01-19-2012, 13:39 | #226 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | We have need of remove the Mm ic component First?, Please answere to this becouse not is clear, Regards Max[/QUO Very nice solution but ı have atf lightning small box solution add my box not found pc no usbA no usbB no search device manager no ding dong pc only blue light .I usb cable change R3 R4 resistor jumper 12.000 mhz smd cyristal change but same problem plesae HELP ME... |
01-21-2012, 04:59 | #228 (permalink) |
Insane Poster Join Date: Jan 2009 Location: Accra, Ghana
Member: 948596 Status: Offline Thanks Meter: 1 | help green light 03:39:41 : ================================================ 03:39:41 : Advance Turbo Flasher Found 03:39:41 : ================================================ 03:39:41 : Driver Version : 00020817 03:39:41 : Library Version : 00030206 03:39:43 : Box Type : AdvanceBox Turbo 03:39:43 : Box Firmware : LogiCore 9.02.10 03:39:43 : Software Version : v8.10 03:39:43 : AdvanceBox SN : E8694999E3AD6E36BC5ECF2B 03:39:43 : Box Status : ACTIVATED 03:39:43 : ================================================ 03:39:43 : Box Successfully Initialized 03:39:43 : ================================================ 03:39:43 : 03:39:43 : VBATT Powering Down <<<< 03:39:47 : VBATT Powering Up >>>> 03:39:47 : SET VCCIO Level Done 03:39:47 : SET BSI Load Done Pls if I open the atf software this is what display but it cannot boot any phone I have re intall the driver but yet still is not working. but what I have realise is that the green light and the phone light that is the middle light is not working. so pls in this case can I modify the pcb? if yes pls give me full details about it thanks |
01-21-2012, 05:42 | #229 (permalink) | |
Member: 948596 Status: Offline Thanks Meter: 1 | green light problem Quote:
02-25-2012, 03:44 | #234 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | can any one give solution to atf lighting new error problem have serch this tread the solution is for the old and new big atf what about the new lighting atf |
03-09-2012, 08:44 | #236 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 704971 Status: Offline Thanks Meter: 4 | after firmwere update mmc unlocked ok but green light goes off and orange light is on continously. plz help fast.after restore my box then also box is not working and mmc also not working .rep fast i have to flash many phones and i mostly use atf only |
03-10-2012, 15:53 | #237 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | If any body helped me, i appriciate for his willingness, ATF_BOX is on BLUE lite D:\ATF_BOX\DOCS_PICS\BOX_REPAIR\MY_DEAD_BOX\MODIFY _BOX_SOFTWARES\NEW_PCB_81510>D irectC.exe -aprogram firmware.dat OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOO OO OO OO AdvanceBox JTAG In-System-Programming v1.0 OO OO OO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOO AdvanceBox JTAG: Open Port Success... Calculating timer calibration value... Timer calibration value = 2214 | | -<+>- Firmware Update will take approximately 7 minutes -<+>- | | ActID = 32A141CF ExpID = 3A141CF Initializing Target Device... Setting BSR Configurations... Loading BSR... Reading Security... Performing Data Authentication.......................... Erase... ACTEL_SLOG_UROW = FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Programming UROW... Programming FPGA Array.......................... Verifying FPGA Array.......................... Programming Rlock... Programming FlashROM... Programming SILSIG... Exit code = 0... | | -<+>- Firmware Update was a Success! -<+>- | | Please type 'exit' and press the 'Enter' key to close this Window... Elapsed time = 00:04:55 D:\ATF_BOX\DOCS_PICS\BOX_REPAIR\MY_DEAD_BOX\MODIFY _BOX_SOFTWARES\NEW_PCB_81510>p ause Press any key to continue . . . BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
03-10-2012, 15:56 | #238 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
http://forum.gsmhosting.com/vbb/8215231-post1.html | |
