11-26-2014, 15:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Lahore Age: 38
Member: 1016490 Status: Offline Thanks Meter: 290 | Nokia X2 Dead - [SOLUTION INSIDE] |
11-26-2014, 22:17 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @sajidshah50 The easiest way to fix you problem is to manually install/update your Nokia X2 Drivers to Nokia Emergency Connectivity Drivers which you can find here: C:\AdvanceBox Turbo Flasher\Drivers\ You will find a file EmergencyDownloadDriver.msi Install That. After your Phone is detected in Device Manager as "Nokia Emergency Connectivity" Then you can flash it easily Also, you can download Drivers here in case you cannot find it: http://174.120.45.27/tmp/EmergencyDownloadDriver.msi |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
11-27-2014, 07:48 | #3 (permalink) |
Member: 1016490 Status: Offline Thanks Meter: 290 | I have solved with your help. THanks a lot . Here is the Log. Code: Nokia Android Phone Flashing Started ====================================================== Nokia Android Firmware Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ====================================================== Emergency Loader Found! Sending FireHose Loader... Starting FireHose Loader... FireHose Loader Accepted! Start Sending Files... BOOT Partition Write: rm1013_2.1.0.11_user_boot.img Partition Write OK! CACHE Partition Write: rm1013_2.1.0.11_user_cache_1.img Partition Write OK! ABOOT Partition Write: rm1013_2.1.0.11_user_emmc_appsboot.mbn Partition Write OK! ABOOTBAK Partition Write: rm1013_2.1.0.11_user_emmc_appsboot.mbn Partition Write OK! MISC Partition Write: rm1013_2.1.0.11_user_misc_erase.img Partition Write OK! MODEM Partition Write: rm1013_2.1.0.11_user_NON-HLOS.bin Partition Write OK! RECOVERY Partition Write: rm1013_2.1.0.11_user_recovery.img Partition Write OK! RPM Partition Write: rm1013_2.1.0.11_user_rpm.mbn Partition Write OK! RPMBAK Partition Write: rm1013_2.1.0.11_user_rpm.mbn Partition Write OK! SBL1 Partition Write: rm1013_2.1.0.11_user_sbl1.mbn Partition Write OK! SBL1BAK Partition Write: rm1013_2.1.0.11_user_sbl1.mbn Partition Write OK! SDI Partition Write: rm1013_2.1.0.11_user_sdi.mbn Partition Write OK! TZ Partition Write: rm1013_2.1.0.11_user_tz.mbn Partition Write OK! TZBAK Partition Write: rm1013_2.1.0.11_user_tz.mbn Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_1.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_10.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_11.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_2.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_3.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_4.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_5.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_6.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_7.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_8.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.11_user_system_9.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_1.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_2.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_3.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_4.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_5.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_6.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_7.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.11_059V782_001.custom_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_1.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_10.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_11.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_12.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_13.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_14.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_15.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_16.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_17.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_18.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_19.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_2.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_20.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_21.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_22.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_23.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_24.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_3.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_4.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_5.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_6.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_7.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.11_user_userdata_9.img Partition Write OK! Sending All Files Done! Total Flashing Time (Erase + Flashing) : 00:03:40 Restarting Phone... Wait 1 to 3 Minutes for Phone First Boot |
The Following User Says Thank You to sajidshah50 For This Useful Post: |
11-28-2014, 14:03 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Flash latest firmware like my screenshot. Not sure what else is wrong... Make IMEI backup as well, and rar it and upload it somewhere. I can check config from there. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-17-2016, 12:17 | #11 (permalink) |
No Life Poster Join Date: Jul 2009 Location: CHENNAI
Member: 1079392 Status: Offline Thanks Meter: 444 | NOKIA X2(RM-1013)dead recovered with usb only Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME DOWN button 3. Continue to Press the VOLUME DOWN button for 15 more seconds ================================================== ==== Emergency Loader Found! Sending FireHose Loader... Starting FireHose Loader... FireHose Loader Accepted! Start Sending Files... BOOT Partition Write: rm1013_2.1.0.13_user_boot.img Partition Write OK! CACHE Partition Write: rm1013_2.1.0.13_user_cache_1.img Partition Write OK! ABOOT Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn Partition Write OK! ABOOTBAK Partition Write: rm1013_2.1.0.13_user_emmc_appsboot.mbn Partition Write OK! MISC Partition Write: rm1013_2.1.0.13_user_misc_erase.img Partition Write OK! MODEM Partition Write: rm1013_2.1.0.13_user_NON-HLOS.bin Partition Write OK! RECOVERY Partition Write: rm1013_2.1.0.13_user_recovery.img Partition Write OK! RPM Partition Write: rm1013_2.1.0.13_user_rpm.mbn Partition Write OK! RPMBAK Partition Write: rm1013_2.1.0.13_user_rpm.mbn Partition Write OK! SBL1 Partition Write: rm1013_2.1.0.13_user_sbl1.mbn Partition Write OK! SBL1BAK Partition Write: rm1013_2.1.0.13_user_sbl1.mbn Partition Write OK! SDI Partition Write: rm1013_2.1.0.13_user_sdi.mbn Partition Write OK! TZ Partition Write: rm1013_2.1.0.13_user_tz.mbn Partition Write OK! TZBAK Partition Write: rm1013_2.1.0.13_user_tz.mbn Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_1.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_10.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_11.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_2.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_3.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_4.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_5.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_6.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_7.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_8.img Partition Write OK! SYSTEM Partition Write: rm1013_2.1.0.13_user_system_9.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_1.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_2.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_3.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_4.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_5.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_6.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_7.img Partition Write OK! CUSTOM Partition Write: rm1013_2.1.0.13_059V782_001.custom_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_1.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_10.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_11.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_12.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_13.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_14.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_15.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_16.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_17.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_18.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_19.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_2.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_20.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_21.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_22.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_23.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_24.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_3.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_4.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_5.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_6.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_7.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_8.img Partition Write OK! USERDATA Partition Write: rm1013_2.1.0.13_user_userdata_9.img Partition Write OK! Sending All Files Done! Total Flashing Time (Erase + Flashing) : 00:03:29 Restarting Phone... Wait 1 to 3 Minutes for Phone First Boot |
The Following User Says Thank You to mmurugan1978 For This Useful Post: |
12-06-2017, 13:57 | #12 (permalink) | |
Freak Poster Join Date: Mar 2012 Location: BARNALA
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | Quote:
