07-09-2010, 03:13 | #31 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Hi, no need to replace anything... Just remove LT1930 and it's supporting components. Then redirect VBATT to use the backup regulator and put the special firmware to the box. All this can be done by following the first post of this thread. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
07-12-2010, 09:57 | #32 (permalink) |
Junior Member Join Date: Jan 2006
Member: 223608 Status: Offline Thanks Meter: 0 | hy, ATF Team, I am new perchase atf box but its green light is not on,i install new vergen 5.50 and update firmware no any respons not info not connect any mobile so what can i do plz help me with thanks, here is my box logs. AdvanceBox Turbo Flasher Found Driver Version : 00020601 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 7.07.10 Software Version : v5.50 AdvanceBox SN : 9CFF6A3C9D41F35DC478B338 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... |
07-12-2010, 16:49 | #33 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: nija Africa Age: 47
Member: 121356 Status: Offline Thanks Meter: 73 | Quote:
07-12-2010, 16:56 | #34 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @obioha It can be easily fixed by you or your reseller. Once it is fixed, it will never go back to same problem again and you do not have to replace any parts at all. We already removed the LT1930 in the new batches of PCB. It takes less than 15 minutes to perform the pcb modification. And your box will still function the same as before and you get some free 1.5 GB extra from our download servers as well. B/R |
07-13-2010, 09:29 | #35 (permalink) | |
07-13-2010, 10:00 | #36 (permalink) |
Crazy Poster Join Date: Mar 2010
Member: 1271501 Status: Offline Thanks Meter: 5 | how much atf have light pls help me withe pic ..........................help me atf 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02034100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 27D0020B ID DWORD 1 : A7400E49 ID DWORD 2 : DFF1905E ID DWORD 3 : 187B1DBC ID DWORD 4 : 2102763D 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 Checksum F1 SearchForBootstrap_DCT5.. CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv40_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT |
07-14-2010, 17:30 | #38 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gamal hussein This is RAP3Gv4 Phone and it requires a good QUALITY wire for the cable. Tell me the brand of your cable and I will PM to you how to fix the manufacturer's short comings... B/R |
07-18-2010, 17:58 | #42 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: Romania/Craiova Age: 45
Member: 44085 Status: Offline Thanks Meter: 123 | Quote:
Thank's! | |
07-23-2010, 12:11 | #45 (permalink) |
Major Poster Join Date: Feb 2008
Member: 711504 Status: Offline Thanks Meter: 9 | hi all the product supporter pls guide me for the problem in my atf box when i m connecting my atf it is not showing found new hardware or detecting new hardware only green light blinking continuously pls its urgent |
