Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-13-2010, 16:22   #91 (permalink)
Temporary banned !!
Member: 839503
Sonork: 100.1578866
Thanks Meter: 108
Please give update firmware for modifyng PCB using 6.0
Br.
Kabir Telecom
Old 11-13-2010, 16:53   #92 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Br.
Kabir Telecom
Hello!
What's WRONG ? What update you need ? There's nothing wrong with modified PCB boxes. They are working well with v6.0 - And there's NO need any WARNINGs to users.
Old 11-15-2010, 12:47   #93 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 353
Originally Posted by utuh View Post
how to modif for new PCB, my box cant check any phone.
same problem help me
b.r
yuvi
Old 11-20-2010, 14:22   #94 (permalink)
javakiller's Avatar
Member: 180873
Thanks Meter: 80
ATF box repair
My box worked fine for the first day then caused problems, so I followed the modify PCB method and it seems to work fine for now,
STEP 1 ( REMOVE COMPONENTS ) :
STEP 2 ( MAKE JUMPER ) :
STEP 3 (WRITE SPECIAL FIRMWARE)
STEP 4 (Restore/update box via main software)
Maybe this will be a bit more clearer for some people
The Following 3 Users Say Thank You to javakiller For This Useful Post:
Old 11-28-2010, 15:22   #95 (permalink)
Member: 501123
Thanks Meter: 8
my atf box LT1930 is broken,only disply blue led ,please equalent value of new regulator ic value ple reply
Old 12-09-2010, 10:21   #96 (permalink)
Member: 777756
Thanks Meter: 44
i was having problem in atf of green light i did all things as above handset is now flashing but as i treid to read information or any other function it is not oprating pl help.
Old 12-10-2010, 08:10   #97 (permalink)
Member: 395389
Sonork: no idi
Thanks Meter: 193
thanks to every one.i repear my atf 1000000000000000000000000%
Old 12-14-2010, 15:19   #98 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
After update install all remove parts again yes or not .... remove jumber yes or no
Old 12-14-2010, 15:27   #99 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
After Modify my atf box problum solve....
Old 12-19-2010, 10:44   #100 (permalink)
faizafirdous's Avatar
Member: 1281866
Thanks Meter: 330
i need spacial firmware sir
Old 12-19-2010, 12:52   #101 (permalink)
Member: 923032
Sonork: 321321
Thanks Meter: 17
AdvanceBox Turbo Flasher Found
Driver Version : 00020601
Library Version : 00030119
Initialize Device....
Init TRY : 1
Box Name : AdvanceBox Turbo
Box Firmware : LogiCore 8.15.10
Software Version : v6.10
AdvanceBox SN : DF0DC573D4C0C9FFDBAF8A78
BOX Status : ACTIVATED
INIT : OK
VBATT OFF...
VBATT ON
Setting VBATT Done!...
ERROR : PHONE READ INFO FAILED
i cannot flash the phone i cannot do anything with this box. please give me the solution
please please please
Old 12-23-2010, 16:31   #102 (permalink)
Member: 1001635
Thanks Meter: 63
sir
My atf box can not boot any set from yesterday though The green light is lightning ok.
I reinstall the drivers as well as the box v6.10 softwares.I have also updated the fimware
bot the problem has not solved yet.
Please help......................
Old 12-23-2010, 23:21   #103 (permalink)
chardex's Avatar
Member: 162332
Sonork: 100.1578458
Thanks Meter: 36
for this also new pcb what is the solution.....................i run the software all and driver install properly the box cannot detect...atf box not found all i doing they same problem...box not detect...new box days....pls..make solution this
Old 12-24-2010, 16:03   #104 (permalink)
Member: 640605
Thanks Meter: 9
Old 12-25-2010, 12:38   #105 (permalink)
Member: 205475
Thanks Meter: 179
after i make all steeps i can flash but i can not read info and i can not make factory reset
Use "BUSCHECK" Button to Force the Phone
into Local Mode... Then "SCANPHONE" after.
For N95, N95-8GB and E90 Phones, you need a
Test Mode Adapter to provide some Extra Power
so that the Phone will go into Local Mode...
Page generated in 0.23114 seconds with 10 queries
