10-21-2014, 16:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | nokia xl rm-1030 dead boot repair done thanx team atf Code: ========================================================== Phone Type : Nokia XL [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.2.3.1 ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D4201BB18DC5E61B4 Flash Description: Samsung J5XWMB, 3.64 GiB, SN BB18DC5E, Jun 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91932 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Completed in 0h 1m 30s. Code Download Speed 228 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= |
The Following 3 Users Say Thank You to tornado2008 For This Useful Post: |
10-23-2014, 13:46 | #2 (permalink) |
Member: 648590 Status: Offline Thanks Meter: 267 | and lumia 520 boot and flash Code: ========================================================== Phone Type : Lumia 520 RM-914 CPU Type : Qualcomm MSM8227 Storage TYpe: eMMC 8GB Boot Package: 3046.0000.1329.2009 (BIG BOOT) ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943001D095A5C605A Flash Description: Samsung M8G2YC, 7.28 GiB, SN 1D095A5C, Jun 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3257 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Restoring Partition #11...OK Restoring Partition #12...OK Completed in 0h 13m 21s. Code Download Speed 216 KiB/sec. Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ============================================================= Code: 22:11:30 : ====================================================== 22:11:30 : Flash File Checksum Verification 22:11:30 : ====================================================== 22:11:38 : RM914_3058.50000.1425.0001_RETAIL_im_mea3_334_01_444363_prd_signed.ffu: CHECKSUM PASSED 22:11:38 : ====================================================== 22:11:38 : Verification Done... 22:12:00 : Windows Phone 8/8.1 Flashing Started 22:12:00 : Loading Flash Files Please Wait... 22:12:00 : 22:12:01 : ====================================================== 22:12:01 : Windows Phone 8/8.1 Lumia Flasher 22:12:01 : ====================================================== 22:12:01 : 22:12:01 : If the Phone is ALIVE 22:12:01 : 1. Power On the Phone and Connect it to the USB Port 22:12:01 : 22:12:01 : If the Phone is DEAD 22:12:01 : 1. Connect Phone to the USB Port 22:12:01 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 22:12:01 : 3. Wait until the Phone Vibrates Shortly... 22:12:01 : 4. Stop Pressing the Buttons... 22:12:01 : ====================================================== 22:12:01 : 22:12:14 : Nokia Phone Info Mode Initiated... 22:12:14 : Please wait upto 15 Seconds for SW Reset 22:12:14 : IMEI: 357287057064117 22:12:14 : Version: 1.1.1.3 22:12:14 : Product Code: 059S1L2 22:12:14 : Module Code: 0205435 22:12:15 : 22:12:15 : Continuing Previous Boot... 22:12:15 : Please wait upto 30 Seconds for Boot Re-entry 22:12:16 : 22:12:16 : Boot Flash Mode Successful... 22:12:17 : Buffers Flushed OK... 22:12:17 : 22:12:17 : Phone Info Query Start... 22:12:17 : Blocks Returned: 0x07 Blocks 22:12:17 : Block ID 0x01 :00241000 22:12:17 : Block ID 0x02 :00240000 22:12:17 : Block ID 0x03 :00E90000 22:12:17 : Block ID 0x05 :Nokia.MSM8227.P6036.1.2 22:12:17 : Block ID 0x0D :0001 22:12:17 : Block ID 0x0F :0301010100000101FF 22:12:17 : Block ID 0x10 :0100030000 22:12:17 : Checking SD Card Size... 22:12:17 : Card Size: 0x00000000 22:12:17 : Checking Platform Security Status... 22:12:17 : Platform Secure Boot Status: Active 22:12:17 : Secure FFU EFUSE Status: Active 22:12:17 : Debug Status: Active 22:12:17 : RDC Status: Not Active 22:12:17 : Authentication Status: Not Active 22:12:17 : UEFI Secure Boot Status: Active 22:12:17 : Checking Secure FFU Mode... 22:12:17 : Secure FFU Mode : SYNC + ASYNC 22:12:17 : Query Flash App Information... 22:12:17 : Flash App Information: 02010E011900 22:12:17 : UEFI App: FLASH APP 22:12:17 : Flash App Protocol Version: 1.14 22:12:17 : Flash App Implementation Version: 1.25 22:12:17 : Query ROOT KEY HASH... 22:12:17 : ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACECAEF3F808C868FD 22:12:17 : 22:12:17 : Sending Image Signatures... 22:12:18 : Image Signatures Accepted! 22:12:18 : Erasing Data Partition... 22:12:19 : Data Partition Erased Successfully 22:12:19 : Preparing Buffers for DATA LOOP... 22:12:19 : Allocating System RAM OK! 22:12:19 : Start Sending DATA BLOCKS... 22:16:30 : Finished Sending all DATA BLOCKS! 22:16:30 : Exiting FLASH Mode via REBOOT... 22:16:30 : Exit FLASH Mode Successful! 22:16:30 : 22:16:30 : Flashing Done! 22:16:30 : Total Flashing Time : 00:04:13 |
The Following User Says Thank You to tornado2008 For This Useful Post: |
