05-01-2015, 17:25 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Venezuela
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | note3 n9005 dead after flash thanks |
05-01-2015, 18:19 | #2 (permalink) |
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D4247344743000146495670CD CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 31268536320 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : MBG4GC Product Rev : 0.0 Product SN : 01464956 Manufactured : July 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D4247344743000146495670CD.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Write EXT_CSD Backup Task Done! Start Writing 0x00001000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:04 Write Success! Start Writing 0x00001000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:04 Write Success! Start Writing 0x00100000 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:16:16 Write Success! |
05-01-2015, 18:30 | #3 (permalink) |
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | i am writing full flash 4.4.2 but phone still dead Start Writing Flash Images... Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x00026800 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: boot.img Start Writing 0x00005800 Blocks at 0x0003C000 Partition Selected: USER AREA Total Elapsed Time 00:00:22 Write Success! Warning: EXT3/4 Image Detected Skipping cache.img.ext4... Warning: EXT3/4 Image Detected Skipping hidden.img.ext4... Flash Image: modem.bin Start Writing 0x0001CB80 Blocks at 0x00009800 Partition Selected: USER AREA Total Elapsed Time 00:01:50 Write Success! Flash Image: non-hlos.bin Start Writing 0x00007800 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:28 Write Success! Flash Image: recovery.img Start Writing 0x00006800 Blocks at 0x00041800 Partition Selected: USER AREA Total Elapsed Time 00:00:25 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x00027800 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: sdi.mbn Start Writing 0x00000040 Blocks at 0x00026780 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Warning: EXT3/4 Image Detected Skipping system.img.ext4... Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00027C00 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Total Images Written: 9 Process Done! |
