03-02-2015, 09:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | Nokia X2 02 RM-694 White & Screen & Hang Done By ATIK Code: AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12101C0618102814 Original Product Code: 059D1G6 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354627054372844\354627054372844_55540.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354627054372844\354627054372844_CERTIFICATE_3E296F9C.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354627054372844\354627054372844_PMM_PROT_765CB0D2.bin Security Code: 01817 Data Sections : 04 Current File : rm694__11.79.mcusw Compile Name: rm694__11.79.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27528584 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CCF5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7ACE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: A7F4 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 26214400 bytes Data Checksum: 67B2 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm694__11.79.ppm_i Compile Name: package_i.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4647436 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41C00000~0x422FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4644092 bytes Data Checksum: 6EB3 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm694__11.79.image_i_059J6H5 Compile Name: package_i_059J6H5.image.fls Image Type : CONTENT Package Data Size : 15076624 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42300000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15073280 bytes Data Checksum: C480 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:06:53 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 11.79 15-08-12 RM-694 (c) Nokia IMEI Plain : 354627054372844 IMEI Spare : A354627054372840 IMEI SV : 33546270543728410F IMEI (2nd) : 354627054372851 IMEI Spare : A354627054372850 IMEI SV : 33546270543728510F Phone Model: K X2-02 Category : Entry Phone Type : RM-694 ================================================ Extended Phone Information ================================================ Product Serial Number: D1663EDAH Product Code : 059D1G6 Module Code : 0204922 Basic Production Code: 059C943 Long Production SN : 0 PPM SW Version : V 11.79 15-08-12 RM-694 (c) Nokia I BT MCM Version : 19e2-47026 MCU SW Version : V 11.79 15-08-12 RM-694 (c) Nokia HW Version : 1002 RFIC Version : Dummy RFIC version LCD Version : TPO Content Pack Version : Content: i_059J6H5 V 11.79 15-08-12 RM-694 (c) Nokia Bluetooth ID : C8:3D:97:CF:76:C6 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 01817 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 115B6002 DCC Ver: 004020 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
