F55BB80721 39241826C80702EBF80CC5F2A80AE5E00FB8F0B0C8160327C8 07EAECBC9606ECA9C3B0C00D05F709F4760FF1B6E685AF0BEB C116FEADC00A90CAD1FC07EAECBC590113F0D9ED00010CFA0E F00B06F9E62290CAD1FC07EAECBC5F70AF54EC00B8EA080214 2204EAA80AB902F0F8169D56950067E70B760CF00AC016017C FED1FC07EAECBCE63FEFF4EBF4E704C604989D19959811F3A0 02CA3B49E3073B00FF003E003B1BE704C6169D19953BE685AF 0BEBC116FEADC00A90CAD1FC07EAECBC590113F0D9ED00010C FA0EF00B06F9E62290CAD1FC07EAECBC00D408A910AF54EC00 B8EA080214C80BEDE70BF86E9801E2FA62B1E69CD719E5CC62 741428080EEB06E8E32135FA0706FD21CB128A90BC21241067 D3F50009FC56D0731CE620F867840B04DBF5F81D291C141F08 D506F121260402F9F807F00AF22134D22694F895BBDB213432 D23326030BBC214F5C1603270081ADFE1611F5DAEEBADC8B01 DDB087C006A286D271C9F50F5A00D0FB06F8EB0AF50ADF058E 006E00FC211A04A52117063E01211ACF5E56FA08EDE66AC112 EF050A146AE7B087F2D9CCFB6A07F00AF2D9CCFB6A02110F01 2134D29AA3F929A3019AA3F91ACF5E1998AD11E6240811F50E 04810904D8141ACF5E56FA08EDE6240811F50E04810904D814 3ADAF55BB80738CDA3F93ADA0079A5386AC107950FEDDB98E0 E70B060F06F002CD0005CF5E19F3950FEDF87CA3F9E6CB92F8 D408F3FA8BFE0FC3AA0AFA143ADAF30D1640D70238CD006EF5 1366F1CDF8F0EF0E10A910AFA58FE0F6F304A1D1E7B087C006 A20E01DD0B060F06F0F8EDA3FE0BF0ACFE69BAC1FDD90627C0 0A06BFCA4D02610095BBC66466B712890032731C33E61C0FBB 02CA67E70B760CF00AFBE68000E7B006A1D195BBC6D4000501 C0F6B97EF8D0321D291C331485AFADFA1F0307020BE20AF3FA 8B01398A1026C91AED0CC46A0F0806EDD6112134D26AE7A7DD B087F2C80BEDE70BF8E70B060F06F0F8A70AB807350355E70B 030E050677AC04FCCAD3F516EFF8F6F3EA0802E61FF194FE6D 7EF81001A70701F8061200D40005ED0CBFE0ADFE06F854EE00 130355E70B030E0506E3E6350355E70B030E050677AC04FCF2 F310EF09DFEA19FEC29DFEFCF500360D0601F8F0AA08FD0CF0 0214DDC29DFE1206F1254FDD3652F8E740D7DBDD40D7DB214F CB02F0F8D016FEB865C054EC0003481508D6FEE8976D02F0F8 02110FFEA70AC0D0D170AF07FC0BFED1169D1995E6220300C1 E70C03A1D200EDF315D6AB00D512A910AF0A90CAB865F2E63F EF9606EC00C116FECEB7D0ADFE70FD01590113F0D9ED00010C FA0EF00B06F9E685AFA2E01004A1D016FEB8EA08DB1417EA02 AD213432D2338213C0D6010C071E08AB870129A9E2029AA9E2 99C80BEDE70BF807F00AFAF55BB8079F0AF2D9CCFB214F6A07 F00ACAE740D7DB98E04A4B0A9F0AF2214F9F02214F9FF8D601 0C071ACF5E56FA08EDE68CF6F3F00A1417FA8BFE0D791366F1 E6CB92F8D408F3FA8BFE0FC3AA0AFA1417FA8BFE0FC3AA0AFA 1E0F5A6B51E9D3F301F8D03B1E0719D97B07F8F7A53BE61E0B B00F02CA0F890FF8BFC907F50F5A00F66B51E96E000D05F709 F50F5A000127D607149CD719A363CF7449FA046500FC120321 1BEBB0ECFB2ACCFB1FF00AF2171C1F26A9030706E3F224010C C20402F980BB11350355E70B030E050677AC04FCCA1004E916 01F0F4760FF1DBE6350355E70B030E0506E3F4EB98FE9D6004 DB98E01003090ACA0AC9055F088A10F807A077888139039707 0BE7F000ED00AA04001001A707CFE6350355E70B030E050677 AC04FCF2F310EF09DF16FEE70F0104DB000612001001A70701 F8D3F410EB0EFB14A40A0603A3012A099410A301180D09F70C FB9BA3011F0307020BE20A240127F80CC50137261E1A72CB02 F0F8C107950FEDDBBD19DA15050005CF5E56FA08ED6A6DEAFC E90D0507950FEDDB00031640D7991C0FBBC6FC06F704DB9811 2134D21CC203A7F3FA8B01220887016FDC03F310E2F2C8D805 01F8B6F170FD014EF8D0D115011600D00AC9058404DF058EF3 FA8B012537261E1A6274211A0DB5BAC181AD01D2000501FBE9 B8EF085100ADC01611A80057F0F50F5AE61E050057F0F50F5A E5ADF816FE0B8407C0F6B902FC0D01141F04ADFBE61FF194FE 1504D6141FB8E93B9F0A3B00F6F3F0DF69FA21A6F816E0EE01 A5A4D0160814FF00266DAC1478F40309EF08A4D0F113010907 2A06EC00098A10B12E03090A2E0309DF0D050AFA09FC0120EA 09E420EA09E4000D050AFA09FC011F0904FC1F0904810D050A FA09FC0120A286FB06652AFDF80B0309EF08C807FAF8B62702 C807FAF8120804A5C807FAF80B09060F31E202C807FAF8B627 027540ADEA16B707063E011BC30F0006A20E012AFDF80B0309 EF081AED0CC42AFDF807063E01170CBF2AFDF8070211F12E03 090A2E0309DF0D050AFA09FC0120EA09E420EA09E4000D050A FA09FC011F0904FC1F0904810D050AFA09FC012D27AC04F30C BF180313011FEDAC0406F807063E0123F90B04F12303EAC6B6 270224012702212ACCFBCDF8E7AC060113FBDDB087F21FF00A F2178A790290FEC1FC0B090D0AFB1E02EAAB0CF0992134D25C F3F002213432D2335CE5070EE6FA08ED1FF00AF228088AFCC4 E5CCF3063E01213432D2333704D6F2D9ED00E7AC143220181E 1F4733A994075E0A28EEFA6274321F281F4333A994075E0A17 18241FA994075E0A5C6274C80B76F2F3FA485CF55BB8076100 79A5DDC21131F6F55BB80761F38A79020DE72A892134D25C00 1001A7FA3220181E1F4733260402F902260402F9F80D05E7A7 321F281F4333DDACE654EEF502EAAB07145CA301C80B76F2E5 CCF3FA482118E079A521DDC21131F6F55BB80721280D020E03 F2E5CCF3FA4821DDB087FB214F8213FB214F9F02214FC80B76 E63220181E1F4733F3FA13143220181E1F473300ADBA79A5C8 0B7614F3FA13BA02110F015C1603270079A518E079A5C80B76 CA321F281F4333F3FA1314321F281F433300ADBA79A5DDC211 31F6F55BB807280D020E03CA1718241FF3FA13141718241F00 ADBA79A51B0B212A89219F0221170D1640D70221802149F0F2 E5CC1603271BBFF2350355AC04FCCAE70B760CF00AFB7540AD 020CF099F364FB1A0497ABEB0EFB1E0B6004DB214F7540AD02 0CF0F812CCFB2D360DC4D3FA1B099407E4C446043E3E2D360D C4D3FA1AED0CC41F5723030B191E0B6004B61B099407E4C42D 0AD646043E3E1AED0CC41F5723F004A523030B19A6F89A1B09 9407E4C446043E3E1AED0CC41F5723030B19610079A5211BBF 00E740D7DBBD19DA1505F3FA13BAFA08ED1BFAF712E404C6FC 13C4060A6B0BED0ACAD070FD013BE9BBB69CD719B97EE36274 2D0808ED00030B0B9008FBE6AE77C10B760FF1DB1430580FF4 E7BCD9CCFBC813C4060AE50316E1FE69FAD9EDA202E6FF000D 348393D1FCD805BCC4F4EF05AC11F4030AFEFF002B731A003A 1D291C38D903ECC9C016E0D10C0316E1FE69FA2CD9ED000127 040CC2FEFF002B1D3D1A3D2F293D4347FF0035FF0036FF0037 FF003714C813C4060AE50316E1FE69FAD9EDA202E6FF000D34 8393D1FCD805BCC4F4EF05AC11F4030AFEFF002B731A003A1D 291C38D903ECC9C016E0D10C0316E1FE69BA54EEEFF8F1A7CA 3EFA032CD9ED000127040CC2FE00FF002B1D3D1A3D2F293D43 47FF0035FF0036FF0037FF003714C8AAEAE3F3F00AF2D9CCFB C813C406DF79A5CD0013C4060AF4FAF712E404B61C07BA2022 00C1E70B030E05D3C01611F3FA48412410FEADBAD400F0D8C0 0A03F900C10127D302E61FF194FEAC11F50E04FC146FDC0300 C107950FEDDB4603FCCA0E580FD9CCFB1BEBC109040D05AB98 08C907FAE61EDAEEBA466404F50FC2E6080D0505F21417F7EC 0095BBB1F3FA48E61BEBC19D5107F50F5A14CD006E00D00AD3 C26CCD0005CF5E19F40348040E01CDC607F00AF2D9CCFB731C F509E7A711F507078A05FBF5E9420111B992F81D291A1F0486 E73652F80BEBB0ECFB1BFAF712E404C6C1FDA910AFED004AA6 E2ABD9CCFB9F0AF2D9CCFB17FA13BA0AC90517FA8BFEC10795 0FEDDBA6E2ABF40806D89B00F6030009E20E018CF6E5E219E5 018F114B0A8CF6E5E219F30397D6010C078CF6E5E219F31107 B60CD906F18CF6E5E219F31107B60CD903090AFA8CF6F310C9 00031640D7028CF6F310C9F5EC00031640D79926D3F8D5000D C203A7F3FA8BF900C1E7A7111B030AFEF603F310ED0218E219 F5EC003BD23B1A0DB5BAC112EF050ABD0CE219F5EC003BD23B 2EADFCF9074B0A1B04F1050AE200F0AC111B5711F2180313F2 CDF8F0EF0E10E5018FE0FDE5018F114BDFF6F304A11206F1CD F8F0EF0E10A910AFA58FE0F6F304A11206F11F04EE00F60300 09FD0E2A099410A301C712040D090230580F0006A20E012130 580F0079A52130580F0002FD01214201110F04DF02FDF9211E 861289211E86F6211E02EAAB0CF002212E0B0B212204C6D598 7BEE211B0B211BD611211BEF05AC113CDD0E06FD212AE7FEB6 2702212A0806F00A09E079A52130F00AFA213903161606F921 78A26800840EFC217831178A0500FD2178314E0221FF00A478 A268B97E77A4D0178A0500FC212203A2FC211F94075E0A211C 07BA202221411C07FA79A53F04100303FF002100202221C802 F0E3211BF0ACFE79A5212D310CCCF3FA13BADA14215CF4F0AC FEDA1421750A06E3C4F55B0814211BD611211BEF05AC112130 E7CFCAB627022120A20E01211F0307EA09F403DC21DD0B060F 06F0022117EAB63C1FC313FCB0211F0307EA09F55BB8072118 E206EA09F3EA02AD219101211BF0ACFE79A52118070E14F4F0 ACFEDA1421280B0B9406FD2182A10F94075E0A2117EF050AF4 09060F21170D1640D70221240127022180216FDC03F409060F 2118EB040EBA79A518EB040EBA69FA71F3A0DB1BEBB0099CEB 0E011BF1E2D90601090AA6BEF8BB1128121228052D27D62603 0EFC178A0500FD4E0241178A0500C8178A0500FCC807FAF86D 92F8DCEAE11AAF07A0DB1F096C821301A648C4F3A0DB83DFD5 004DF802FD012150FAF87C21CDEECAD00AD3C26CCD0006A20E 019CEB0EF9F364FB2A060109DFC16466F1440028088AFCC4A3 FE449CEB0EF99606EC00C116FEE813FBE62D2706F8EB11156C 25C80B761472F509FA022123F2CA02FD012123F2CA1303090D A5211F08D5E1FE79A52118070E14F509FAF802FD01215CF4F0 02E76A0BF002E74AA3FE0BF002E72018F509FAF802FD01216F 160804B1F509FA0221D2E5FC0D02F926F9E9EEEB003D2F22F9 0B08060FE31C0FBBC66466B712890032731C333417063E0121 001D291C341E0F0FC32706A2C6FC07EAECBC00F7A521001D3D 1CE5FC0D02F93422F90B08060FE32100321D431C332D270FD7 DB00FC07EAECBC00F7A5CD199B0D05070FD7061206FB1C0FBB C6FC7CA2021417371C1F222E090D01F603EEA6BEF86D7E7702 110F0121DD31FC07FAF8A58F114BDFF6B902FC0DFE95BBB618 018F114BDFE70C0313FBE622C9058404DF12CCFB14CDF8F0EF 0E10E5018FE0FDA910FD01E61C0FBBC60BEBB0ECFB149F0AF2 2E090D01F603EEB97E77C112EF050AE685AF0501FBE9F6F3F0 DFE70FEDF8D5F30D0B5107120D090095BBB6E64E02CAD00F9D 9EF86EE62204EA72F40307F8A211F50FC211E64EF8DA1525DD B087FBD906F1CDF8F0EF0E10E5018FE0D0E7B006A11206F16F DC03F409060F00E7B087FB2AE1FEE7B087FB9AD9E1F900E7B0 87FB20A286E7B087FB24100197E7B087FB24AFE7B087FB4EF8 F6F3950FED023220181E1F47336B51E90F03FC02321F281F43 336B51E90F03FC021718241F6B51E90F03FC02230D09F9D9ED D90D029063FA48F311050B2150156C07F5ECC9CB127B0CD97B 070250156CE9E740D7027100D6010CE9DCF1DBD989D903090A FA22C90584A7F4EBB0ECFB2A03090ABADCF1DB180313C0D0D2 AEDB18018F114BDF7CA202DB18018F114BDF7997ABEB0EFB1F 94075E0AF410EB0EFB1F94075EDFDCF1DB1F94075E0A629F0A F2F4EBB0ECFB17EDDB6F8EF3A0DB1F94075EDFFC0BEDE70B02 1F94075E0AE90A0300C1A202AB8CF6F502EAABD906F1C7EAE1 E9C16466F18CD0DCF1B68CD008F004A5CDF8F0EF0E10E5018F 119F0AF2D9CCFB8CF6F304A11206F118ADE43503E4018503F6 23A706036FDC03DD0BED0ACBAC9402C7EAE10730BFFA118213 0122C90584A7072EE0BBB62EE079A52E11F3063E012EE07CA2 023008060A26D3F854EE00DCEAE10726D3021A0497C4E7A7E0 0127D3998CF66B6004C66D02F0022410FE12E1FED3F4571108 8A10F80FC302D7DB2900D6010C00C1DCF1DB9A00D6010CE9C1 DCF1DB18018FE0120DECE67FD6010CE912890030BFFA111418 018F114BDFC17CA202DB1A04970BEBC107EA08F854EED90DEC F3F60F00EDF30F04B0A6BEF8EA080E01F81203090AFA43303D 18112A64E6E4FD0775DF1203090AFA50FAF802FDF91E0F5A07 1E35202E181F1B09060F31E2021B57E01203090AFA1B57111B 5711088A10021AFD011FC302D7DB1BE704DB7FBFC7EAE10726 F00EEE2D0A06F87003F61A04A52AEDA2022A08040CF924110F FED500AA8ED200302E30202A30080470E407461F2D30D20019 2E18E219CA57E307D200182E18018F11F3EA02AD9CEB860F94 075E0A2AEDA2F8A58F114B0A18010C144BDF57E3077F0F9407 5E0A23F00497A50C144B0AA6F80F94075E0A3A0D057CA202DB 381803A11203090AFA18031301181F4718ADE4D9E1F949F049 F00030BFFA1120A20EF91F1A307F1203090AFA23F903090DE3 24FDF923F2CA02FDF9821301170BE7F0F364FA07A4EEED24D6 F1370116F55BB807A6360DF0B022C90584A707A6F804E915BF 0F040FFAA6F86DAC940217063E0149F000FCF301360DF0B017 ED022410010CF943301FBD19DA15056FDC03F409060F076F8E DD0BED0AF20737BF0F040FFA07372E181F37183518018F114B 0A83D8E5018F114BDF79A5218393058EA994075E0A2183D8E5 018F114BDF0F94075E0A2135FA0612E0058EA994075E0A212A 03090ABA79A5211BEBB009000AC90584A72522C90584A7F2D9 CCFB49F0D9E1FEDA1525002AE1FE0AC90584A7C0D0D214AEB6 2534D22A03090ABAC1010C0F0211E6AEB6253432D233CDF8F0 EF0E10E5018FE0FD4B0AE682A1D070FD0125CDF8F0EF0E10A9 10AFA58F11E682A1F6E5018F114B0A25CDF8F0EF0E10A910AF A58FE0D00AC9058404DF1206F12AEDA2F8A58F114B0A257FBF 006E00FDE5018F114B0A2518018F114BDF54EC98FE0D05840B 19FBE6CB02FC0D0125D2E5EDFEA58FE00501FBFBE6A6BEF812 E1F900D016FEDCF1DB257F1203090AFA253432D2332AE1FEF6 030009E286D00AC90584A717063E01FF005A037622C90584A7 F234D22AEDA202B1E5018F114B0AAEB117EDB19CD719F2F3A0 DB00D6010C3004970AC90584A7072DB5FB0AFBCD2812121710 C900DAB63FF94E77F7A531EF0278A268CD3FF96FDC03721BEF 05D807F4F1E2FB509B07F364FB1E0B6004DB214F24060CFA07 F4F1E2FB1F9D9EF86EB97EE36B60011F9D9EF86EB97E77FD00 1003090A9A002E1F9D9EF86EF50DEEF068BCD9CCFB830A72D9 7B07021F9D9EF86EB97E77C16466F183DF0F9D9EF86EB97EE3 D97B070283DF0127D302CA0F9D9EF86EB97EE3D97B07021F9D 9EF86E00C1BFC9FB1F9D9EF86E6B51E90F03FCF8C113C4060A CDF8BFC9FB170D16070B080616FED00F9D9EF86ED97B070283 DF0F9D9EF86EB97EE3D97B07021BF1E2F4EF05D8071BF1E200 F70CFA072D0A06F89DF7A19D51E90F02141F9D9EF86E00F70C FA1E0B51E90F03FC99301F2317E503DC0C17CF742204EAF4EF 05D81F9D19E66E00F70CFA1E0B51E90F03FCF89A2204EAF4EF 05D81F9D9EF86EB97EE3F48407C016E005CF5E191F9D9EF86E B97E77F00AFB1F9D9EF86E00C16466F11F9D9EF86EB97E7784 07021F9D9EF86EB97E7784070250156CE9FD09FCFEC16466F1 1710E2FBB97EE3E68CD0F00A141ACF5E1998AD111F9D9EF86E B97E7784070217FA8BFEC107950FEDDB24010C0FEDE2E005CF 5E19A9C316F10C371E1FB97E77F00AFB1E0B51E90F03FCF89A 61F5099B07211E0B51E90F03FC02212290BC00D5F5ECF3F907 14DDB087C0810994F807F907147100E7B087C06E9FF8810994 F807F90706FD71F3F0F86E1F9D9EF86E6B0BE60F02141E0BF7 A19D51E90F03FC021E0B51E90F03FCF8C49B071F9D9EF86E62 742290E6D5000994F807F90706FD1BE704B1B97EE3CDB62100 DA72E91510E1FE1608C907F22D0AD6CAC10F0307070616F11F E4020DE7DDC204B018E02A643ADAE501B5FA073818112A64F9 18112A64F9000AD3C26C1E0B5107F4030AF91E0B51E909EB0A 0CE219071ACF5E19A9890F02390397070BE7F018112A64F900 E4FD07750AE5CC |
09-21-2013, 09:09 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | FlashInfo.RestartMode : 2 80F08F00 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:10 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 08.35 09-01-12 RM-618 (c) Nokia IMEI: 356236049680176 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 12345 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
