10-29-2014, 04:53 | #1 (permalink) |
Junior Member Join Date: Apr 2009 Location: Indonesia
Member: 1008208 Status: Offline Thanks Meter: 0 | nokia XL rm-1030 file mismatch what to do? i don't see any V1 with same product code Flash File is for REVISION 2 Phone... Nokia Android Phone Flashing Started ================================================== ==== Nokia Android Firmware Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME DOWN button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 15 more seconds ================================================== ==== Establishing Connection... Device is in Recovery Mode Phone Info cannot be Read... Flash File Mismatch!!!, Flashing Cancelled!!! |
10-29-2014, 05:46 | #3 (permalink) |
Member: 1008208 Status: Offline Thanks Meter: 0 | still can't flash it, i pressed vol up with battery inserted, connect to usb, and it goes into recovery mode and Establishing Connection... Device is in Recovery Mode Phone Info cannot be Read... Flash File Mismatch!!!, Flashing Cancelled!!! |
11-01-2014, 16:58 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
In Power On Mode File Mismatch But After Flashing In Dead Mode With This File RM1030_1.2.3.1_059V6Q7_IMEA_PK Now Fone Is Dead My Question Is Why Happened Like This And Need Help Plz Last edited by shoaibrao; 11-01-2014 at 17:04. | |
11-01-2014, 19:43 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @shoaibrao Yes, you killed phone... Actually, you see that software already told you flash file is mismatch, but you still did not listen to it. So it is dead because you did not follow WARNING MESSAGE. You need to repair boot via JTAG or via eMMC Direct. Next time, follow what ATF Software tells you... B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
11-02-2014, 07:41 | #7 (permalink) | |
And Apology For My Mistake Actually Your Below Given Quote Misunderstand Me So This Happened Just Give Us Any Hit To Differentiate Between V1 And V2 Before Flashing Thanks Anticipation | |
08-03-2015, 06:51 | #10 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 360614 Status: Offline Thanks Meter: 63 | |
